01-16-2008, 10:37 AM
#121 | |
Guest
Oddometer: n/a
Wiring
The vast majority of wires connect to the board according to the colored sections. Take pictures of how the harnesses run around the headstock and frame. Then send them to me because I forgot that step. Happy wrenching... |
01-16-2008, 09:01 PM
#122 |
Oddometer: 102
Steve-0: happy to see that re-size thing worked out!
As you were fellah's. Oh, I sent this to some of the afflicted. http://home.comcast.net/~oldsport/R9...ory/index.html Edit: Just read the whole thread. Thank you for adding a new obtuse reference to my lexicon. I'll now be wondering if "scope creep" is a proct-o-logical term. You're doing important work there Dave! Your karmic score is on the rise. itchybro screwed with this post 01-16-2008 at 09:27 PM |
01-18-2008, 10:10 AM
#123 |
Guest
Oddometer: n/a
Weekend Progress
What's on tap for the R100 this weekend Dave?
01-18-2008, 10:15 AM
#124 | |
Gettin' there.
Oddometer: 10,955
. "Origin is right here, right now," said Klay. GTomic replied, "Many myth the point." |
01-18-2008, 01:20 PM
#125 | |
Tinaversal
Next weekend is Death Valley, so I won't get anything done that weekend. This weekend, I also want to fashion some kind of stand to hold the motor. In fact, it might be easier if I just get it to a point where the motor can come out before I take the wheels and stuff off, huh? I mean, right now, I've got a centerstand and wheels to hold the whole mess up. *starts thinking about engine removal recruits*
IMHO. Fuck Cancer. Ride bikes. - dave + tina |
01-18-2008, 02:13 PM
#126 | |
Spudly Adventurer
Oddometer: 3,253
![]() Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. |
01-18-2008, 04:22 PM
#127 | |
Tinaversal
01-18-2008, 06:27 PM
#128 | |
Spodely Adventurer
Oddometer: 2,991
Have fun at DVD. Kick Curry in the slats for me.
AMA 'MOA ECEA 'RA ARRA DHMC TCSMC: teamhammer.org "I'm a choker!" ask me how "They're ALL dirt bikes.....some work better than others"-----Harley Huey
01-18-2008, 06:43 PM
#129 |
anytime now
Oddometer: 2,352
Great thread, I too have a last edition CS, for years it sat languishing with fairly low miles underneath a friend's carport(he has a garage with just junk in it?)Every six months or so for maybe five years I ask if he wants to sell it. The answer is always no. One spring day on my way to buy an XLCR I run into my friend who coincidently was permantly laid off after 33 years the day before.(financially he was fine it was intial shock)He mentions he might want to sell the CS, I reach in my pocket whip out the money for the XLCR...Sold! It'spart of the permanent collection now, still want an XLCR
01-18-2008, 07:38 PM
#130 | |
Tinaversal
More progress tomorrow.
01-19-2008, 12:51 PM
#131 | |
Guest
Oddometer: n/a
Motor stand
You will need a strong back to help if you don't remove the top end. B and I were able to remove my motor but the top end was off. |
01-19-2008, 05:01 PM
#132 | |
Still a stupid tire guy
Oddometer: 7,270
Feh. All you really need is good food and beer for a guy like me who is 6'2" and 270 lbs. I swapped out my R90 motor a few years back by myself in about 4 hours. It's not an easy thing to do solo, and I'm probably damned lucky to not have caught any fingers during the process.Look at buying one of those lifts that Harbor Freight and Sears sell that go under the enigne of the bike. You can rig up some more padding for the cylinders, and there are tie-down points at the corners. When you're done with the Airhead you'll have a nice little lift for miscellaneous bike chores. http://www.harborfreight.com/cpi/cta...temnumber=2792 http://www.sears.com/shc/s/p_10153_12605_00950190000P
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
01-21-2008, 06:54 AM
#133 |
Tinaversal
OK, so I get the shaft drained, get the final drive off and slide back the cover to start working on the driveshaft bolts. I put the bike in 5th gear and start to loosen one of the bolts.
And the shaft just turns around as nice as can be. Suggestions? Put the final drive back on so I can apply rear brake to hold the bolts tight?
01-21-2008, 07:07 AM
#134 | |
Slasher
I did the zact same thing! LOL....almost...Only I hadn't removed the final drive, but I had removed the rear wheel. All I had to do was put the rear wheel back on, and was able to hold onto it to break the shaft nuts loose. Good luck, keep up the good work.....
Hank Pfister Copper Hill, VA 2007 R1200GS, 1973 R5/5/Dnepr, 1984 R100RS/Motovation, Gotta get my post count up
01-21-2008, 07:24 AM
#135 | |
Oddometer: 2,077
Bacon... it makes everything better. |
