Old 12-24-2007, 03:53 PM   #1
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
neoprene fork gaiter?
Is there an easy way to put on neoprene fork gaiters on a 640adv?
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 12-24-2007, 03:59 PM   #2
reconsmr
Oddometer: 1,522
One company made them with velcro, they simply wrap around the tubes, no disassembly, forget who it was,,,, Easier to clean too, though I'd guess they allow a little more dirt in than the regular style.
reconsmr is offline   Reply With Quote
Old 12-24-2007, 04:01 PM   #3
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,321
No there isnt.. unless you got the velcro kind
remove wheel ,brake caliper(s) speedo sensor.. loosen triple clamp bolts, drop one leg at the time slide em on from the top down
'99 Road king
'09 XR1200
Laromonster is online now   Reply With Quote
Old 12-24-2007, 04:03 PM   #4
reconsmr
Oddometer: 1,522
found them, fork skins available through parts unlimited from what I see
Protect expensive suspension components from rocks, mud, sand, and all other types of roost
  • Made of flexible 2mm neoprene and held on by industrial-grade hook-and-loop material
  • Easy to install
  • Fork skins are sold in sets of four
  • Seal skins are sold in pairs
  • For 125cc or larger
Old 12-24-2007, 05:04 PM   #5
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Is it worth it?
Do the gaiters really help keep the forks? Is it worth using them?
Old 12-24-2007, 05:24 PM   #6
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
ABSOFUCKINGLUTELY
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 12-24-2007, 05:54 PM   #7
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Thanks, theyre going on tomorrow...
Merry Christmas all...
Old 12-24-2007, 07:13 PM   #8
GB
Mod Squad
GB's Avatar
Oddometer: 56,561
Touratech sells gaiters with velcro, so you just wrap them around the forks and you're done.
Old 12-24-2007, 08:16 PM   #9
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Thanks again. Just went and put on the KTM gatiers. Took about forty minutes. Nothin like working on your bike Christmas eve to relax... Goin for a chilly ride in the morning. Can't wait...
Old 12-24-2007, 10:43 PM   #10
bmwktmbill
Traveler
Oddometer: 5,143
Don't install them full length, they will bind on the lower rock guards and limit suspension travel, yes they are worth it even short, also pry off the dust seals and pack the area under them with grease and put the dust seal back in place.
Use a heat gun or hair drier to heat the dust seals to help get them loose.
This is all per Creeper who I learned the trick from. It works in my book.
You will experience a fine smear of grease on the tubes but don't worry, it doesn't hurt. This system saw me from Wisconsin to Germany via the Gobi desert in Mongolia and all of Russia last summer, probably 7-8K of dirt, rock, sand , gravel, plus plenty of broken pavement and no seal or tube failures.
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 12-25-2007, 04:39 AM   #11
gybeman
gybeman's Avatar
Oddometer: 632
Yes to that... I had a pair of full length KTM ones on mine but when compressed and all the air comes out of them they create enough of their own suction to prevent the forks from fully extending. I cut them in half and made 2 pairs of shorties. Work great.
gybeman is online now   Reply With Quote
Old 12-25-2007, 05:07 AM   #12
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Thanks for that info. Ill be sure to cut them down.
Old 12-25-2007, 05:14 AM   #13
djchan
djchan's Avatar
Oddometer: 1,173
Put them (shorties) on my KLX300 and love them. They were HARD to get on even though I got the ones for the 43mm forks (which they are). Next time I get the velcro or buy the regulars for 46mm to facilitate the fitup. They have kept EVERYTHING out of the seals.
djchan is offline   Reply With Quote
Old 12-25-2007, 07:18 AM   #14
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Second guessing me huh.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Old 12-25-2007, 08:18 AM   #15
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 608
Lol
Ha... Never. Just being cool to my other ADV riders. Need to rebuild the rep after my run in with God. Oh I mean John the TM
Times are GMT -7.   It's 04:30 AM.
