Old 03-29-2013, 09:33 PM   #31
Droptarotter
Oddometer: 1,236
If you solder electrical connectors, only use rosin core solder........if you use acid core for electrical, it will eat any connections you have made.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 08-11-2013, 01:50 PM   #32
zoltan
zoltan's Avatar
Oddometer: 250
Alright, I'm back again.
I am replacing the volt regulators (2) on my 97 ktm lc4 400 again due to over voltage issues at tail and head light. i had replaced them just last fall too.
A guy at the shop asked me if they were directly grounded to the frame through the mounting bolts which I thought they were, but it turns out they are not.
This is the factory mounting spot and there was no jumper to frame when I took off the oem reg.s.
Could this be a reason I have been going thru bulbs and regs?
zoltan is offline   Reply With Quote
Times are GMT -7.   It's 03:08 PM.
