Old 01-07-2008, 04:55 PM   #16
woodgrain
In-Dented Savant
woodgrain's Avatar
Oddometer: 820
I was hoping to see someone like my Norwegian grandfather, actually putting a tire on with their bare hands without the use of any "tools", straps included. He used to do it on model T Fords. Innovative idea nonetheless. Kudos.
Woodgrain
woodgrain is offline   Reply With Quote
Old 01-07-2008, 05:08 PM   #17
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
I bet those straps flop around a bit at speed
If that works on my damm dirtbike tires I'll need to send ya some beer amigo!@!
WoovsHoovs is offline   Reply With Quote
Old 01-07-2008, 05:18 PM   #18
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks for the kudos my brothers. I appreciate it.
Some of your questions:
I suspect getting those straps tight was a bit of work, right?
Yea, that took a few minutes, tightening the straps a little bit at a time. I'm working on a coupla tools for that job. The trick is to start the buckle in the right spot so it won't end up over the beads. The light-duty non-tubular-webbing straps are a necessity.
- Reckon it would work with a tubed tire as well if you start with the valve first.
- Man ...I wonder if that would work ok with a tube type tire.
Yes it does. You can tuck the valve stem into the tire too. Rim locks might be a curious difficulty.
I will be trying this. Let me add one question - after this process are you lying in a heap of your own sweat and blood or is it as easy as it looks?
Heh heh Instead of my hands, I did the process the first few times using my feet. You know, straddling the tire with my feet at the 3 and 9 o'clock positions.
The wheel in the picture isn't attached to the 'skids', and it tiddlywinked me to the ground more than once. When you get a feel of where to push the tire (out close to the tread, ahead of the bead rollover point) it almost falls onto the wheel.
- Now, how do you get it off with just the straps?
- How do you unleash the beasty?
- I would think that once bead is broken, you may be able to fish straps around a flatted tire and do same in reverse.
Ahh, now there's the rub. I have a trick for that too but I haven't work out the details yet. Getting the straps on the tire and the beads compressed, when the tire is already on the wheel, is a real test of patience.
I wonder if tywraps would work as good as the nylon straps?
Poly twine works if you have the patience. In some ways the twine is easier, because it can be tied with the 'knot' located in the 'airspace' between the beads.
It's like tearing a phonebook in half. Once you know the trick.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-07-2008, 05:29 PM   #19
Lone Rider
Registered User
Oddometer: 25,130
Tire changing solutions range from the simple to complex, but what's needed still remains the same.
Square peg, round hole....not, which frustrates many people.
Hoenstly, no BS, IMO, not telling a lie, no kidding here, etc, some lube with tire tools and knowledge of their use makes for quick work and an easy solution.
Lone Rider is offline   Reply With Quote
Old 01-07-2008, 05:43 PM   #20
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,757
I applaud your innovation for its own sake...that's pretty cool. But if you you know how to use tire irons, it's pretty fuss free, too, and you can use the irons to get the tire off again, too.
Old 01-07-2008, 06:05 PM   #21
2wheelsrbest
Oddometer: 282
Sure, you guys are correct. I don't think Poolside is trying to create a new "product". I took it as "Hey. Look what I figured out!" It is just one more of those tidbits to file away for future use in some remote corner of nowhere when it could possibly save the adventure.
It would totally solve rim scratching problem for some folks, though.
It reminds me of the urban legend of the hillbillys with the blown fuse in the truck. The quick-thinking Cledus shoves a .22 shell into the fuse holder and the truck speeds off. A few miles later he gets shot in the nuts by same .22 shell. This is just like that, except nobody will get shot in the nuts. At least not for using this method of tire mounting... You just get the positive side of the innovation.
2wheelsrbest is offline   Reply With Quote
Old 01-07-2008, 06:09 PM   #22
PunkinHead
Moobless Adventurer
PunkinHead's Avatar
Oddometer: 6,168
Originally Posted by Poolside
Pretty cool eh? No tire irons. Only your hands.
I've been known to do it with nothing but a twenty dollar bill.
PunkinHead is offline   Reply With Quote
Old 01-07-2008, 06:22 PM   #23
Red08
Red08's Avatar
Oddometer: 25
Wink no tool mounting
Originally Posted by Wanderer99
Awsum you the man !!! I have to try that.
But now i want to see you get AIR in it
'All gave some, Some gave ALL'
2010 FLSTFB Black Denim
2008 KLR650 = RED08
1982 FT500 = Old Thumper
2005 Mustang Convertible RED
Michigan Patriot Guard Rider
Charter Life AMA
Life Member Hog.
Red08 is offline   Reply With Quote
Old 01-07-2008, 06:24 PM   #24
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,984
Who runs a tourance on a Ninja?
bemiiten is offline   Reply With Quote
Old 01-07-2008, 06:48 PM   #25
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Heh heh, I was wondering when you were going to catch that
The Kawi wheel is an old beater, victim of many rolling burnout-till-flats. But the DOT bead profile is as good as gold.
Old 01-07-2008, 08:37 PM   #26
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,921
Nice work Jim, looks like that would be an excellent field fix, especially for the damned tube tires.
Jim
JimVonBaden is online now   Reply With Quote
Old 01-07-2008, 09:21 PM   #27
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,846
I'm unclear (not unusual) how this will work for a tube-type knobby with a rimlock...can somebody edumacate me?
fn
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-07-2008, 09:31 PM   #28
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,331
If you do this one bead at a time you don't need to use straps. As mentioned, some lube helps too.
GreaseMonkey is offline   Reply With Quote
Old 01-07-2008, 11:04 PM   #29
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,610
Mount a Motorcycle Tire Without Using Tools??
Thought you said no tools? Sorry, but I see 8
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 01-08-2008, 11:56 AM   #30
bourkeco
bourkeco's Avatar
Oddometer: 634
That is fantastic....
"Motor racing, mountain climbing and bull fighting are the only true sports. All the rest are children's games played by adults."
- Ernest Hemingway
I realized after 29 years of riding/racing that as much as I love motorcycles I had only tolerated ridding the bikes that I have owned. , untill I bought my GS now I have a hard time getting off the ramp to go to work.
- Me!
bourkeco is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
