Old 09-11-2010, 08:36 PM   #31
leafman60
Oddometer: 1,728
Any more info on connecting a tach ?
leafman60 is offline   Reply With Quote
Old 09-12-2010, 08:28 AM   #32
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
Originally Posted by tmotten
They didn't mention that to me. You sure on that?
yes, mounted two trail tech on two different bikes (exc & wrf)
great value for money
Don't shoot me!!! is offline   Reply With Quote
Old 09-12-2010, 09:00 AM   #33
leafman60
Oddometer: 1,728
I was thinking more along the lines of a standard analog, needle tach.
Old 03-02-2013, 09:35 AM   #34
Inniswhe
Oddometer: 206
So is there no simple aftermarket tach that can integrate with the g650x ignition systems?
Sent from my GT-I9100M using Tapatalk 2
Inniswhe screwed with this post 03-03-2013 at 06:31 AM
Inniswhe is offline   Reply With Quote
Old 03-02-2013, 01:57 PM   #35
Bike#8
Location: Socal=Mt. Laguna & Palomar Mtn.> Now in Idaho Yea!
Oddometer: 173
I added the trail tech tach to my XMoto. Cost was $37, wrapped around the spark plug wire. Works fine... Engine cut off occurs at 7500 rpm, other tach speeds match up vs rpm according to speed vs rpm chart.
Now: 2013 Honda CB1100
Then: BMW XMoto, Suzuki SV1000S, Honda 919, BMW XChallenge, Honda FT500, Suzuki GS650E, Yamaha XT500, Kawasaki 500 H1, Yamaha DT175, Suzuki TM125, Suzuki TS100.
Bike#8 is offline   Reply With Quote
Old 03-02-2013, 03:19 PM   #36
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,564
Would you happen to have a pic showing it mounted? Just wondering how big it is relative to the dash.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 03-03-2013, 05:32 AM   #37
Bike#8
Oddometer: 173
I'll post a pic for you on Monday.
Old 03-06-2013, 05:55 PM   #38
Bike#8
Oddometer: 173
Sorry for the delay, busy, rainy week so far.
[IMG][/IMG]
Old 03-06-2013, 06:43 PM   #39
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,564
Thanks. Looks small and light enough I could just use Dual-loc or double sided tape to mount it.
Marc
07 XChallenge
Old 03-06-2013, 07:09 PM   #40
Bike#8
Oddometer: 173
The tach came with a sticky 3M products base. But it stuck to my old bike yoke. I'll pick up some sticky sided Velcro to replace the Velcro strip wraps.
Old 09-05-2013, 02:21 AM   #41
tommyvdv
tommyvdv's Avatar
Oddometer: 416
I've been wondering if it would be hard to put something together with a couple of leds on it.
The trailtech tach looks ok, but a number changing on a tiny display doesn't seem as effective as a couple of coloured leds in ones peripheral line of sight.
Also, making your own opens up a lot of options as to how and where to incorporate it in the existing dash bracket.
Any thoughts?
tommyvdv is offline   Reply With Quote
Old 01-13-2014, 06:31 AM   #42
gafrol
Oddometer: 43
I am looking for an alternative cockpit instrument for my G650X. The original Speedo is just to big for the planned Rally cockpit setup.
I looked at Acewell, Koso and Trailtech but they don't have a plug´n play adapter kit available which fits the G650X connectors.
Basically what I need is a Oil,Water,Fuel,Battery Voltage display. Speed and mileage is available on the Tripmaster/GPS.
rgds
Roland
gafrol is offline   Reply With Quote
Old 01-13-2014, 08:43 AM   #43
MJS
MJS's Avatar
Oddometer: 1,876
rgds
Roland
Are you looking for actual readings or just idiot lights? For idiot lights you could use something like the touratech 01-030-0033-0 which has 7 LEDs. For gauge readings I think you would probably have to change the oil and temp sensors to match the gauge unit.
I have PDF of the wiring diagrams if you want to cut the harness apart. I once found the connector info but not sure I have it anymore for the 24 pin connector. You could make any adaptor to plug into the stock harness if you could find the mating connector.
Don't forget the turn signal flasher and hi-beam indicator are in the stock instrument housing if those are needed.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS screwed with this post 01-13-2014 at 08:50 AM
MJS is offline   Reply With Quote
Old 02-24-2014, 11:31 PM   #44
tommyvdv
tommyvdv's Avatar
Oddometer: 416
idiot lights like that would be fine. just some reference on the engine rpm and the redline would be fine.
what does that touratech led bar connect to?
Times are GMT -7.   It's 06:06 PM.
