02-10-2009, 01:11 PM
#811 | |
wannabeema
Oddometer: 168
Congrats!!!
Regret is a useless emotion. Choose wisely the first time. Own your bad choices. And move the hell on.
Kicksave screwed with this post 02-10-2009 at 02:08 PM |
02-10-2009, 01:31 PM
#812 |
Bad Kitty
Oddometer: 657
Yes, I'm guilty of not posting any pics; gotta take the time to put them in bmwxplor and then get them here.
I enjoyed that little offroad video. I'll be on a x-country in April at the 2-day enduro course in S.C. My partner should be on an F650, not sure if twin or single. Should be a hoot! I've got the Hepco-Becker pannier mounts on order and will try to get some pics when they finally arrive. My partner installed some Moose grip heater elements on the 2009 xc and ran a relay from the taillight so that they turn off with the key. He also installed a headlamp on/off switch that we used to have on our DRZ's to save juice. It is a plug and play into the back of the headlamp. When it is engaged, only the parking lamp is lit (which is quite bright), and saves a bunch of watts when running heated Gerbing gloves or heated grips and the heated vest. We got the headlight on/off switch off the shelf at a little moto shop and have not been able to find a reference online to post it up. Did about 200 miles on Sunday with grips and vest on full. Volts were reading 14.2 most of the time on my non-abs model. Averaged about 66 mpg tip-toeing through gravel-strewn backroads. The TKC's felt good in the gravel. |
02-10-2009, 02:14 PM
#813 |
wannabeema
Oddometer: 168
Great Ceasar's Ghost
66 MPG at low speeds on a trail? That's encouraging. I haven't had mine off road yet. Had planned to go last Sunday with another inmate, but weather stopped us. Still running the stock Tourance. Will switch to TKC's if I find myself going off road more often. Sounds like you had some fun.
02-10-2009, 02:26 PM
#814 |
A nation in despair
Oddometer: 21,041
I find almost no diff in mpg off road if the off road is just cruising along like down a dirt road in 3rd.
02-10-2009, 02:34 PM
#815 |
Team MGH
66mpg?
I feel like I must be doing something wrong then. Unless it's my cruising speed. While cruising down Illinois-20 home from Iowa, I'd get between 50-55mpg depending on how fast I was going. (speed limit most of the way was 65mph). I did get to take it out this last weekend. Heated grips helped
Andrew ps. tkc80's to be installed later this week
Andrew Gore Three R Plastics Economy Cycle Stop Dropping your Helmet with Helmet-Hook I use Carbon Fiber Brake Rotors. Do you? Kettle Cycles |
02-10-2009, 03:13 PM
#816 | |
adventure nerd
Oddometer: 1,247
Nice mods, by the way. |
02-10-2009, 03:21 PM
#817 | |
A nation in despair
Oddometer: 21,041
02-10-2009, 03:29 PM
#818 |
Team MGH
Unfortunately the no\low ethanol content won't jive for me. Lovely midwest, I'm guaranteed to have at least 10%. The times I was getting lower mileage, I'd be filling up right by the Illinois\Iowa border, so who knows what crazy conccotion of fuel I was getting
Andrew
02-10-2009, 03:39 PM
#819 |
wannabeema
Oddometer: 168
nice lights
I like those auxiliary lights, Andrew. They're really discreet. I'm also curious if they're a drain on the electrical system.
02-10-2009, 03:43 PM
#820 |
Team MGH
The lights are actually from Autozone. Couldn't beat the 20$ that they cost. The bar that I have on there, was just 2 pieces of aluminum that I welded together, and then bolted to the bottom of the lower triple tree. Bolted perfect into where the xChallenge fender mounts to. If I'm cruising down the road at highway speed, they're not a real big load on the system (My bike is NON-ABS). I currently do not run with both the heated grips and the lights on. I also make sure to keep an eye on the voltage as I'm cruising, to make sure it stays above 12.5-13 volts.
Andrew
02-10-2009, 11:02 PM
#821 |
adventure nerd
Oddometer: 1,247
Another photo from the NYC tag game
shot tonight
02-11-2009, 03:02 AM
#822 | |
Oddometer: 361
Hi there,
What windshield do you have? I'd like to have one that I can put on for highway trips and take off for off roading. Cheers Quote:
02-11-2009, 06:33 AM
#823 |
Team MGH
The windshield is the Spitfire Slipstreamer. I got part number: 231929 from Denniskirk.com Only downside is that I needed different mounting brackets. I just machined mine to fit the bars though. Other than that, it made long on road sections much easier on the arms and chest.
Andrew
02-11-2009, 11:51 AM
#824 | |
Oddometer: 312
Do not mistake for wisdom the fantasies of your sick mind |
02-11-2009, 12:18 PM
#825 |
Oddometer: 28
Today's Ride!
