Old 12-20-2007, 08:29 AM   #16
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,347
Didnt even think of taking video... I'll have to work on that. Heres some more info on the how-to some of you have requested.
Parts required:
2- U-bolts
1- Old Ski (preferably with a good wear bar)
1ft- Angle iron
10ft?- Chain
1- Bolt and nylock nut
The ski is just an old ski off of a snowmobile- I think it came off a '70s ski-doo or a john deere liquafire. Mighta just come from the scrap yard. I removed the leaf springs leaving basically a flat ski. Went down to the hardware store and bought 2 u-bolts complete with nuts and metal straps that would fit over the tire. Cut the angle iron to fit over the back part of the u-bolt, line up where you want the wheel to sit on the ski, and weld the angle iron over the bolt like so:
I cut slots in the angle iron so it would be longer. I was worried about not having enough contact where the welds were because of the trough in the shape of the ski.
I still need to trim some of the threads off of my u-bolts, but I can get the ski on in about 5 minutes.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 12-20-2007, 08:33 AM   #17
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,347
Couple more pics:
-Charles De Mar.
Old 12-20-2007, 10:06 AM   #18
Zerodog
Oddometer: 1,233
Cool. Nice job. Even if it sort of sucks it looks fun.
That is desperation inspiring invention!!
Zerodog is offline   Reply With Quote
Old 12-20-2007, 12:46 PM   #19
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,571
Okay, so you're not totally retarded, just mildly insane. Methinks the cops up here would not want to go near the paper work that thing would gererate! I so have to try that!
skysailor is offline   Reply With Quote
Old 01-03-2008, 03:59 PM   #20
Waspswatter
Oddometer: 2
I had this exact same idea last week, a fellow SMjunkie led me to this thread.
Dorkpunch, what is the handling like? Does it countersteer just like normal? Is the ski able turn without sliding out? Now, how about some videos?
I give this thread 5 stars
(edit) My first post!
Waspswatter is offline   Reply With Quote
Old 01-03-2008, 05:18 PM   #21
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
dude you are one sick individual! I love it
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 01-03-2008, 05:36 PM   #22
Gusgus
Gusgus's Avatar
Oddometer: 5,308
Originally Posted by dorkpunch
the front brake works great in that situation. I've been meaning to put a bungee cord from the ski loop to the triple clamps but i've never had a problem with it on this bike or when I had it on my XL, OR the version I had on my mountain bike.
The bungee is a great idea, but do it man. The result of a spin of the ski is catastrophic!
I install ski's on aircraft, the limit cables are priceless. Reason? When the ski leave the ground the forward bungee pulls the nose up and the tail becomes the first part to contact the ground. The forward cable (along with the bungee) limits the nose from digging in, and the tail from allowing berms into the frame of the craft/bike.
Limit cables...use them!
Gusgus is offline   Reply With Quote
Old 01-04-2008, 05:43 AM   #23
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,744
I don't think the ski would grab anything for steering purposes on the street, Unless I'm wrong, you will need some snow or ice for it to work.
Also. Why not zip tie the front brake under pressure, that will hold the ski in place.
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 01-04-2008, 08:25 AM   #24
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,347
You cant just zip tie the front brake on. The ski needs to be able to move freely up and down while your moving, ESPECIALLY when your turning. If you have the bike on a flat surface, lean it over a bit, and turn the handlebars while watching the ski, the ski tip actually comes "up". the ski is still flat on the ground, but the wheel will turn as the handle bars turn. Clear as mud? If you were to lock the brake on, basically the back of the ski would be coming off of the ground any time you tried to turn. Plus, it would lawn dart into any obstacle you hit- like the pic of me going over the snow pile, the ski followed the contour of the hill instead of stabbing it.
As far a handling goes: Yes, you need snow. It works best in between 1-6" of snow. Riding in hardpack and ice is a real handful but do-able. It would probably be a non-issue if I had a better wear bar underneath the ski that actually had the skags (thats what we always called em, not sure what the real term is- the sharp carbide parts on the wear bar). The problem with ice/hardpack is the ski is hard to turn and therefore its hard to keep your balance- OR the ski is to easy to turn and will slide out. Thats also what happens when you hit pavement...
When your in snow though, its pretty much impossible to get the front end to slide out. Its really a trip to ride, the front just sticks, the back end slides out and you kinda steer with the throttle by how far you let the back hang out. Havent ridden it a ton on the KTM but we put several hours on the exact same ski when it was attached to my XL350, and it would plow through deep (ie-up to the tank feet on the handlebars deep) snow, just not fast.
-Charles De Mar.
Old 01-04-2008, 05:19 PM   #25
Ted West
n00b-ish
Ted West's Avatar
Oddometer: 485
Interesting post from a most flinty citizen
-Ted West
'06 Husqvarna TE250
'82 Husqvarna 430WR
'81 Husqvarna 250XC
Ted West is offline   Reply With Quote
Old 01-04-2008, 05:21 PM   #26
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,215
This advice will keep you out of the hospital!
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 03-03-2013, 01:08 PM   #27
Waspswatter
Oddometer: 2
Here's my version! (inspired by yours)
http://www.supermotojunkie.com/showt...=1#post1546763
Old 03-03-2013, 08:13 PM   #28
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,347
Awesome! Ain't it fun to slide the back end out like that!? Thanks for sharing. Need to get mine back out someday, but *thankfully* the snow is disappearing quick around here!
-Charles De Mar.
Times are GMT -7.   It's 12:11 PM.
