Old 07-21-2014, 04:38 PM   #8911
madisonreid
Oddometer: 1,701
Ran into a fellow XCountry in North Bend Wa. today. He was on a low mile 09 with Caribou Side Cases and aux gas containers. His bike was significantly lower than my 08. I guess BMW heard the yell for a lower X only to discontinue shortly after. We fellow Xers agreed great Thumper .
madisonreid is offline   Reply With Quote
Old 07-26-2014, 03:15 AM   #8912
leafman60
Oddometer: 1,807
That 09 may have been so low due to the weak spring on the rear shock. I bet that dude was riding on the rubber bumper.
I'm 6-2 and installed a spring to give proper sag. The bike is tall enough that I really cannot fully flat-foot it.
leafman60 is offline   Reply With Quote
Old 07-27-2014, 08:52 AM   #8913
blaster11
Ding fries are done!
blaster11's Avatar
Oddometer: 6,922
I don't know if any of you are in need of bigger pegs but I put these on yesterday.
I have them on my other bikes and really appreciate them on those long offroad days when I do a lot of standing on the pegs. I got them from ZipTy racing.
blaster11 is offline   Reply With Quote
Old 07-27-2014, 09:29 AM   #8914
Xoliul
Oddometer: 35
Any thoughts : http://www.advrider.com/forums/showthread.php?t=997178?
Xoliul is offline   Reply With Quote
Old 07-27-2014, 10:27 AM   #8915
madisonreid
Oddometer: 1,701
so the bolt to stock correct? They seem very nice....
Old 07-27-2014, 10:53 AM   #8916
blaster11
blaster11's Avatar
Oddometer: 6,922
You have to drill 5 holes in the peg and then they bolt on, here they are installed on one of my other bikes.
Old 07-27-2014, 04:12 PM   #8917
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by turbo6bar View Post
How many 2007/2008 G650X owners out there have had to replace the clutch cover due to to wear from the release bearing? Mine was quite worn, and it only had 12k miles on it. Parts were $350, but now, my bike shifts well, and finding neutral is not such a pain in the ass.
Was chatting with a guy that has an X Challenge, and he was worried about the necessity of doing the repair for a long trip. Is the problem just isolated?
Jurgen
It is a known problem, and BMW redesigned the clutch cover for the 2009 X-Country model because of it. No one other than BMW knows how frequently routine wear-and-tear renders the parts unusable.
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 07-27-2014, 04:19 PM   #8918
Geoffster
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by Xoliul View Post
I suspect your bike overheated in the worst possible way. One of a G650X's weak points is its wiring harness--I'm not sure my overtemp light ever worked correctly.
Old 07-28-2014, 03:46 AM   #8919
Xoliul
Oddometer: 35
For now it turned out to be a bad leaking oil line from the valve to the oil tank.
However, I'm still puzzled by my temp light : it flashes three times on killswitch activation, once when I turn it off. Is this normal? Seems like nobody on the web knows!
Old 07-28-2014, 03:54 PM   #8920
icbraz
Oddometer: 9
Well, the three times flashing when you switch on the bike is normal, mine does too, but this same light does not flash at all when I switch off the bike so not sure there.
icbraz is offline   Reply With Quote
Old 07-28-2014, 10:23 PM   #8921
Dutchgit
Completely clogless
Dutchgit's Avatar
Oddometer: 413
I love orange, just not enough to buy a KTM.
Dutchgit is offline   Reply With Quote
Old 07-29-2014, 12:25 AM   #8922
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,580
Interesting. Are you talking about this line?
This pic is with the seat off, and I just noticed last week how worn and cracked this line on my '07 is (22k miles). It was worn by my riding pants rubbing on it by my knee.
If this is the same one, you just gave me the motivation to replace it.
Guess I'll use host clamps as I'm not sure how to do those special hose crimp rings that are from the factory. (anybody have any tips?)
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker screwed with this post 07-29-2014 at 12:40 AM Reason: added picture
snooker is offline   Reply With Quote
Old 07-29-2014, 05:45 AM   #8923
Xoliul
Oddometer: 35
Yeah that one. There's another guy in another thread that had it happen too. Just tuck yours behind that plastic shield and it won't wear so fast anymore.
Old 07-29-2014, 07:29 AM   #8924
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,424
Snooker - good to hear that you're back to wearing pants while riding!
Those little clamps can be put on with a set of CV Joint Boot Clamp Pliers:
http://www.napaonline.com/Catalog/Ca...955_0006402481
Sometimes, they are more of a hassle, especially when you could really use a set of 90 degree pliers.
G650X side panel tank build
tbarstow is online now   Reply With Quote
Old 07-29-2014, 08:24 AM   #8925
TymeRider
TymeRider's Avatar
Oddometer: 415
Pinch hose clamps and pliers
McMaster-Carr is another source of both the pinch clamps and the pliers to apply them.
Side clamp pliers that can be used both perpendicular and parallel to the hose: http://www.mcmaster.com/#6541k69/=t1r8k2
Clamps: Follow the link to "Pinch (Ear) Clamps" on this page: http://www.mcmaster.com/#standard-hose-clamps/=t1ra5r
Over the years I've built up a supply of a variety of diameters of the clamps. Makes for a nice professional-looking installation, and less bulky in tight locations than the worm-drive clamps.
2007 BMW G650X Challenge
2002 BMW R1150GS Adventure
TymeRider is offline   Reply With Quote
Times are GMT -7.   It's 05:18 PM.
