Old 12-11-2007, 04:15 PM   #16
jack splash
Two Sheds
jack splash's Avatar
Oddometer: 2,352
Imo
Originally Posted by Sonymalc
What about using an IMO from TT. I know its not just a tac, but anyone using one. I have been concidering it.
Hey: The TT IMO would work. I have one I removed from my LC4 but haven't installed it yet on my X. It connects to the CDI wire on the coil.
Jack
Stay dirty my friends!
Bigfoot has a picture of me!
www.pinebarrens500.org
www.pinebarrensadventures.com
jack splash is online now   Reply With Quote
Old 12-12-2007, 11:07 AM   #17
GB
Mod Squad
GB's Avatar
Oddometer: 56,742
What kind of ignition does the X have:
is it a Capacitor Discharge Ignition (CDI) that has a positive ignition
signal to the coil.
Or is it a regular transistorized ignition or EFI with a negativ
ignition signal.
We need to know if anyone wants to add a tach.
Old 12-13-2007, 06:51 AM   #18
GB
Mod Squad
GB's Avatar
Oddometer: 56,742
Anyone know what type of ignition the X Challenge has? No mention of it in the specs on their website..
Old 07-12-2010, 01:44 PM   #19
leafman60
Oddometer: 1,855
Whatever happened on this ??? Is the ignition a CDI or what ? Can you hook-up a tach ??
leafman60 is offline   Reply With Quote
Old 07-12-2010, 04:19 PM   #20
satur9
angry black guy
satur9's Avatar
Oddometer: 534
its not cdi. most cdi bikes are carbed bikes. the ecu handles all the crap on efi. we do have twin plugs and i thought somebody somwhere on here tried hooking up a trailtech but it wouldnt act right cause of the twinspark. but i cant seem to find it.that being said. theres most likely a rpm wire off the ecu you can splice if you really really really want a tach
I drank the koolaid again.
Well, it took a lot of work to be the ass that I am
And I'm real damn sure that anyone can, equally easily f*ck you over ...(modest mouse).
satur9 screwed with this post 07-12-2010 at 04:29 PM
satur9 is offline   Reply With Quote
Old 07-12-2010, 04:23 PM   #21
MZcountryboy
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
The X-Challenge uses stick coils fired with a ~5v signal from the ECU.
I believe they both fire at the same time, but most tachs hook to the negative side of the coil for the signal, not possible with the X-C.
You don't need it, revv it up! the ECU will shut you down if you go too far.
MZcountryboy is offline   Reply With Quote
Old 07-13-2010, 11:10 PM   #22
HP2
Oddometer: 249
tach? not so easy
You can not simply connect a tachometer "to the spark plug".
The tach is working, but every few seconds he jumps to the top.
I work a long time on this problem and see at on a oscillograph.
I'm using the right spark plug. 3 cables going to the spark plugs.
+ - And impulse.
Now, the impulse filtered through a capacitor and a resistor.
and.... the Tach is working quietly.
HP2 is offline   Reply With Quote
Old 07-14-2010, 11:50 AM   #23
leafman60
Oddometer: 1,855
Okay, please tell us what type of capacitor and resistor and how to wire it.
Old 07-14-2010, 12:40 PM   #24
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,412
I have a small Daytona LCD tach that I wanted to use. You set it for the number of cylinders and wrap the pickup lead around the plug wire. I had the same set-up on an old RZ.
I do not think this design works with the XCH, the coil and spark plug /wire/ boot/ thingy are all one. No place to grab the signal.
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 07-14-2010, 01:40 PM   #25
HP2
Oddometer: 249
@Scott,
"I do not think this design works with the XCH"
absolut correct,
you have to strip the cable, direct contact with the copper
Old 07-14-2010, 01:49 PM   #26
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,475
What about the trail tech one?
tmotten is offline   Reply With Quote
Old 07-15-2010, 08:34 AM   #27
leafman60
Oddometer: 1,855
Peter, can you tell us specifics on how you made your tach function properly ? Capacitor? Resistor ?
Old 07-15-2010, 03:25 PM   #28
tmotten
tmotten's Avatar
Oddometer: 2,475
Just found out the Trail Tech one also has a non-rechargeable battery.
Old 07-16-2010, 12:34 AM   #29
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
yeah, but you can conect the trailtech unit directly to the battery.
Don't shoot me!!! is offline   Reply With Quote
Old 07-17-2010, 02:07 AM   #30
tmotten
tmotten's Avatar
Oddometer: 2,475
They didn't mention that to me. You sure on that?
Times are GMT -7.   It's 07:18 AM.
