Old 01-16-2008, 01:11 AM   #16
mutt2jeff
Keep firing assholes!
mutt2jeff's Avatar
Oddometer: 972
I installed my SW bars last night, and the package came missing two bolts, a spacer, a washer and a nut. I was able to scrounge around my garage and make due, but I was unimpressed. It might have had something to do with the big hole in the bag that all the fasteners were in.
Think: Use scientifically tested and proven treatments for your ailments, dipshits!
The only thing Homeopathy cures is dehydration.
mutt2jeff is offline   Reply With Quote
Old 01-16-2008, 07:52 AM   #17
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,009
Call them and tell them what was missing, they might send you out a new bag of fasteners etc. Even if you dont use them those nifty aluminum spacers really come in hand on other projects.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 01-16-2008, 11:58 AM   #18
FastEddy760
Lil' Mexican on a 990s
FastEddy760's Avatar
Oddometer: 189
As DSM8 noted...
Originally Posted by DSM8
If you use them your going to have to get the right size bolt with a much larger head due to the size of the hold in the bars themselves that the bolt passes through.
I used two left over fender bushings from the high fender kit and the allen head bolts pictured next tot he bushings.
This allowed me to use the blind nut as I prefer to not drop a nut a thousand times trying to get it started. I'll contact Twisted Throttle later on and see what the resolution is. For now, I can ride, which is what my head really needs.
FastEddy760 is offline   Reply With Quote
Old 01-16-2008, 11:59 AM   #19
FastEddy760
Oddometer: 189
Ooops, the pic...
from the high fender kit...
Old 01-16-2008, 07:19 PM   #20
auslander
Meh
auslander's Avatar
Oddometer: 707
Yeah, the bolts are really not a problem, I can easily get replacements. The thing that concerns me is that the new bars, from a new "fixed" batch shipped from Germany were identical to the ones I sent back.
Does anybody have close-up pics of the bars where they pass close to the fuel cutoffs? I'm very tempted to just keep these bars as I'm not really convinced they will shear off or damage the cutoffs in a crash.
"Every normal man must be tempted at times, to spit on his hands, hoist the black flag, and begin slitting throats." - H. L. Mencken
'07 KTM 990 Adventure, '09 Kawasaki KLX250S
auslander is offline   Reply With Quote
Old 11-12-2008, 09:57 AM   #21
dirtdiver
Oddometer: 2,039
Nice post. Thanks I will use it for my install. Funny that SW Moto has such niggling quality issues.
steve
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 01-18-2009, 11:31 AM   #22
str
Oddometer: 16
I just bought and installed a new set of sw-motech crashbars to mine 990 and at first i could not get them to fit.
There was no way that the bolts nr 2 and 14 in the picture ( sw-motech manual ) was lined up when i used the spacers that was shipped with the bars. On the right side i almost made them fit with brute force but then the crashbar hit the fuel cutoff. But i made a new spacer nr 16 in the sw-motech manual and after that everything was ok no problem with the fuel cutoff and easy to install. The new spacer was 3 mm thinner then the one sent by sw-motech.
Bought my set from a German power seller on ebay for 105 euro really cheap if i compare to what i have to buy for a set here in Sweden
str is offline   Reply With Quote
Old 03-31-2014, 05:55 AM   #23
Viajantelatino
Oddometer: 3
Hey STR
Im having the same problem. I cannot make those 2 bolts to fit with those spacers that came originally...! can you send me pics of how you ended up putting it?
thanks!
Rodrigo
Viajantelatino is offline   Reply With Quote
Old 03-31-2014, 11:46 AM   #24
onewoodsrider
Oddometer: 194
You do know this thread is 5years old right?
onewoodsrider is online now   Reply With Quote
Old 04-03-2014, 06:29 AM   #25
Altego
Altego's Avatar
Oddometer: 133
Altego is offline   Reply With Quote
Times are GMT -7.   It's 01:22 PM.
