Old 01-08-2008, 03:53 PM   #31
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
Originally Posted by Loadedagain
... as mentioned i've had better luck with nsk, ina, and fag.
ChrisC been runnin' his piehole again?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-08-2008, 04:42 PM   #32
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
WTF! It's less than a week into '08 and Meat is already serving up a steaming pile...
I'm so hurt...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-08-2008, 09:07 PM   #33
BobCWNC OP
Orange lithotripter
BobCWNC's Avatar
Oddometer: 13,041
you're correct about bearing qualitiy bill... the new bearing sent to bob is a german made nsk. i've had great experience with them in the past.
NSK is what I pulled out of it.
That said, your prices for NSK are outstanding. I know, I looked. Hard.
I think I'm going to wash the old one in clean K-1 and see if I can find some reason for the crunchiness. The seals looked intact although they seemed to be weeping some grease out of them, (unless it was from elsewhere).
__________
"It is a great art to saunter". Thoreau
“Life’s most persistent and urgent question is– what are you doing for others?” –Martin Luther King, Jr.
Alan Greenspan said out loud, “I have found a flaw.” Waxman pushed him, responding, “In other words, you found that your view of the world, your ideology, was not right; it was not working.” “Absolutely, precisely,” Greenspan said
BobCWNC is offline   Reply With Quote
Old 01-09-2008, 09:23 AM   #34
meat popsicle
Ignostic
Oddometer: 14,260
I'm so hurt...
Too obtuse?
Old 01-09-2008, 08:04 PM   #35
bmwktmbill
Traveler
Oddometer: 5,218
I did a 5 speed BMW airhead tranny with all Japanese bearings, it's still in service 50K miles later, my Toyota 4X2 pu died when the frame rusted through. The trans and clutch were still perfect. 175K miles.
Not sure what that proves....
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is online now   Reply With Quote
Old 02-11-2008, 04:13 PM   #36
Allgo
No Whammy,No Whammy,STOP!
Allgo's Avatar
Oddometer: 1,051
Bearing question
While servicing the sprocket carrier bearing (aka the "cush bearing") on my 00 lc4 - E , I damaged the internal plastic part that spaces the bearings apart - maybe this is called a carrier bearing bearing carrier ? Anyway, where can I find replacement parts to service this bearing. Please don't tell me I'm S.O.L.
Allgo is offline   Reply With Quote
Old 02-12-2008, 06:57 AM   #37
Allgo
Allgo's Avatar
Oddometer: 1,051
Should I take the lack of response to mean that there is no supplier for bearing components ?
Old 02-12-2008, 09:09 AM   #38
meat popsicle
Ignostic
Oddometer: 14,260
Check with Stenhouse Racing (Loadedagain); he is the only non-KTM source for KTM bearings that I know.
Old 03-21-2010, 02:46 PM   #39
klonu
Oddometer: 50
double bearing in a rear wheel
I got a bearing replacement kit for a rear wheel. Kit cost only 30 pounds.
In a spec I can see a single bearing under that sprocket holder but when I get it out I found 2 single bearings !
Whats the story ??? Do I have a older version or what ?
p.s. replacment bearing (blue) is RB tech - made in China :) (5205 RS)
klonu is offline   Reply With Quote
Old 03-21-2010, 03:00 PM   #40
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 842
"0625032057 GR. BALL BEARING 3205B-2RSRTNG" is used for cush drive at least from -94 to -07...
And 5205 RS bearing is for wheel.
Seikkailu_R is offline   Reply With Quote
Old 03-21-2010, 03:50 PM   #41
klonu
Oddometer: 50
3205 and 5205 are exactly the same size
25x52x20.6
bearing which I removed is only 47 mm diameter (6005DU2)
Old 03-21-2010, 06:22 PM   #42
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,950
06 smc carrier
28 0625060058 GR.BALL BEAR.6005 DDU2CG23S6NM $25.97
Part Number:58310050244
Description:SPROCKET SUPPORT CPL. 05
Retail:$140.90
wrk2surf is offline   Reply With Quote
Old 03-21-2010, 11:07 PM   #43
Tseta
Lost
Tseta's Avatar
Oddometer: 674
There has been discussion about this in another thread.
I did some research on it and posted some pictures. Pages 4 and 5 discuss this in detail.
Cheers,
Tseta
Tseta is offline   Reply With Quote
Old 09-19-2012, 03:26 PM   #44
gruesohm
gruesohm's Avatar
Oddometer: 7
So what exactly does the bearing spacer tube do? I just put the bearings in and now realized that the spacer is not.
gruesohm is offline   Reply With Quote
Old 09-19-2012, 03:28 PM   #45
LukasM
Oddometer: 5,427
It's there to make sure that the bearings stay at the correct distance, and don't get preloaded too much when you tighten the axle nut.
Not a good idea to leave it out....
Times are GMT -7.   It's 07:57 PM.
