Old 12-26-2007, 09:40 PM   #1
fmfpunk OP
Hooligan in training
fmfpunk's Avatar
Oddometer: 1,170
TDC locking bolt
Getting ready to check my valves, and wondering what's the purpose of this locking bolt.
Guessing that it's to hold the crank from moving while you have the cams out, because there's no TDC marks on the crank, only on the cams?
What can i use in place of this special tool?
thx.
I'll slack you off, you fuzzy little foreigner. I'll fill your bagpipes with Wheatena!
fmfpunk is offline   Reply With Quote
Old 12-26-2007, 10:13 PM   #2
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Before I had the locking bolt, I just used a long phillips screw driver.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 12-26-2007, 10:51 PM   #3
Tim McKittrick
Oddometer: 1,764
Just make one- when you remove the bolt that fills the stop bolt hole in the right case take it by the hardware store and get one of the same thread pitch but about twice the length. Or, if you're like me, root about in the bins of crap in your workspace unti you find one. Then make a point on it with your grinder or a file. If you make it about a 30 degree taper it'll work just like the factory tool. Done! Add it to your tune up tools.
Tim McKittrick is offline   Reply With Quote
Old 12-26-2007, 11:01 PM   #4
VintageThumper
Gotta ride!
VintageThumper's Avatar
Oddometer: 1,030
If you want the official bolt, it's 0113080802. If you want to make your own, it's 8mm x 80mm x 1.25mm thread pitch. As Tim said, it has about a 30 degree point on one end, and is machined for a hex key in the other. But I'm sure a regular screwdriver slot would work too. Here's a pic...
One adventure bike + one retro bike + one dirt bike = one big grin
VintageThumper is offline   Reply With Quote
Old 12-27-2007, 07:41 AM   #5
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
thx guys. I'll grind one here at work.
But would u explain why you need the bolt? If you don't uses the bolt is it possible to screw up cam timing?
thx.
Old 12-27-2007, 07:59 AM   #6
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,417
Yes it is possible, the valve springs pushing back from the "other" cylinder not being valve-checked can roll the crank. Spin the crank with a wrench and you will know what I mean.
If you do pull the cams be sure you understand the markings on the gears, they are not intuitive or easy to read, esp on the front cylinder. I mark the teeth with red paint to aid reassembly. Have fun, is not that tough a job!
Thread hijack: So whats the hot deal on FMF repacking for the 950? My Q's are getting loud!
HellsAlien is offline   Reply With Quote
Old 12-27-2007, 08:59 AM   #7
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
I've done the valves at least three times and never bothered with it. Never had a problem. The only time I had a prob was when I had a degree wheel on the crank trying to check the lift of the cams. You could probably leave the bike in gear to add a little resistance.
Get that thing goin and let's go race the Adelanto GP and pester Paul. Tell him I said hi.
tahoeacr is offline   Reply With Quote
Old 01-08-2008, 05:18 AM   #8
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
Thanks to VintageThumper for the pic,i made two using normal bolts of the correct thread and grinding a point on the end of each.
I have now done my valves-just need to rebuild it-anyway,i ordered the KTM bolt so i dont need the two i made(they work perfectly adequate),so if any UK people want one(there is 2 available),first 2 people to PM me their address gets one in the post.
Yep,FREE!!(KTM locking bolt is about 4quid and will most likely need ordering.
As i said,first 2 people.
BLUE(UK) is offline   Reply With Quote
Old 02-29-2008, 10:35 AM   #9
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,591
Why does it need to have angle in the point?
Can I use a screw on the correct dimension?
Member #68,893
stop pandering to posts from morons like Venteuri who can't even spell Venturi properly.
Venteuri is online now   Reply With Quote
Old 02-29-2008, 11:23 AM   #10
emelgee
emelgee's Avatar
Oddometer: 870
It'll make it easier to locate in the corresponding recess - the point will kind of guide it into the hole.
Mark G
KTM 990 rider and proud of it!!
950 adventure gone, but not forgotten.
emelgee is offline   Reply With Quote
Old 02-29-2008, 11:40 AM   #11
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Sometimes it is tough to get the crank to stop on TDC...
... especially on the rear cylinder (due to valve spring pressure forcing the crank past TDC). One trick I use when inserting the locking tool is bring the cylinder just short of TDC then insert a phillips screw driver or other pointed tool into the locking tool's hole and put slight pressure against the crank as I slowly turn the engine to TDC. That way I can feel the recess that the locking bolt needs to go into and stop the crank from slipping past. I then insert the locking tool. The top of the locking tool should be flush or slightly recessed with the engine case. Hope this helps some folks.
Should look like this:
NOT like this:
-cp
cpmodem screwed with this post 02-29-2008 at 11:59 AM Reason: Add an image
Old 06-26-2010, 07:14 PM   #12
G$
Lack of Adventurer
G$'s Avatar
Oddometer: 987
Thanks a bunch
For everyone who contributed to this thread, I just like to say thanks. This as well as many other threads here are invaluable.
G
G$ is offline   Reply With Quote
Old 06-27-2010, 10:13 AM   #13
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,717
TDC locking bolt
All said are good points - I made one out of aluminum so no chance of damaging things -good bad whatever it works. BUT as another thread discussed; what the hell do you do if you forget to back it off and turn the crank and either break or bend the bolt??? That'll ruin your day, week month. As said may be just don't use the bolt, and hope you can find TDC if it moves while you have a cam out. Here is what I think I'll do in future: Tie a lanyard between the lock bolt and my crank-turning tee -or some derivation of that scheme, so I can't turn the crank without at least making me think about the bolt.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 07-31-2013, 05:39 PM   #14
990adventuredes
Oddometer: 7
would this locking bolt work to stop the engine rotation to remove the ignition rotor ? i am using a manual torque wrench.
990adventuredes is offline   Reply With Quote
Old 08-01-2013, 05:56 AM   #15
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
Yes.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Times are GMT -7.   It's 08:39 PM.
