Old 12-06-2007, 06:35 PM   #1
jigdog OP
jigdog's Avatar
Oddometer: 813
WHat Happens When Your Brake Fluid Gets Low?
It shuts off the ABS feature on your BMW motorcycle, thats what. A K1200LT owner found this out the hard way and, according to his article he wrote in the latest issue of ON magazine, he had a crash because of it. It seems he was out riding in pouring rain and had his ABS failure light come on. Not a good time for that to happen. He got into a situation where he lowsided shortly after that. Luckily neither he nor his machine were seriously dammaged. Now whether or not having ABS was a factor could be called into question. (although he clearly thinks it was) But one fact stands out. He brought the machine to BMW and was told the ABS cut out because of low brake fluid levels. Adding brake fluid restored the ABS to functionality. He apparently checked the fluid level, but was told by the dealer there were OTHER brake fluid resevoirs added to his late in 05 model he didnt know about.
Personally I would not think that a low level brake fluid should disable the ABS feature. Its clear that the computer sensed the level and shut off the ABS. It wasnt a case of the low level itself causing the ABS not to work. If you have ABS on your BMW motorcycle you might want to get a hold of this article and read it.
jigdog is offline   Reply With Quote
Old 12-06-2007, 07:09 PM   #2
brenter
Brenter
Oddometer: 370
abs
I took a fall in my pasture about a year ago and thought it would be no big deal. Well the ground was as hard as a rock and when I hit, I hit hard ended up breaking a rib. What a stupid thing!
Anyway, the bike was on its side('05 GS) for a few seconds and when I picked it up it was flashing "brake failure". I still had brakes, but the light wouldn't go away. I took it to the dealer and he asked me if it had been on its side. I said yes and he told me the reserviour under the seat lost fluid during that spill and needed to be topped off. I was going to have to wait a long time for him to get to it that day and I live 100 miles away, so I took the tank off and did it myself. It fixed the problem.
I read that same article you are talking about in ON. The guy was lucky and smart for wearing the right clothing. The servo assist brakes are the only ones with additional reserviours, I think. I am thinking of trading to get rid of this technology, however I really like my bike. The warranty is about to run out and it is a good excuse to trade. Have a good day, Brenter.
brenter is offline   Reply With Quote
Old 12-06-2007, 07:47 PM   #3
jigdog OP
jigdog's Avatar
Oddometer: 813
Yes he made some good points about how to survive a slide after a crash. Like trying to stand up before you stop moving can break your leg(s). You will roll (causing further dammage) if the lenth of your body gets to right angles with your direction of travel.
Old 12-06-2007, 07:48 PM   #4
big adv
I need supervision
big adv's Avatar
Oddometer: 1,072
My question is, why did the fellow NOT stop to investigate the brake warning lamp on? Have not read the article sited, but would think that if a big red warning light started to flash, on any vehicle that I was operating, I would stop to investigate. Just seems like common sense to me. Red and flashing usually means danger!
Earl
BA
My dad's a TV repair man, he has an awsome set of tools. We can fix that!
big adv is offline   Reply With Quote
Old 12-06-2007, 07:55 PM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,531
Earl
Good question, his ABS light comes on indicating an ABS failure, and he keeps riding like nothing happened? Stupid to blame the bike for his bad judgement.
ABS is not designed to protect the rider from doing something dumb!
Jim
PS You can even lowside WITH ABS working. ABS doesn't work in a turn.
Old 12-06-2007, 07:57 PM   #6
ctfz1
ctfz1's Avatar
Oddometer: 1,253
Far from home with no detectable change and no descernable reason for warning (known reservoirs and brakes fine) would you call road service? Or assume false light?
ctfz1 is offline   Reply With Quote
Old 12-06-2007, 08:01 PM   #7
JimVonBaden
"Cool" Aid!
Oddometer: 53,531
I would assume the brakes are not working as normal, and slow down!
If I could feel the brakes are working normally, I would assume ABS isn't working, and might slow down a little. However, any time the bike is telling you it has a problem, and you ride it anyhow, YOU are responsible for the consequences!
Jim
Old 12-06-2007, 08:02 PM   #8
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,407
Any hydraulic brakes can and will fail if the fluid gets too low. ABS has nothing to do with it.
Karl | 2014 BMW R1200GSW Adventure | 2009 BMW G450x
Originally Posted by SchizzMan View Post
We pay Motorrad to design weight off the bike then pay TouraTech to bolt it right back on.
rideLD is offline   Reply With Quote
Old 12-06-2007, 08:43 PM   #9
jigdog OP
jigdog's Avatar
Oddometer: 813
Jim
Yes he could have stopped. But there was no ABS failure. There was only a low level of brake fluid. The machine is programmed to cut off the ABS in that situation. Its like the common low battery voltage fault. We know from experience when that happens if you shut down and restart a few moments later you get your ABS back. And it works fine. Low battery voltage after startup does not affect the ABS function. But the machine disables the ABS if it sees it.
Old 12-06-2007, 08:47 PM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 53,531
That doesn't change the fact that he crashed with a known issue with his bike, then blames the bike!
Jim
Old 12-06-2007, 09:48 PM   #11
big adv
I need supervision
big adv's Avatar
Oddometer: 1,072
Why do you think that the ABS funtion shuts down if the brake fluid is low? (cars with ABS do this too) Its because when the pump is activated and the acumulators are open the system draws alot of fluid in from the resivor, if the level is low, then air can be drawn in, causing a complete failure.
I dont quit follow on the 'no failure' thing? just because something seems to be working fine, does not mean that there is not a 'real' problem. Otherwize why have the light come on?
The next question is why was the fluid low? The resivor in question is the ones on the modulator, these are the wheel curcuits, was there a leak? Was the pads worn below the min. spec.? Lack of maint.? ( With the I-ABS II the fluid level in the upper resivors should not change) Did the rider also not read his riders manual to familurize him self with the bike he was riding?
This seems like a situation that need not have happened, barring a sudden and complete braking system failure. Seems to me that it was a rider failure.
Earl
BA
Old 12-07-2007, 03:26 AM   #12
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,644
Funnily enough, the warning light is to warn of low fluid in the servo unit.
The name - WARNING LIGHT- is a sort of clue
His decision to ignore it.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 12-07-2007, 03:38 AM   #13
Tabasco
Double Down
Tabasco's Avatar
Oddometer: 415
Just friggen wonderful; neither my 1150GS Adv Sport nor my HP2 have ABS and up until now I thought they could be ridden safely. I guess I should park them before I die.
Edit: "Now knocking wood and praying for good Juju..............I hate it when I'm stupid"
Ride a GS, it makes your butt look smaller......
Tabasco screwed with this post 12-07-2007 at 03:51 AM
Tabasco is offline   Reply With Quote
Old 12-07-2007, 06:58 AM   #14
gpothoven
whatever
gpothoven's Avatar
Oddometer: 2,129
Same thing happened to me a while ago. After dropping the bike several times over a few months, I finally got a brake failure light. Was left with residual brakes for 400 miles, until I made it to Salt Lake and they topped off my reservoirs under the tank. I knew I had 50% brakes and rode accordingly.
gpothoven is offline   Reply With Quote
Old 12-07-2007, 07:06 AM   #15
mistercindy
In a state of equilibrium
mistercindy's Avatar
Location: North Dallas 'burb in a box made of ticky tacky.
Oddometer: 2,905
That happened to me. My brake light would pop on after an hour's riding but there didn't appear to be any affect the brakes. I checked the brake fluid resevoirs and they were fine. But, the dealership said it was the low fluid level in the additional bladders or resevoirs that did it, and they fixed the problem. I'm still not sure how it happens that the level in the resevoirs looks perfect, but it somehow doesn't translate to the levels in the various bladders or resevoirs in the bike. They said that all they had to do was add fluid, but I don't get how they added fluid to those other resevoirs since the ones you're supposed to check looked perfect. It remains a mystery.
'05 R1200GS
The following statement is true.
The above statement is false.
mistercindy is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
