Old 10-08-2008, 07:58 AM   #691
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 69,142
Originally Posted by Tbone
FNG would be so proud !!! Great job Dave !
I want to find a local pinstriper to add a few letters to the rear fender under the seat.
F.N.G.
G.V.M.
#535
Small, only visible when the seat's open.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 10-08-2008, 09:03 AM   #692
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,155
Originally Posted by kbasa
Current efforts are focused on finding a new left side mirror. All BMW seems to have is the old style R90S type. I want to put the lollipop style back on. I've got a good right one of those and a good left R90S style.
Are you talking about the plastic ones? You won't find them in the 90S or 100S parts fiche - those came on the R11RS or one of those. There are enough variations in the mounts that I'd take it to the dealer and have them match it.
Wirespokes is online now   Reply With Quote
Old 10-08-2008, 10:04 AM   #693
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 69,142
Yep. That's what I'm looking for.
IMHO.
Old 10-08-2008, 10:12 AM   #694
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
I like bikes.
snip
I'm going to try and get the spacers sorted this morning so the rear tire stops rubbing on the swingarm.
My imagination isn't latching on to this.....if the swingarm is even somewhat centered, and the tranny output is bolted up reasonably centered.... how can the wheel be rubbing (over to one side or the other, I assume?)
Do you have the correct axle in place (front and back are different lenths iirc?).... Do you have the "top hat" in place on the left side of the wheel, and the axle-nut correctly torqued?
Please esplain!!!!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 10-08-2008, 11:03 AM   #695
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 69,142
Please esplain!!!!
The original spec tire size (4.00), is somewhat narrower than the 120 section tire I'm using now. I bought a new, slightly wider top hat from the dealer and need to get it installed. It should move the tire over the smidge I need.
I also think I slightly expanded the swingarm when I removed the old driveshaft with my press. It's only enough to rub on the lettering on the tire and not enough to actually wear it down.
IMHO.
Old 10-08-2008, 11:06 AM   #696
phactory
Motorcycle Rescue
phactory's Avatar
Oddometer: 438
bpeckm,
It is rubbing because the motorcycle was designed to run a 4.00-18 rear tire, not the 120/80-18 Dave is running. You can change the inside spacer from 36314038142 sleeve (9,2MM) to 36312301737 sleeve (10,7MM) but that only gives you 1.5mm (0.060") more clearance.
PhacK
Please esplain!!!!
"There are only two true sports: bullfighting and auto racing. The rest are simply games," Ernest Hemingway
phactory is offline   Reply With Quote
Old 10-08-2008, 04:36 PM   #697
MikeyT
Krusty Olde Pharte™
MikeyT's Avatar
Oddometer: 5,353
F.N.G.
G.V.M.
#535
Excuse my ignorance, Dave, but what's the significance of the #535 with Greg's initials?
MikeyT
99 Shadow Spirit 1100
"Non Illegitimi Carborundum"
MikeyT is online now   Reply With Quote
Old 10-08-2008, 04:52 PM   #698
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 69,142
His race number.
IMHO.
Old 10-08-2008, 04:57 PM   #699
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,709
F.N.G.
G.V.M.
#535
Nice touch.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 10-08-2008, 05:58 PM   #700
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
Originally Posted by phactory
bpeckm,
PhacK
Thanks.... I am thinking that the entire assembly "starts" on the right side, i.e. the right side is fixed by the hub/axle assembly as it is pulled to the right by the tophat/axle-shoulder on the left side. Thus, I could not imagine how to increase that clearance....But, like you say, the additional clearance would be minimal... Any additional clearance would require a shim ( or ??) to keep the wheel hub from being pulled as far to the right. But then that would bring up issues with engagement of final drive gears, etc....
I ran into an "a-ha" when I reassembled my final drive to the swingarm by doing it wrong initially, and then realizing that the assembly could be correctly aligned by installing the axle itself, which must be in perfect alignment from the left side (fixed) swingarm to the right side (which is the final drive itself), all assembled PRIOR to cinching of the four bolts bringing the driveshaft housing and final drive together. All very cleverly designed and engineered to be pretty much self aligning IF used in conjunction with each other.....Elegantly simple.
Loving the 80ST
Old 10-09-2008, 07:30 AM   #701
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,307
F.N.G.
G.V.M.
#535
Tbone is offline   Reply With Quote
Old 10-09-2008, 08:30 AM   #702
phactory
Motorcycle Rescue
phactory's Avatar
Oddometer: 438
Dave,
I might still have one of the NFG GVM # 535 decals left. i will have to look.
PhacK
Old 10-09-2008, 04:15 PM   #703
MikeyT
Krusty Olde Pharte™
MikeyT's Avatar
Oddometer: 5,353
His race number.
Thanks. I shudda knew.
MikeyT
Old 10-09-2008, 04:48 PM   #704
kbasa OP
Colnago!
kbasa's Avatar
Oddometer: 69,142
Dave,
PhacK
I've still got my credential from 2000 WSBK, though I'm reluctant to peel it off.
IMHO.
Old 10-10-2008, 07:53 AM   #705
phactory
Motorcycle Rescue
phactory's Avatar
Oddometer: 438
Dave,
If I have one left it will be new and unused. I think I ended up with a bunch from the GVM Memorial Ride in 2000. Let me look and if I do have one I will mail it out to you.
PhacK
Times are GMT -7.   It's 07:51 PM.
