Old 07-17-2012, 06:01 PM   #6841
leafman60
Oddometer: 1,809
Originally Posted by tenfive0 View Post
Just wondering if anyone can offer their experience with a Boost Plug and if added expense is worth the gain on an X Country?
I have a full Akra race system on my XCo with a UNI filter and removed airbox inner lid. I also run a Booster Plug. Works great. Strong, very strong linear power curve.
leafman60 is offline   Reply With Quote
Old 07-17-2012, 06:05 PM   #6842
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,364
So was the plug alone a noticeable difference? Affect mileage?
Arizona Adventure Riding Group
azgsa is offline   Reply With Quote
Old 07-17-2012, 09:12 PM   #6843
jtw000
Survivor
Oddometer: 564
I have a straight through, uncatted but legal end can, removed the airbox cover, K&N filter and Iridium spark plugs plus a little saved weight. I couldn't go any further because I needed the bike to be reliable. It's a lot better than standard, at one point I swapped bikes with a fellow traveller who was riding a Tenere and we both got off and commented how much faster and stronger the bikes were over standard, having both ridden standard versions of each other's machines and being unimpressed. He had done the same work as me, essentially.
None of this adversely effected my fuel economy either, she remains constant at delivering impressive mileage, she just breathes and burns more efficiently now so runs better.
Personally, i couldn't care less about power curves, i just want to pull my throttle open and notice a difference and i do so that makes me smile.
jtw000 is offline   Reply With Quote
Old 07-18-2012, 12:44 AM   #6844
pibyk
pibyk's Avatar
Oddometer: 22
Is anyone running a Boost Plug on their X Country? Welcoming comments go or bad, noticeable changes in performance or MPG? I apologize if this topic has been covered before and I'm beating a dead horse.
I have installed booster plug quite a while ago because I have noticed that my bike is more "user friendly" in cold weather so considering the logic of this solution (which in practice sort of cheats the system into thinking that it is colder than it really is) I thought that it is a good idea. From my perspective (I do not consider myself to be an experienced rider and I ride mostly in heavily congested city traffic) it made quite a change. In 1st and 2nd gear the bike seems to be more agile, 1st and 2nd gear seems to be quite a bit "longer" which is a welcome improvement because I do not have to change gears so often while riding in the jam or between other vehicles. Mileage ? Actually in the city traffic is higher (lower fuel consumption sometimes even by 10%). On the road I could not observe any difference.
pibyk is offline   Reply With Quote
Old 07-18-2012, 01:24 AM   #6845
jtw000
Survivor
Oddometer: 564
You're the second person I hear who says that range improved. Logically it should be the opposite as you're putting in more fuel but I guess it makes sense if the bike has a very lean burn system. Maybe we're twisting the throttle harder than we'd like on pullaways which is costing us at the pump and this helps? Interesting you've had it a while and it's been reliable. I might consider one of these myself. My bike is due for a major overhaul later this year...
Old 07-18-2012, 03:57 AM   #6846
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Originally Posted by tbarstow View Post
Looks like the X bikes will be coming back as Husky's:
http://www.cyclenews.com/articles/ne...dual-sporters/
You just cant kill that Rotax 654 engine (tho Loncin own the rights to it now) ... awesome to see BMW continuing to refine it ... 58 hp now. Same economy.
Like an XC with a steel swingarm, link suspension, steel subframe, 10% more hp and about 15 kgs heavier I estimate ... should be able to shave 5kgs off straight away by eliminating the dual exhaust and putting an aftermarket can on.
Suspension and wheels - as usual for BMW - looks to be the downside. 190mm of travel on an off road bike? And looks like a 17 inch rear wheel - tho it says 18 in the specs. Also looks like the weak BMW F650GS single front hub ... I am guessing that in keeping with recent BMW tradition the suspension will be all Sachs ... which will surely mean its even worse than the poor units on the X bikes. Oh well .... [edit - just read the specs ... it is Suchs all round]
I would like to look at transplanting the engine into an X-C ... wonder if the head - frame bolts are in the same position.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch screwed with this post 07-18-2012 at 04:12 AM
Colebatch is offline   Reply With Quote
Old 07-18-2012, 05:06 AM   #6847
leafman60
Oddometer: 1,809
I'm not sure the head is changed. Compression is up a wee-bit but that may be done with the piston. Also, cams are different.
If the head is modified, I'm sure it would bolt-on direct to the old motor.
I'm just not sure it is worth the trouble. Try the new cams and maybe mill-down the old head.
My XCo has plenty of power, as is.
Old 07-18-2012, 05:19 AM   #6848
leafman60
Oddometer: 1,809
My XCo, with the alterations I mentioned, runs better and gets good mileage. If I baby it, I get maybe 60 mpg. That rarely happens.
I recently made a trip with a friend on his bone-stock BMW 650GS single. My mileage was very similar and never more than 10 percent worse.
Doing the Booster Plug only ? I'm not sure I'd worry about doing that. My primary concern was to add a little richening after opening up the intake and exhaust.
In addition to the UNI and removal of the inner airbox lid, I also fashioned an intake scoop that routes incoming air, when underway, to the airbox.
I can't over-praise how well this little bike runs. Very strong.
Maybe the mods allow it to pull the 17T front sprocket so well. Adding that bigger sprocket was one of the best things I've done.
I very recently bought a Guzzi Stelvio that is mind-blowing but I still luv my little 650.
http://www.advrider.com/forums/showthread.php?t=804682
Old 07-18-2012, 06:25 AM   #6849
Sparqq
Oddometer: 67
Do you have more info on the weak F650GS single hub?
Sparqq is offline   Reply With Quote
Old 07-18-2012, 06:52 AM   #6850
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
...I would like to look at transplanting the engine into an X-C ... .
Personally I'd rather ride a bike with that engine first and feel the engine work. Often upgrading the number of horses with no gain at the torque side doesn't make an engine smoother. I don't care for horses (they're for track racing ) toomuch, but usable torque and power through the revs are more important to me.
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 07-19-2012, 10:35 AM   #6851
Tunngavik
Tunngavik's Avatar
Oddometer: 195
Originally Posted by snooker View Post
If it is draining that low it will not hold enough capacity. There are tons of problems here caused by this bike being very sensitive to battery voltage droop. But your problem is not that subtle, you have a crappy battery. Get a new battery!
Consider a new LiFePO4 style like from SyclBatt.com or Shorai or Ballistic, or an old school reliable Odyssey. I've posted a ridiculous amount of into on batteries at my Links Page - search for
Battery:
After trying everything I went down to the battery shop and has my old battery tested. Looks like it only put out 1 crank AMP. Bought a new battery right there, took it home, installed it, and the bike started as if brand new.
Thanks for the help guys!
Tunngavik is online now   Reply With Quote
Old 07-19-2012, 07:27 PM   #6852
scgodwin
scgodwin's Avatar
Oddometer: 53
I suppose it is about time I join this thread. I've graduated from the Dr200 I've been riding, and am picking up an '09 XCo this weekend. Pics will come when it makes it home. I'm looking forward to joining the list of proud XCountry owners!
scgodwin is online now   Reply With Quote
Old 07-19-2012, 07:40 PM   #6853
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 164
Welcome!
Welcome! It's truly amazing how diverse the places your XCo can take you! I've zigged downtown blocks, then passed semis on slab at 80mph, then within that hour climbed steep mud deep in big mountains 20 miles from other people. My XCo is my only bike, and so far I'm quite happy with that! Welcome to a great club!
Yukon Ho! is offline   Reply With Quote
Old 07-19-2012, 10:11 PM   #6854
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
I can see the ad now, dude on his GS and his gal on her XC exploring together, camped alongside an alpine lake laughing and then that look, and they disappear into the tent. OK, maybe not the last part explicitly in the commercial, only implied. "BMW, where the romance of adventure starts"
Something like this then ... (a mate of mine on his GS and his girl (Beemster) on X-Country ... both with 18-21 inch wheels)
Old 07-19-2012, 10:11 PM   #6855
jtw000
Survivor
Oddometer: 564
Diverse it true. I commuted to work on mine for a year and a half. No issues. I took it green-laning, sometimes with a pillion and up against 400 KTM and enduro bikes. No problems (I couldn't always keep up). I toured Europe with a pillion and half her house strapped to the back. No issues. I rode it across the Middle East through mud, dirt, rocks, desert, sand-storms, flooding, storms, snow, heat, traffic, motorways and everything in between. I was even hit by a car and she still just got up and got going with no real damage. I love this bike. It's not the fastest, not the most comfortable, not the best in the mud and not the sexiest but it does everything with the minimum of fuss and puts a smile on my face every time I see it.
Times are GMT -7.   It's 04:07 PM.
