Old 12-20-2010, 06:27 PM   #91
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,233
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 12-20-2010, 06:57 PM   #92
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,435
Originally Posted by Dorzok View Post
about stinkin' time!! gonna be able to lace them to tubeless hoops? and you offering them up for both the Vee and Wee?
yeah i know,,,there's only so much of us to go around for all the requests we get....
FYI,,these should be able to use the Aprillia CapoNord 2.5x19 and 4 x17 tubeless hoops,,,,we can still do the sealing techniques for other safety beaded rims,,,,
and yes there will be front hubs for the 650 and the 1000.....the one pictured is for the 1000.
the rear wheels are interchangeable according to the micro-fiche...
will keep ya posted
w
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 01-17-2011 at 05:49 PM
Old 01-13-2011, 04:13 PM   #93
Built to Last
Oddometer: 3,435
new hubs are here!!!!for your wire Vstrom ,,here's the front
here ya go ,,hot off the CNC n anodizing tank,,,''this 1000 front in its final configuration...''
pass the word,,,,rear should be ready shortly,,,,w
woody's wheel works screwed with this post 01-17-2011 at 05:48 PM
Old 01-13-2011, 04:22 PM   #94
DNTOUCH
Need more time to ride.
DNTOUCH's Avatar
Oddometer: 785
Subscribed..
I feel the wallet getting lighter already.
'08 DL1000 (with some stuff
DNTOUCH is offline   Reply With Quote
Old 01-17-2011, 05:47 PM   #95
Built to Last
Oddometer: 3,435
update on the billet V-strom hubs..
so i just got the word form RAD... the black hub pictured is available and it's for the 1000 Vstrom ,,the 650 is a bit narrower and sport sa speedo drive ...
we were under the assumption the rear wheels were the same because my kid sez they have the same part number ..RAD doesn't think so..we are resolving it ..the rest of the hubs should be done within the month...
better late than never.???...BETTER RIGHT THAN WRONG!!!
tis winter and that's when many of the machine shops get a lil breather and have the time to do those special projects like this...
at times i wish i could just solve every request,,,and theirs only so much time,,,i have to be realistic /pragmatic in how we allocate it ,,,BWOE if i have a hundred times as many requests for BMW /KTM products it behooves me to keep my troopies engaged in cost effective investments of our time and energies ,,,,i'm sure most of you can relate to this.
thanks for understanding,,,
woody
Old 01-18-2011, 12:53 PM   #96
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 633
I was starting to save up for the new Tiger when you resurrected hope for decent tires for my Wee. Keep us posted.
What a lovely bunch of coconuts.
Better to be a fast mule than a slow race horse.
hahmule is offline   Reply With Quote
Old 02-13-2011, 04:57 PM   #97
Built to Last
Oddometer: 3,435
new rear hub for 650/1000 V-strom arrived..
it's here,,,looks solid,,,is compatible with your discs and sprocket carrier....your choice of anodized color
pics below
woody
woody's wheel works screwed with this post 02-16-2011 at 10:12 AM
Old 02-13-2011, 04:58 PM   #98
Ride_There
Will ride for bacon.
Ride_There's Avatar
Oddometer: 3,121
Ride_There is offline   Reply With Quote
Old 02-15-2011, 04:26 PM   #99
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,289
pics will follow shortly
woody
Woody, Are the rear hubs finished for the 650 yet? I am building a DL/DS and sure would like to go wire wheel in the rear to complement the 19 wire wheel in the front. Sending an email to the shop.
Thanks,
Assfault
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 02-16-2011, 10:29 PM   #100
Built to Last
Oddometer: 3,435
here ya go..billet V-Strom hubs!!!!
Thanks,
Assfault
so ya can finish your project,,,i'm told the 650 and 1000 rear are interchangeable,,,made to use your oem disc and sprocket carrier
woody
Old 02-27-2011, 06:34 AM   #101
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,289
I am awaiting a call back to place my order for a set for my project DL.
Anybody have a preferance between a 17 or 18 rear rim size?
Pro's - Con's ?
Woody, what would you use?
Thanks,
Assfault
Old 02-27-2011, 08:58 AM   #102
Built to Last
Oddometer: 3,435
Pro's - Con's ?
Thanks,
Assfault
sorry assfault,,,it's been another week from hell,,,we didn't get the final $$$ number yet from RAD if the total price for an F800GS hub which is similar and comes with sprocket carrier and dampeners is $549, then i'd guess ya better set at least $400-450 aside for this hub,,,remember it was designed to recycle your oem sprocket carrier and dampeners.
i'll take your order any time,,,i have no idea if the taller 140/80x18 tire will fit ,,it is at least 2''bigger in diameter so it will make your gearing taller...you'll need to drop the CS at least one tooth or add 3 more in the rear
if you are doing mostly fire roads and lot's of slab work,,,, well the 4.25x17 will be fine.... if more off-road, than my recommendation is the slightly narrower 3.5x17,,,pulls the sidewalls in a bit ,,,better traction cornering in the dirt and less prone to getting bent,,,same old story
i have one in stock,,, black as pictured....what color rim ya want???
holler woody
Old 03-03-2011, 04:34 PM   #103
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,289
Order placed, cant wait to see how they come out.
Bump to the top to get the word out.
Wire V-strom wheels are here.
Should see mine in a week or two.
Old 03-06-2011, 04:46 AM   #104
Sebastian_v650
Oddometer: 3
Is there also an ABS version? If not, I think it would be an very easy modification to the hubs. Only thing that would change is (maybe) the hole circle for front brake disks and some additional holes for ABS sensor disk. On rear hub, Brake disk is unchanged, only the senor disk holes should be added.
I can provide dimensions from my DL650AK7 if somebody is interested.
Sebastian_v650 is offline   Reply With Quote
Old 03-06-2011, 06:41 AM   #105
Built to Last
Oddometer: 3,435
i'm all ears
are there 2 versions of these bikes???..perhaps the loaner bike/wheels we acquired were non ABS
yes i am interested..and thank you''for sharing''
woody
Times are GMT -7.   It's 11:53 AM.
