Old 05-09-2008, 08:54 PM   #1
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
Question LC4 oil level, first oil change
I just did my first 640A oil change. Everything went OK, including burping the bike. (OK so the burping thing was a little messy...)
The oil level in the sight glass was OK, and just short of the full line.
I turned it on and let it run for a few minutes. I didn't see any leaks so I turned it off to commence buttoning it up. I noticed the oil level is at the very, very bottom of the sight glass.
Should I top it up? I don't want to overfill. How long would the oil take to come back to equilibrium after running?
Tempo is offline   Reply With Quote
Old 05-09-2008, 09:04 PM   #2
mikeprod92211
Desert Rat
mikeprod92211's Avatar
Oddometer: 589
In my manual it states to wait 5 min after shutting off the engine and checking oil level.
LC4 Rider
mikeprod92211 is offline   Reply With Quote
Old 05-09-2008, 09:57 PM   #3
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
The manual!
Well, I topped it up. We'll see what comes out of the airbox tomorrow.
Old 06-03-2008, 02:13 AM   #4
joekanter
Oddometer: 128
Too funny
I just wrote a huge post/question about the same issue. So what happeend with your post oil change level?
Joe Kanter
North West Nevada
USA
joekanter is offline   Reply With Quote
Old 06-03-2008, 07:03 AM   #5
runwolf
Coureur des bois
Oddometer: 18
It seems to get an accurate reading on the oil level you really need to wait for the engine to be cold.
When the engine is warm, it seems in my case, the oil level goes all over the place, low, high, middle but once the engine rest for a bit the oil level come back to "normal"
I made the mistake of filling it up warm, cause I was below the bottom line once and once cold, I was well above the upper line....
runwolf is offline   Reply With Quote
Old 06-03-2008, 07:13 AM   #6
joekanter
Oddometer: 128
Sounds right. But I think my bike is possessed. Here is my post from this morning. http://www.advrider.com/forums/showthread.php?t=348234
Cheers
Joe Kanter
North West Nevada
USA
Old 06-03-2008, 07:30 AM   #7
Tempo OP
Stumptown Native
Tempo's Avatar
Oddometer: 684
I believe I used the exact amount of oil specified in the manual and FAQ. However this left me with an oil level just below the minimum in the sight glass. So I ended up topping up until it looked better. So far there have been no ill-effects. Sorry I didn't measure the extra, I will say it was a non-trivial amount (i.e. not just a few ml).
Old 06-03-2008, 12:01 PM   #8
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,202
There ya go Joe,
warm the bike up and wait 5 minutes to let the oil drain out of the system so the sight glass is accurate. If it stays below the upper line when hot, and above the lower line as it cools then you should be good.
I posted this in the other thread but Creeper said the difference between the two lines is a few ounces.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-03-2008, 02:19 PM   #9
joekanter
Oddometer: 128
Master Meat-you have reduced my profound mechanical paranoia.
That makes sense.
Originally Posted by meat popsicle
There ya go Joe,
Joe Kanter
North West Nevada
USA
Times are GMT -7.   It's 01:40 PM.
