01-31-2008, 12:17 PM
#91 |
SILENCE.....i kill you
Oddometer: 812
I just replace the carrier bearing and the trick I was told that work great was to take a couple washer that just fit on the back side of the bearing. There is a slot there where a washer will fit into and give you a surface to pound against. Then get a socket that fits as tight as possible down the back side of the drive shaft tube. Put and extension on this socket so you can get a hammer to it. Then insert washers with some grease to help hold them in place and keep pressure on the socket to also hold them in place. You can then get some pretty good wacks on the socket extension and the bearing will come right out.
I could not get any kind of device on the lip of the bearing from the back side but this washer trick worked perfect. The replacemetn went in well, bearing in freezer, heat gun on housing and it went right in.
2004 Harley Sporster 1200C, 2001 Ducati M900, 2001 Honda XR650L, 1994 Harley Heritage, 1978 Honda CB750K with sidecar, 1977 Moto Guzzi 850 LeMans, 1976 Honda CB750K, 1965 Honda 305 Dream, 1973 Norton 850 Commando, 1971 Triumph Trophy 650, 1970 Honda Trail 90, 1970 Triumph Tiger 650, 1973 Honda Z50, 1984 Yamaha Virago 1000, 1981 Honda Passport 70, 1970 Suzuki T250, 1971 Yamaha RT1 360 |
01-31-2008, 12:18 PM
#92 | |
Oddometer: 449
That is for the best, I think. They're damn cheap and easy to change since you have the beast apart. Imagine my horror when ~500 miles after my rebuild, one of the tranny bearings siezed. I had to strip the damn thing down to pull the tranny. anyways, I recall that when I pulled my carrier bearing, I attacked it from the other side with an old socket with an OD just less than the ID of the swingarm. A couple of taps with the hammer and it slid right out. jeff |
01-31-2008, 01:03 PM
#93 |
honestly
Oddometer: 2,264
finally! Ive been waiting FOREVER for someone to start talking about guzzis!
I have to pull my swing arm to replace my boot... should I plan on putting in a new swingarm bearing while I'm at it?
the carrot seed - honest country. Bulletproof VS. Bloodweiser - yamaha world super GP TT 5000 BW - 455 : BP - 100 |
01-31-2008, 01:14 PM
#94 | |
Oddometer: 449
I usually carry a split boot (has a seam that fastens with nuts and bolts) in my toolkit. I did a roadside repair with it and left it on for 15000 miles didn't have to pull anything. if you are pulling the swingarm, you might as well take the opportunity to check for play in your cardan joint, inspect and replace the swingarm and carrier bearings if necessary, and check your splines. I do not know the history of your bike. If it was a new-to-me with unknown history, I'd just go ahead and replace. |
01-31-2008, 01:18 PM
#95 | |
yet another dave
Oddometer: 360
Another thing - i've read that misalignment of the swingarm will shorten the carrier bearing life. Alignment is done by making sure the spindles are screwed in exactly equally on each side (or as exactly as a sober guy with a good metal ruler can do, anyway). |
01-31-2008, 02:09 PM
#96 | |
honestly
Oddometer: 2,264
back to the bearings - its a new-to-me bike, so I feel like replacing as much as I can afford. so how many bearings are there? Theres a motion industries near me, think they'll be able to help me if I bring in the old ones?
01-31-2008, 02:35 PM
#97 | |
yet another dave
Oddometer: 360
01-31-2008, 02:48 PM
#98 | |
Abner Snopes
Oddometer: 10,037
Most good industrial bearing supply stores can help you out quite a bit. Greg bender has a lot of the information about part numbers for the bearings on his website. I'd print out a copy of his info, and take it to the bearing place, and get them to match everything up. Thats what i did. the carrier bearing really ought to be pressed in, not hammered in. i know a lot of people have hammered them in with no problem, but I have the luxury of a friend with a machine shop, so thats how i did it. Greg's site, just in case it hasnt been posted before. http://www.thisoldtractor.com/gtbender/loopframe.htm |
01-31-2008, 03:31 PM
#99 |
honestly
Oddometer: 2,264
I read greg benders site ever night before I go to sleep.
so I should budget in the cost of a carrier bearing, is there just 1? When do I get my refund check? I just found out today about the $600, i'm going on a guzzi spending spree!!!!!
01-31-2008, 04:24 PM
#100 |
Oddometer: 812
Yes, just one carrier bearing, I bought mine from MGcycle and I think it was only like 16.
02-06-2008, 05:50 PM
#101 |
Spodely Adventurer
Oddometer: 2,993
Sucess!!!!!!!!!
Finally got the #%^!*'in' driveshaft carrier bearing out of the swingarm!
Put the swingarm in the freezer(don't tell the queen) for 6 hrs. Rigged up a puller using a 1/2" X 12" carriage bolt. Then heated the outer surface of the swingarm until it was toasty. Put a 12" crescent wrench, with 4' breaker bar on the puller nut and gave it a yank............... POW! That sucker was out 'o there. Thanks for all the helpful tips.
AMA 'MOA ECEA 'RA ARRA DHMC TCSMC: teamhammer.org "I'm a choker!" ask me how "They're ALL dirt bikes.....some work better than others"-----Harley Huey
02-06-2008, 06:30 PM
#102 | |
Any bike can go anywere
Oddometer: 1,252
The C3 mark is often just etched on the outer race as part of the bearing number, and can be missed. BTW bearing clearances go as follows, C1: precision bearings, C2: normal bearing clearances and so not marked, C3: loose clearance, used were alienment can't be guaranteed (guzzi carrier bearings) or hot running conditions, like crank shaft bearings. C1 and C3 are marked on the bearing, and as they are "Special" they usually cost more
"If a man empties his purse into his head, no man can take it away from him. An investment in knowledge always pays the best interest" Benjamin Franklin. '95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R |
02-13-2008, 04:58 PM
#103 | |
Spodely Adventurer
Oddometer: 2,993
Thanks for the clarification. Went shopping for bearings today and had to inform the counter person of my need for the C3 spec. They didn't stock it. Once I made it clear that it was for a driveshaft application, there was no argument as to my proper needs.
02-13-2008, 05:14 PM
#104 |
honestly
Oddometer: 2,264
how much did it run ya?
02-14-2008, 11:21 AM
#105 | |
Spodely Adventurer
Oddometer: 2,993
