Old 05-06-2008, 07:37 AM   #136
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 872
I have been running the Tombstone for over a year now, the smoked version.
I like that it is narrow so that it is more tolerable on very hot days.
Mine is mounted more vertical than on some of the bikes pictured here.
I had to rotate my bars forward some to achieve this fit.
I am 6 feet tall and use a corbin that is 1 inch taller than stock.
For me there is no buffeting at all but it is noisy but quieter than a stock KLR screen.
Mant places sell them as a Harley Davidson fitment and come with 1 inch bar clamps, make sure you get the 7/8 clamps.
Very happy with mine.
I bought off the Slipstreamer websight for $44.95..
I also like that it gives the bike kinda of a Dakar fairing look.
When it's all said and done, More will be said.
You dont have to wish me luck for me to know that I need it.
rallyhound is offline   Reply With Quote
Old 05-06-2008, 07:41 AM   #137
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 872
Old 05-06-2008, 12:29 PM   #138
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,762
rally, i like the way you mounted it.
problem is, I ain't gots room left on my bars! did you mount the barclamps inside of the barkbuster clamps? or outside... Especially on the right grip, I have zero space... none.
which is one big reason why I will have to go with the KLR extension....
Sarah, and all.. the way RallyH has this I think, from my much tinkering, is better. The shields that sit in front of and interferes with the stock shroud are much tougher, IMHO, to get quieted down. I had a spitfire for awhile and it was ok for getting some rest from the chest pressure, but beat my head around and was noisy.... i tried a lot of diff angles and such.
and way back toward the front of this thread... the Beemer Dakar kind of setup and the Cee Bailey XRL type shield are variants of the same theme.
Originally Posted by rallyhound
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 05-06-2008, 05:46 PM   #139
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 872
Old 05-06-2008, 07:37 PM   #140
motomex
"Como ves?"
Oddometer: 59
I mounted a modified GS 1200 windshield to my DR's number plate/headlight with a bracket that runs from the handlebar clamps for support. I had to do a bunch of sanding and some cutting to the windshield to get it to look right. First the Picaso like headlight holes had to be shaped to look like one large opening, then the side wings were cut down to narrow it up a bit.
All in all it looks Ok and does a good job of keeping the wind blast off. I have not decided what farkles I will mount to the brace yet. Maybe my XM? I may have fabbed the brace a bit too long because it won't lay back as much as I think it needs. The trials continue and I am still working it out...
I'll try to post a picture tomorrow, that's if I can figure out how...
Tony
"Hey they'll get over it, if they don't, we'll always think they should have!"
motomex is offline   Reply With Quote
Old 05-07-2008, 02:13 AM   #141
greer
Oddometer: 3,820
And check this out...
http://www.thumpertalk.com/forum/sho...34#post6348234
Now I'm wondering if I should just ditch the National Cycle and go buy a big sheet of lexan.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 05-07-2008, 04:11 AM   #142
motomex
"Como ves?"
Oddometer: 59
Thumb
That home-made shield looks real good! I wonder how it would hold up in a stiff headwind? Seems like it would need some bracing....
Tony
Old 05-23-2008, 03:21 PM   #143
tt408
Oddometer: 1
I went with FZ-1 route since I had one. I used a stock sheild
http://s289.photobucket.com/albums/l...P5230005-1.jpg
tt408 is offline   Reply With Quote
Old 05-24-2008, 07:48 PM   #144
greer
Oddometer: 3,820
Hi tt,
Welcome to the forum!
Sarah
'08 DR650
Old 05-24-2008, 08:17 PM   #145
FXRocket
Phoneticide Squad
FXRocket's Avatar
Oddometer: 5,315
I had a flat piece mounted to the number plate, I found that it got in the way if I needed to duck under a limb. I almost hit my face on it one time.. But, I think I want to make one with a more "upright" angle to get it out of the riders space and move the air upward over my head at speed.
If you say "Gullible" slowly it sounds like "Oranges".
FXRocket is offline   Reply With Quote
Old 05-25-2008, 04:24 AM   #146
Lefty52
Lefty52's Avatar
Oddometer: 83
I know this has been done before but for a total of $48.00 it's worth every penny KLR650 windscreen and three nylon bolts/nuts.
2007 Moto Guzzi Breva 750
________________
If you reject the food, ignore the customs, fear the religion and avoid the people, you might better stay home. ~James Michener
Lefty52 is offline   Reply With Quote
Old 05-26-2008, 04:14 AM   #147
greer
Oddometer: 3,820
I want to try a Cee Bailey screen
If you have a used one you'd part with, please let me know. I've got some sort of windshield quest thing going on and I can't help myself. Get back to me ASAP, we leave for Alaska in less than 3 weeks. I'll put this on the DR thread and in the fleamarket, too. Thanks
Sarah
'08 DR650
Old 05-26-2008, 08:56 AM   #148
Lefty52
Lefty52's Avatar
Oddometer: 83
Sarah,
I've read some post's about the Cee Bailey flopping about in the wind due to it's height and lack of support. Just thought I'd pass that on, as it was one of the shields I'd considered.
________________
Old 05-26-2008, 10:37 AM   #149
greer
Oddometer: 3,820
Thanks Patrick,
I'd read that too, I figured I'd brace it like Stromdog's. Thanks
Sarah
'08 DR650
Old 05-27-2008, 05:53 PM   #150
SeabeeLT
Seabee
SeabeeLT's Avatar
Oddometer: 57
What a great fit. I like your shield... What model year did you use. 2001-2?
Life is Good!
'06 Suzuki DR 650
'04 Honda CBR 600rr
SeabeeLT is offline   Reply With Quote
Times are GMT -7.   It's 06:44 PM.
