Old 09-26-2013, 07:51 PM   #1096
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,994
Originally Posted by Ride4Coffee View Post
Hey Jim, How's the kit held up over the past couple months that you've had it? I'm shocked to see a HID kit for $24. I just thought it would be some major expense.
I use it every day, still no issues.
Jim
Old 09-29-2013, 08:12 AM   #1097
johnny80s
johnny80s's Avatar
Oddometer: 267
I put in a ddm tuning kit and took it on a 2000 mile test run. I like it a lot.
johnny80s is online now   Reply With Quote
Old 09-29-2013, 09:18 AM   #1098
Hikertrash
Oddometer: 2,869
Yep, I've had my DDM Tuning HID in for about a year and 12,000mi. I know I paid under $30 shipped for it and I wish I bought it when I first bought my bike.
Hikertrash is offline   Reply With Quote
Old 10-01-2013, 10:16 AM   #1099
Falco888
Falco888's Avatar
Oddometer: 63
Originally Posted by Falco888 View Post
Has anybody install a HID on the 2013 GSW?
thanks!
Anybody?
Falco888 is offline   Reply With Quote
Old 10-01-2013, 01:41 PM   #1100
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,994
Anybody?
It is an H7, same as the old Hex and Cam heads, be the first!
Jim
Old 10-01-2013, 02:01 PM   #1101
Falco888
Falco888's Avatar
Oddometer: 63
Jim
I know but the cap looks different. Also, I was wondering how sensitive would be the cambus on the water cooled.
Old 10-01-2013, 02:05 PM   #1102
johnny80s
johnny80s's Avatar
Oddometer: 267
At the most it will cost you 38 bucks for a kit and a set of caps. That's not bad at all.
DDM tuning has a lifetime warranty.
Old 10-01-2013, 03:19 PM   #1103
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,994
You can try it before cutting the cap, just to see.
If you were close I would lend a hand. I would try the 35 watt first.
Jim
Old 10-01-2013, 09:15 PM   #1104
johnny80s
johnny80s's Avatar
Oddometer: 267
The 35 watt version puts out a lot of light.
Old 10-02-2013, 10:56 PM   #1105
RJP3579
RJP3579's Avatar
Oddometer: 109
When installing the 35w ones, do you connect directly to the factory bulb connections or do you need to run a relay connection from the battery for enough power?
If you buy a set, which they seem to come in, can you use the other for the high beam?
Rick
'09 R1200GS - Namibia Orange
'04 BMW R1150RT - Silver (Traded in)
'97 BMW R850R (Gone but not forgotten)
RJP3579 screwed with this post 10-02-2013 at 11:33 PM
RJP3579 is offline   Reply With Quote
Old 10-03-2013, 04:12 AM   #1106
TuefelHunden
TuefelHunden's Avatar
Oddometer: 591
That lifetime warranty isn't all it that appears. I made the mistake of buying two of DDM 55w units. The high beam is going strong, but it was one lampf1 after another. They avoided the entire lampf issue, even when I got the error killer which did not work either. Yes they would talk to you and replace with more components that did not work. Got another 35w kit from HIDSRUS. Went through two ballasts and two bulbs. Again they would replace but the problem did not go away. IMO, the issue is not CanBus. It is ZFE and if you get one that is finicky you will have to find one that works. The set that JVB has is on and working, no problems. Like others have said, use 35w on low beam. 55w is too much light for low and definitely has issues with the ZFE.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 10-03-2013, 07:52 AM   #1107
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,994
No relay or extra wiring needed. Yes, you can do high and low beams.
Jim
Old 10-03-2013, 08:17 PM   #1108
kimzx1000r
kimzx1000r's Avatar
Oddometer: 532
25 dollars off ebay, conversion done tonight on GSA, mounted ballast to light bar under oil cooler! Changed 3 h7 bulbs in 17000 miles! I hope I'm done for a while!
kimzx1000r is offline   Reply With Quote
Old 10-03-2013, 09:21 PM   #1109
RJP3579
RJP3579's Avatar
Oddometer: 109
Jim
Thanks, Jim!
I ordered the same set you have.
Rick
Old 10-21-2013, 05:30 PM   #1110
mbaur
mbaur's Avatar
Oddometer: 4
Jim
Ordered the same set on 09/09 since it was so cheap ($25 shipped) while I was two thirds of the way through this thread. Installed without a hitch and has been fault free (about a month later and 1000 miles on it) so far.
I tested the high beam first without installing since that looks like the quickest way to test if they work. Even without warming up they were as bright as the stock bulbs (subjectively, not measured), so I went for high and low beam. And just for the record the bike is a 2005 R1200GS.
Also worth mentioning if you haven't gotten this from the pictures: slim ballasts, but no separate igniters.
I'm very happy about the conversion and carry one of the H7s I replaced as a spare on the bike.
- Markus
mbaur is offline   Reply With Quote
Times are GMT -7.   It's 09:04 AM.
