Old 12-12-2007, 04:31 PM   #1
easyridin5150 OP
To young to feel this old
easyridin5150's Avatar
Oddometer: 1,675
Fork Cap Tool
Overcoming spring preload while reinstalling your fork caps can be an exercise in patience and self-control. Usually it takes to people. I made a new tool that makes replacing the caps quick and easy.
I started by putting a 24mm socket in a lath (a grinder would work) and removing the chamfer so the socket gets a better bite on the cap. Next I welded a piece of round bar to a 4" ratchet extension forming a T-handle. Now with the slider secure in a vice or in the triple trees, you simply use your arm and shoulder muscles to push the T-handle and cap into place, engaging the threads with a simple twist of the wrist.
Socket with chamfer removed
Round bar welded to extension
Finished tool
War doesn't determine who is right, it only determines who is left.
easyridin5150 is offline   Reply With Quote
Old 12-12-2007, 07:11 PM   #2
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,081
Good solution. And by sticking with that short extension for making the handle, you have better control holding it straight while pushing on the cap and spring.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 12-12-2007, 08:32 PM   #3
easyridin5150 OP
Oddometer: 1,675
Old 12-13-2007, 10:09 AM   #4
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,676
Good tip - thanks!!!!
"If you don't peer over the edge now and then, how do you know where it is?" The venerable Mr. Cob
Mista Vern is offline   Reply With Quote
Old 01-09-2008, 11:46 PM   #5
xroad
Oddometer: 774
Get around the welding requirement
When I did my springs on my Concours, I purchased a 3/8 drive sliding T-Handle. I pop in a 4" extension and then the appropriate socket.
Carpe diem quam minimum credula postero.
xroad is offline   Reply With Quote
Old 01-10-2008, 12:21 AM   #6
xroad
Oddometer: 774
Caution: Cross threading the delicate aluminum fork caps
The aluminum fork cap have very soft delicate threads. Be very careful not to cross the threads. That is the reason for the short 4" extension. (Does a shorter extension exist? )
What I did was ...
Try the cap without the spring to get a feel of how tight the thread mates together. I lubed the threads to get rid of the notchy feel making a smoother turn.
Here it goes ...
Standing straddling the bike.
Closed fist holding the T-Handle/extension/socket/forkcap.
PALM side of the hand facing forward.
Knuckle side of the hand toward the back of the bike.
Push down on the fork cap onto the top lip of the fork.
Making sure the fork cap is alligned with the fork tube axis.
Rotate COUNTER-CLOCKWISE ...
... and feel the cap riding UPWARD on the top thread.
Keep rotating until you feel the top thread runs out and ...
... "drops" or "clicks" down to the second thread.
Now I know the threads are alligned.
Start rotating CLOCKWISE.
You may have to turn your body toward the right ...
... as you reach the limit of wrist rotation.
You don't want to let go while only a small part of the thread is mated.
It was a long time ago. I think I remembered the caps were cut with double threads. That means one thread starts at one side of the cap and the second thread starts at the other side of the cap. If you concentrate, you can feel the cap drops one side and the cap is "cocked" then the other side dropped and the caps is back in alignment.
To get the most force ... bend your elbow all the way, roate arm far back so the hand and tool near the side of your body. Use your body and shoulder to press downward. Otherwise, you'll be using your arm muscle and it'll get tired very fast. Tired arm means shaking ...
Do this while the front wheel is OFF the ground. Prop up the bike at the bottom of the engine while it is on the center stand. Otherwise, the weight of the bike will compress the spring making it much more difficult to press downward.
I figured this out after screwing up the threads on one of the caps.
By the way, a welded T-Handle is better than my sliding one. I did not have any mishaps with the sliding handle but I would have felt more confident if it was welded.
Old 01-10-2008, 04:53 AM   #7
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,753
What I did was ...
Here it goes ...
Your sliding tee handle will plug directly into the socket, further reducing the leverage you've got available. If you feel you must have a welded handle, then go ahead and fix the sliding tee. e
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 01-10-2008, 08:40 AM   #8
xroad
Oddometer: 774
Deep Socket
I tried without the extension. I needed knuckle room. Perhaps a deep socket would work, but then, the socket is pretty fat.
Old 01-16-2008, 10:26 AM   #9
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Sure, use a reducer or expander on a different sized driver. Say a 3\8th t handle with a 3/8th female to 1/2" male adaper.
they actually do make 1, 1 1/2, 2" extensions, no idea why as a deep socket would do the same.
I have this by Calvan tools, simply awesome to have around.
expander, reducer, 2" extension and finger driver all in one.
Oh yea, they do make non sliding T handles, check MC tool companies (MSR, Motion Pro, Pit Posse, e.t.c.)
HaChayalBoded is offline   Reply With Quote
Times are GMT -7.   It's 11:56 AM.
