Old 07-08-2013, 11:23 AM   #7801
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
Originally Posted by muddyrabbit View Post
...and while I did it with straps I do NOT recommend this procedure.
Why not? What have you done with the real MuddyRabbit??
My objective with the 5KG spring...
I know you are going to say "Yes" but... are you sure you mean 5 KG and not 15 KG or something? Does not sound like it is even in the right range to me, there must be a translation wrong or something?
It seems like a few months ago there were tons of people wanting to trade a short 2009 for a tall 2007 shock, guess I missed them all!
That's what I was thinking. google.
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 07-08-2013, 03:41 PM   #7802
dip1
Oddometer: 115
I have a short stock spring but no shock to go with it.
dip1 is offline   Reply With Quote
Old 07-08-2013, 04:55 PM   #7803
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,871
1. Do you like having fingers?
2. Actually I was reading the numbers totally wrong, this is a Hyperco 750 pound spring.
3. I have googled a lot.
muddyrabbit is offline   Reply With Quote
Old 07-08-2013, 05:39 PM   #7804
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,404
Does anybody out there have the GS 911 Diagnostic Tool ?
You might try your local BMW organization. Our local Washington DC chapter has a professional license one for members..
Most folks only buy the recreational use one. The difference between the licenses is the number of VINs. The recreational use license can read-only error codes for unlimited VINs, however, it can only reset any codes/service minders for 10VINs. To reset any data, after 10 VINs willcost more $$ to upgrade the license.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito screwed with this post 07-08-2013 at 06:12 PM
Dorito is offline   Reply With Quote
Old 07-08-2013, 06:59 PM   #7805
SchillerM
Oddometer: 202
Is that 10 ever? Can you remove VINs or reboot the thing?
SchillerM is offline   Reply With Quote
Old 07-08-2013, 07:19 PM   #7806
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,458
You can email Hexcode to reset the VINs if you buy a used GS-911.
tbarstow is online now   Reply With Quote
Old 07-09-2013, 05:40 AM   #7807
muddyrabbit
Lost Boy
Oddometer: 3,871
I'm thinking of taking an alternative approach and just getting a second shock to modify for Mala B. Since it takes me between 2-5 minutes to swap the shock (heck you don't even need to pull the rear wheel) I figure why not keep the shock I have, get a second one, and be able to change out depending on who is riding the bike for the weekend. If I can get my hands on even a blown stock shock I can rebuild it and shorten the stroke to make a low version. So anyone have any type of shock sitting around, stock, any year, OEM or whatever that they would part with?
muddyrabbit screwed with this post 07-09-2013 at 05:47 AM
Old 07-09-2013, 11:12 AM   #7808
SchillerM
Oddometer: 202
Geoffster posted an 07 stock shock awhile ago. Not sure if he still has it.
Old 07-09-2013, 11:14 AM   #7809
muddyrabbit
Lost Boy
Oddometer: 3,871
He messaged, me, I messaged him, waiting.
Old 07-09-2013, 05:18 PM   #7810
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,404
Crash Bar summary
In the market for a set of crash bars. Any options I missed?
1) OEM BMW
2) SW Motech
3) Wunderlich (Discontinued, would need to source used)
BlastOff Adventures
Old 07-09-2013, 07:22 PM   #7811
SchillerM
Oddometer: 202
1) OEM BMW
2) SW Motech
Hepco Becker
Will be installing mine this weekend (or Friday)
Matt
Old 07-10-2013, 03:32 AM   #7812
muddyrabbit
Lost Boy
Oddometer: 3,871
The HBs are pretty sweet. Mine are well tested.
Old 07-11-2013, 09:35 AM   #7813
muddyrabbit
Lost Boy
Oddometer: 3,871
So I made a deal with Geoffster to procure his 2007 shock. This will alow me to keep one shock long with the heavy spring, and shorten the other one with the light spring, and swap components depending on who is riding the bike on a particular trip.
So before I take a perfectly good 2007 tall shock and have it shortened is there anyone out there that has a 2009 shock and wants to trade?
Old 07-13-2013, 03:24 AM   #7814
leafman60
Oddometer: 1,855
15 kg, I suspect. I had John at Moto Pro re-spring mine from the stock 11 kg to a 15 kg spring. I'm about 205-210 lbs and it works great. Little pre-load when not loaded. I could even go a little higher, maybe 16.
Had to return it to him at least once to get the correct spring. His formula used in the beginning yielded a spring too weak. The static and laden sag for mine with the 15 is good.
By the way, my '09 stock shock with the stronger spring combined with the Corbin seat makes this '09 "lower" bike high enough that I cannot flat-foot it - and I am 6-2. I wouldn't want a taller shock.
For my riding, the bike works well. I've run out of things to do to it -except ride it !
leafman60 screwed with this post 07-13-2013 at 03:52 AM
leafman60 is offline   Reply With Quote
Old 07-13-2013, 05:13 PM   #7815
turbo6bar
über n00ber
Oddometer: 53
Has anyone used Cogent Dynamics to rebuild a shock or simply install a stiffer spring? I am a dirt newb and doubt I need a super duper shock, but the bottom tier Wilbers/Hyperco at $600 seems like it might be a good fire-and-forget solution.
I am 170 lbs dry. I also have a HB rack and aluminum panniers. When my girlfriend is riding with me, the rear shock bottoms very easily. The stock spring on my 07 seems far too soft. Looks like I need to consider at least a 1000 lb spring rate or at least 15 kg.
Also, I bought a pair of MX boots from CycleGear. However, I found I could not manage to use the shifter, because the boot is too stiff. I attempted to rotate the shifter up, so I would be able to get the boot under the shifter, but that's impossible due to the engine case. I've read a lot of posts in this thread, but never saw mention of problems with stiff boots. What gives?
I had to leave NM, because my eye was not healing quickly. My eye wasn't infected, but I was suffering from a pre-trip chemical burn. I'll be back in September.
Jurgen
turbo6bar is offline   Reply With Quote
Times are GMT -7.   It's 06:27 AM.
