Old 01-23-2008, 09:57 PM   #61
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,449
Originally Posted by duckboy
woody,
what would a set (f&r) of these wheels for my r12gs run me (gold excels, your cnc'd gold anodized hubs, big spokes, and front rotors)?
feel free to pm me off line if you want...
thanks
duckboy
depending on the rotors circa $2200-2400
UPDATE,,2 JULY 08,,,,FYI,,BMW's latest prices :
front wheel only,,no brakes,,,$1219.85
rear #1231.02
sub-total=$2450.87
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 07-13-2011 at 06:02 AM
Old 02-05-2008, 08:43 PM   #62
configurationspace
delooper
configurationspace's Avatar
Oddometer: 9,069
Hi Woody,
Are you in production yet, or are you still in a testing phase?
I'm looking for a set of off-road wheels for the HP2, ie: 21" front, 18" rear. Your new hubs look nice/desirable. Please let me know if you think something like that might be available to ship before summer.
Thanks.
configurationspace is offline   Reply With Quote
Old 02-05-2008, 09:56 PM   #63
Built to Last
Oddometer: 3,449
whoaaa here's a lil news for you...
Originally Posted by configurationspace
Hi Woody,
Thanks.
check this out...where have you been????
http://www.advrider.com/forums/showthread.php?t=294435
or....
http://www.advrider.com/forums/showthread.php?t=301724
we still have a couple from the first run left,,,after the feedback from the Sandblast rally,,,run # 2 will kick in,,,we do not anticipate any changes,,,
holler n thanks for inquiring
woody
Old 02-05-2008, 10:47 PM   #64
configurationspace
delooper
Oddometer: 9,069
I just moved back to Canada after being away for 12 years. So I've been keeping busy.
or....
woody
I'll try to give you a phone call tomorrow. I won't be able to beat the hell out of your wheels until summer, unfortunately. But if you'd like another customer for your 1st batch and you're not so fussy about how badly I'll abuse your work, then I'll take a set of your 1st batch. Otherwise I'd be happy to wait until the 2nd batch -- either way I'd just like to get my hands on a set before the end of April.
Old 04-18-2008, 05:12 PM   #65
Built to Last
Oddometer: 3,449
here's my Superlite II Hubs for R12GS and GS Adventure,,with/without ABS!!!
These are Woody's latest creation.
Feature's:
1) Can be used on any BMW R12GS and R12GS Adventure with/without ABS.
2) You can use your stock Rotors, ABS, and Hardware
3) Can be put with any 36H Rim Jap lace pattern
4) Currently available in Silver/Black/Blue [have spares to anodize in other colors]
5) Saves un-sprung weight ,,,will be the lightest available,,, Specific weights to come
6) have adapter kit available in order to mount the lightest KTM wave rotors just like we use on the original Superlite I hub[the ones designed for the HP-2]
Photos:
the Superlite II hub is basically the same as the Superlite I ,,,however it was modified slightly to allow the use of a 1/4'' thick adapter ring...this allows the mounting of the OEM disc brakes with/without ABS ring utilizing your OEM hardware
here's the new adapter plate which bolts onto the above pictured hub,,,,,notice the 3 little tabs cut out of the center they are part of a retrofit kit that will be available to mount any KTM drill pattern brake disc...they essentially replace the metal cut out for the adapter plate,,,,my research showed the KTM discs were lighter and less expensive than the BMW versions,,of course you'll have to give up the ABS ring,,,in this case ya can't have your cake and eat it too
here's the basic sequence from start to finish,,,,we beadblasted the 6061-T6 plate first to give a trick 2 tone effect to the finished product
here's how it fits together without the ABS ring,,,,i tried to create smooth ovals
and with the ABS ring
these are the matching rear hubs that can be used on any 1200 GS,GS Adv or HP-2
woody's wheel works screwed with this post 04-19-2008 at 09:43 AM
Old 04-18-2008, 09:09 PM   #66
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
MegaMoto
Hey Woody.. Any solution for a HP2 MegaMoto?
Agito ergo sum - I ride therefore I am!
http://www.adventuremoto.com.au
Your ride.. Your adventure!
SteveRed is offline   Reply With Quote
Old 04-20-2008, 03:44 AM   #67
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
steve,,,haven't a clue what kind of solutions are needed,,,or what you have in mind,,,,
woody
Ye.. I like the billet hubs but the mega (unlike the HP2 enduro) has twin discs upfront. I also like spoked rims and wanted a set of light weight wheels to put sticky rubber on for track days. I would keep the OEM rims for the road and swap out for track days or racing BEARS! BTW the wheels you guys made me for the X Challenge rock!
Old 04-20-2008, 10:23 AM   #68
Built to Last
Oddometer: 3,449
the superlite I hub is available in single AND twin disc
SteveRed,,,we have every possible configuration covered with these hubs,,,
supermoto,,,,,,street,,,,,,dual-sport,,,,,,MX,,,,,,,enduro,,,,,,paris-dakar,,,baja etc,etc in any rim combo known to man
now the mega-moto,,,,gotta double check,,,ya see,,, my brain cells don't always co-operate these days,,,i'm almost certain that 1200GS hubs/brake width/ ie the node points are identical,,,,
perhaps someone knows for sure and can chime in ,,OR i'll have an answer fro sure shortly
woody
Old 07-06-2008, 07:03 AM   #69
Built to Last
Oddometer: 3,449
Warthog's feedback and BIG muddy pics
The front wheel is a Woody's Superlite. About 4 kg lighter than stock. Just put it on 2 rides ago - the front end lifts easier, heels over faster, and also deflects a little more ... off of rocks, ruts, etc. I'm thinking about a steering damper with this wheel, as things are definitely more active in the front end. __________________
WartHog
1989 R100GS Bumble Bee
2006 HP2
Old 07-06-2008, 04:00 PM   #70
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
Hey Woody.. How's Chris? I still want a quote on a set of Rims and hubs for my R1200GSA project (18/21 conversion) But I understand if Chris is still out of action.
Regards
Steve
Old 07-06-2008, 05:40 PM   #71
Built to Last
Oddometer: 3,449
SteveRed and all who want quotes,,,,be patient,,,,
Regards
Steve
will jump on Chris first thing in the mornin,,,woody
PS,,,SORRY ALL YOU GUYS,,,,BUT CHRIS HAS BEEN FLOODED WITH INQUIRIES ,,,and HAS BEEN TRYING TO RUN THE SHOP,,WHILE I WAS AWAY TRYING TO DEAL WITH MY MOM WHO DIED LAST WEEK,,, so i've been away and that's life sometimes,,,well now i'm back and we're cleaning up the things that accidentally got over looked,,,,we won't abandon you all,,,honest....woody and the gang
woody's wheel works screwed with this post 07-07-2008 at 07:22 AM
Old 07-07-2008, 01:34 AM   #72
SteveRed
Adventure Mojo
SteveRed's Avatar
Oddometer: 2,681
Condolences
My condolences Woody. I'm not in any spectacular rush. I am hoping to have the GSA set up as a show bike for the Phillip Island Moto GP in October where I will have a stand selling Wolfman Gear to any unsuspecting Aussies So I have a couple of months. Anyay I'm heading off to the outback for some wild riding on the G650 with some other maniacs doing the 'Wild Boar Imperative' next week. Should be fun
Old 07-07-2008, 01:40 AM   #73
Warthog
TeutonicChronic
Warthog's Avatar
Oddometer: 845
So THIS is the Superlite thread...
Here is the left side, where you can see some hub ...
and here it is before the mud...
less mass = more fun...
detailed pic...that is dust on the hub, not scratches or nics. The anodization layer is still perfect after 2 horrific mud rides.
Warthog
2006 HP2
Warthog is offline   Reply With Quote
Old 07-18-2008, 10:07 PM   #74
Warthog
TeutonicChronic
Warthog's Avatar
Oddometer: 845
Laugh Front Superlite
Warthog
2006 HP2
Old 07-25-2008, 12:25 PM   #75
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 6,886
sweet
little foot is offline   Reply With Quote
Times are GMT -7.   It's 03:05 PM.
