Old 02-14-2008, 10:33 AM   #196
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
Originally Posted by Nixels
Didja get the frame off to the painter's? Or is that spaghetti in the headlamp slowing you down a bit?
That headlight shell skeers me.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 02-14-2008, 11:57 AM   #197
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,964
Were the VW style fuses still mounted in the headlight bucket in 84? If so, I'd suggest upgrading them with some 8 or 10 amp micro breakers that you can flush mount on the fairing. When I had my 76, I was always skeered I'd blow a fuse at night and getting to it is no trivial task.
Mark
If I agreed with you, we'd both be wrong.
Eurobiker screwed with this post 02-14-2008 at 12:02 PM
Eurobiker is offline   Reply With Quote
Old 02-14-2008, 12:44 PM   #198
pfestus1
Slasher
pfestus1's Avatar
Oddometer: 606
I know what you mean! Hows this one make you feel
Its all out of there, but it'll have to go back in.
Hank Pfister
Copper Hill, VA
2007 R1200GS, 1973 R75/5/Dnepr, 1984 R100RS/Motovation,
Gotta get my post count up
pfestus1 is offline   Reply With Quote
Old 02-14-2008, 02:10 PM   #199
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
I think I"m going to try and leave the main harness in place and just remove what I need to get the bike apart. I think I can leave the harness for the dash in place, along with the main one, but I'm not sure about the switch clusters yet.
IMHO.
Old 02-14-2008, 02:23 PM   #200
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Hi Dave ,
Nice progress so far!
I don't remember the brand, maybe Luftmeister?,
but back in the "day", my R75/6 had a remote
fuse holder with two 15 amp AGC fuses that mounted on the gauge bezel.
It was a necessity when using an aftermarket fairing (Luftmeister, Vetter
Vesco, etc.) so you could change the occassional fried fuse.
Was a rather simple set up that could be duplicated quite easily and even
hidden if you didn't want to see it.
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 02-14-2008, 02:30 PM   #201
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
Originally Posted by deerslayR
Hi Dave ,
I'm just going to leave this bike as stock as possible, I think. It's a nice afternoon rider, not a daily rider, so I'm not real concerned about getting stuck somewhere with a busted fuse.
That's what cell phones, a wife, ramp and pickup truck are for, right?
IMHO.
Old 02-14-2008, 05:36 PM   #202
kixtand
kixtand's Avatar
Oddometer: 2,154
You might also want to look at replacing the grommets and such for the wiring that goes into the headlight bucket while you're down this far, some of which can be done w/out removing all of the wires first, if memory serves.
Also, don't be intimidated by the wiring and such in the headlight bucket. If you dig into I think you'll find that it is MUCH simpler than you thought, and really broken down into pieces that can be addressed one at a time (i.e left switch, right switch, main harness, etc...) If you've got thw wiring diagram putting it back together should be a snap, even if you forget things along the way...
I wish I was coming to the left coast soon, I'd pop up your way and we'd be through that dude in two beers or less .
Bacon...
it makes everything better.
kixtand is offline   Reply With Quote
Old 02-14-2008, 06:21 PM   #203
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
It'll be Miles Davis on the box, a pen and paper for notes and a camera to document it while I sit on my little stool and start pulling it apart.
IMHO.
Old 02-14-2008, 08:14 PM   #204
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Mrs. kbasa towing inc.
Tina could make some serious jingle with all the old skool rides in your 'hood.
AMA 'MOA
ECEA 'RA
ARRA DHMC
Old 02-14-2008, 11:28 PM   #205
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
Headlight bucket rat's nest...
Actually, that mess in the headlight looks much worse than it really is. Like I said before, a good grippy set of forceps - those locking medical pliers/tweasers things work wonders getting the connections apart and putting them back together.
Secondly, the wires and connections are color coded: the brown wires go to the brown section of the circuit board, the blue with yellow stripe go to the blue section with the yellow stripe, and so on. The only real tricky part is routing the wiring so it wraps around the 'outside' of the bucket rather than crossing over the center area where the headlight has to fit.
Thirdly, there are some unmarked connections, but don't sweat it - they're easy if you just follow these steps: keep notes on a note pad, draw out the device with it's connections and mark which wires go where. There are about three of these - the ignition switch, headlight relay, and the flasher unit.
I forgot, there's one other thing: the wires need to be removed from a connector - forgot what it is now, but I seem to recall it being a black, L shaped thing with about four connections. The wires need to be removed from it, but there's a trick. There's a little tab that sticks out when the wire was pushed into the connection. It's a little barb that won't let the wire back out. Insert a very small pick from the business end of the connection to flatten it back, while gently pulling on the wire. When the barb is sufficiently back the wire will pull out.
One other thing to know is that all of the German parts have little numbers next to the terminals. Those numbers are usually listed in the wiring diagram, so you can figure out what goes where in case you forgot to fill out the diagram. Be sure to draw the diagram with distinct markings so you won't get mixed up and turn things upside down. Easy to do.
Old 02-15-2008, 09:39 AM   #206
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
Thank you so much.
I got a call from Ray and the striper this morning. Since I've gone with a painted rear fender instead of the stock black, they wanted to know how to stripe it. It's going to be a replica of how the front is striped and should look terrific.
It must look great because both the striper and Ray were telling me it came out beautifully.
Guess I better get the frame done. The bodywork's going to be here before I know it!
IMHO.
Old 02-15-2008, 09:39 AM   #207
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
Now that I think of it, she's rescued my neighbor when the electrics on his Triumph croaked, brought me gas and done a bunch of other little rescues.
IMHO.
Old 02-15-2008, 09:45 AM   #208
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,111
you sure you dont need to go down into the motor
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 02-15-2008, 10:39 AM   #209
Team Dennis
Certified Troublemaker
Team Dennis's Avatar
Oddometer: 4,539
Great job so far Dave. Can't wait to see the pinstriping.
Be careful how far you go with that project. You might end up parking it inside as art.
P.S. What bike is that freshly painted red frame from?
Team Dennis is online now   Reply With Quote
Old 02-15-2008, 10:46 AM   #210
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 67,717
Highly doubtful, man. I'm holding a spot for a Honda.
The red frame and headlight bucket are from an R69S that Ray's doing. The color is Granada Red. I'm very pleased with my R60, but if I could have had it in that red color, I would have been even more pleased.
IMHO.
Times are GMT -7.   It's 03:44 PM.
