Old 07-02-2012, 01:09 PM   #151
Badjuju
Badjuju's Avatar
Oddometer: 326
A new question in an old thread....
Would the "waterless" hand cleaner goop that comes in small tubs be OK to use as a bead lubricant? Looks to me like it's almost identical to the tire bead paste they sell for a whole lot more.
EDIT: The term "waterless" is misleading. Waterless refers to using it to clean hands without the use of water. The main ingredient on the can is water, but it also contains petroleum distillates, nonoxynol-6 (anti-bacterial, I think), triethanol amine, carbomer, magnesium aluminum silicate, and lanolin. Basically, a gelatinous soap...
Some people will tell you that slow is good, and it may be on some days, but I am here to tell you that fast is better... Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S Thompson, Song of the Sausage Creature
Badjuju screwed with this post 07-02-2012 at 01:18 PM
Badjuju is offline   Reply With Quote
Old 07-02-2012, 02:14 PM   #152
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,333
So...the consensus so far is that this really works, eh? I can have tires mounted for $20...is it worth doing it this way?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 07-02-2012, 02:22 PM   #153
_cy_
Oddometer: 6,326
looks pretty neat
Old 07-03-2012, 06:38 AM   #154
Wuwei
Oddometer: 1,108
I think it would work, as does ordinary dish soap or shampoo even. Almost anything slippery works, but for regular use I purchased a jug of RuGlyde from Napa--it is a rubber lubricant designed for this job. Cheap enough though I suspect it is nothing more than dish detergent and water.
That's a lot cheaper than most of us can get tires done for. I have mounted a half-dozen tires using the strap method and it does work and is reasonable easy to do. The time is in taking off the wheels, putting everything back together, etc. I have some Stubby Tire tools too, which don't mar your rims when you're taking off the old tire.
For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move. Robert Louis Stevenson
Wuwei is offline   Reply With Quote
Old 07-22-2012, 04:09 PM   #155
Chiriqui Charlie
Oddometer: 380
I have an even better trick. If I remove the wheel, any of the local tire shops will swap tires for two bucks. Being the super nice guy that I am, I generally tip another fifty cents.
If I drive the bike to a dealer and buy new tires, they do the entire job (front and rear) for $15
Chiriqui Charlie is offline   Reply With Quote
Old 08-17-2012, 01:07 AM   #156
calfinm
calfinm's Avatar
Oddometer: 38
Ive got to put a big in for this Poolside.. I just put a rear Kenda 761 (tubed) on trying this..a combination of a b@@%%d head cold, general haste, and a few shots of vodka to help me a long and I with a fair amount of struggling got it on...backwards
Spooning it off I'm convinced its the stiffest sidewall that Ive ever had the misfortune to encounter.
Round 2 and a bit more lube, taking my time and it just literately slid on to the rim ..couldn't believe it..
Cheers!
calfinm is offline   Reply With Quote
Old 09-01-2012, 07:14 PM   #157
victor441
victor441's Avatar
Oddometer: 961
Thanks very much! tried this for the first time today and it worked great, mounted a 150/70 tire with a tube very easily, Rather than lashing straps I used six 24" cable ties and they worked great, got a bag of 8 for $5- FWIW they can be reused too, it is easy to lift the locking tab with a small screwdriver and undo them. Bought a gallon of Ruglyde from Napa per suggestions here and it does seem better than straight soapy water...the tire went on so easily I probably could have not used lubricant but like to anyway since it makes the bead seat much easier.
victor441 screwed with this post 09-01-2012 at 08:23 PM
victor441 is offline   Reply With Quote
Old 09-03-2012, 01:03 AM   #158
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Boy, I haven't checked in here for a while. Thanks for the kudos folks!
I'm glad many of you found this tire mounting method useful. Cheers!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 09-03-2012, 10:35 AM   #159
Kaanan
Knee deep in snow.
Kaanan's Avatar
Oddometer: 591
Originally Posted by Klay View Post
I applaud your innovation for its own sake...that's pretty cool. But if you you know how to use tire irons, it's pretty fuss free, too, and you can use the irons to get the tire off again, too.
I'm no expert, I've probably changed 10 tires in my few years with a motorcycle. But I on average pinch 1 tube for every other tire I change. The cost adds up quick, especially when I was 23, newly married and the only one working. I wish I knew about this trick years ago!
Kaanan is offline   Reply With Quote
Old 09-03-2012, 10:36 AM   #160
Kaanan
Knee deep in snow.
Kaanan's Avatar
Oddometer: 591
Did I mention I ride a KLR! I am not as cheap as a lot of other people I meet on the road with them, but pinching a tube is a biuzzkill.
Old 09-03-2012, 10:51 AM   #161
Kaanan
Knee deep in snow.
Kaanan's Avatar
Oddometer: 591
I still feel the need to defend myself.
The last tire I tried to mount was a Duro 904. I wrestled with it for an hour, pinching two tubes in the process. I realized I was in over my head, so I brought it in to the motorcycle shop down the road.
The guy working has been a mechanic for 10+ years, we are on a first name basis since I've brought my bike there for other things/see him around Milwaukee for different motorcycle events.
We were talking as he put the tire on, I saw him pinch 3 tubes! It scared the shit out of me. But the walls were so stiff! I was hoping I was doing something wrong with my shitty studebaker tire irons. It makes me nervous to think I could be stranded somewhere and pinch the only spare tube I have on me.
Old 10-15-2014, 06:18 PM   #162
nevada72
Klaatu barada nikto
nevada72's Avatar
Oddometer: 563
An older thread but I thought I would pass along props for the info. It worked very well. However, there were a few differences. Firstly, 6 + years after the thread starter - Harbor Freight straps cost me $3 for the pair - on sale! The horror! Also, installing Michelin T63s with a tube on a spoked wheel is a bit different. As such, I used pry bars and lube.
Overall, I felt it made the process easier, and more importantly, helped prevent a pinched tube. That alone makes it a worthy method imo.
So thanks OP for passing along a very handy tip.
2003 DR650
1976 Triumph Bonneville
2014 Harley Davidson Street Glide Special
1964 Honda Dream
1967 Honda CA Touring
nevada72 is offline   Reply With Quote
Old 10-16-2014, 08:56 AM   #163
davidpetersen
BestRest Adventurer
davidpetersen's Avatar
Oddometer: 813
Why do tubes get pinched?
Why do tubes get pinched by tire irons?
We stationed the BestRest film crew on the inside of a tire as it was being mounted. They reported that the tube was pinched as the iron was rotated past 100 degrees; when that happened the end of the tire iron pinched the tube against the rim, causing a hole in the tube. They videoed the entire process, but due to low-light conditions and a failure of the battery pack on their kleig lights the video was useless.
Based on an after-action debriefing, we developed this method to prevent pinching the tube:
1. Wheel assembly lying flat on ground.
2. Insert tire iron between tire and rim, pushing the iron inward just enough to get a "bite on the rim" with the end of the iron. The tip of the iron will push the tube out of the way.
3. Rotate tire iron upward, but don't rotate more than about 100 degrees from horizontal (it's OK to go slightly past vertical). Every degree beyond that increases the chances of a pinched tube.
4. Using more than 2 irons is good. 3 is best. That keeps any one iron from putting too much force on the tire or rim.
5. Of course having the tire and rim properly lubed is critically important when it comes to spooning tires on the rim.
6. Work your way around the rim, carefully working the tire into place. I like working in a clockwise fashion since I live in the northern hemisphere.
David Petersen
Mr. BestRest
KTM 450 EXC
F800GS
R12GS Standard
Feet of clay
http://www.bestrestproducts.com
davidpetersen is offline   Reply With Quote
Old 10-16-2014, 10:34 AM   #164
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,341
Times are GMT -7.   It's 07:37 AM.
