Old 01-07-2008, 08:09 PM   #1
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Laugh Hacksaw Tire Dismount!
If your tire are used up and you are changing them, here's another way to dismount them.
And no, I don't own a KLR . . . yet
The fine tooth blade cuts through the steel belts in about 10 seconds each. Cuts through a non steel belted tire carcass also in about 10 seconds.
This thread is a companion to http://www.advrider.com/forums/showthread.php?t=299597
Use a fine tooth blade, 32 Tooth Per Inch or better. It's surprising how quickly the blade cuts through.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-07-2008, 08:20 PM   #2
RocketJ
Oddometer: 674
My choice
Also 32tpi
[/IMG]
RocketJ is offline   Reply With Quote
Old 01-07-2008, 08:26 PM   #3
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I didn't have a 32tpi blade for my reciprocating saw, otherwise...
Old 01-07-2008, 08:30 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,870
I tried that once, but ran into issues cutting near the rim. It got in the way. Did you do that on, ot off, the rim?
Jim
JimVonBaden is online now   Reply With Quote
Old 01-07-2008, 08:37 PM   #5
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Try it again man. Protect the wheel with a short piece of wood moulding.
Old 01-07-2008, 08:39 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 53,870
I will, actually my mid 80's XT 200 needs tires. Combine removal like that, and straps to reinstall a new tube tire and it should be golden!
I hate tube tires!
Jim
Old 01-15-2008, 06:43 AM   #7
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
if you want more control, and to cut out cute shapes into the tire use a dremel with the light switch or wall socket adapter\cutter. If it's cordless it's even easier. Similair tools include the rotozip and other small rotary tools.
I have never done it myself, but the theory is sound. Just make sure you use carbide or some other stronger bit instead of the one designed to cut drywall or sheetrock.
HaChayalBoded is offline   Reply With Quote
Old 01-15-2008, 10:30 AM   #8
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I have cut elastomer with a roto-zip. The risk of the cutter grabbing and binding in the rubber, and winding up tire cord and steel wire, is substantial.
The cutter heats up and melts the rubber, and the tool leaves your hand. Things go pear-shaped in hurry with a high power roto-zip. My fingers were spared that time.
Maybe try it yourself with a two-flute high-pitch bit in a 1/4HP tool. Reduce the risk for the experiment.
Old 01-15-2008, 12:38 PM   #9
gman350
Oddometer: 156
Kind of along the same lines, I cut old tires onto 4 pieces so they will fit in the trash (FWIW I called my trash hauler and that was their suggestion).
I have tried using a recip saw with a metal-cutting blade. The problem with that is the tire flexes too much and moves with the blade. I have tried clamping it in a vise, using c-clamps, it's just a pain. The blade will zip right through all but the steel belt at the rim, I use a set of bolt cutters for that.
A plain old hacksaw works fine. The easiest thing is a metal-cutting bandsaw.
gman350 is offline   Reply With Quote
Old 01-15-2008, 03:02 PM   #10
Lone Rider
Registered User
Oddometer: 25,130
Has anybody tried using a cutting torch and then welding the rim back together?
Lone Rider is offline   Reply With Quote
Old 01-15-2008, 03:40 PM   #11
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
I've done it with a jig saw - metal blade .. forget the tpi.. took for ever to go through the bead .. think the wires were vibrating in the rubber rather than being cut .. metal fatigue set in and it ended as I intended - tyre in bin. Will try the hacksaw next time
Frank Warner is offline   Reply With Quote
Old 01-15-2008, 05:48 PM   #12
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
I am surprised how often I will kill myself trying to do something with a power tool that I could have actually done easier by hand.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 01-15-2008, 06:16 PM   #13
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
You could be the first!
Think of the chills, thrills and spills…
Be sure and take before and after pictures… It would be yet another ADVr first…
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 01-15-2008, 09:48 PM   #14
Ben10
Expert Trespasser
Ben10's Avatar
Oddometer: 120
...nice. I actually prefer unscrewing the valve stem and using the torch to fill the tire with oxy/acetelyne, then I jam a lit non-filter cig in the stem and walk away. Since the tires explode outward the rim is spared. Mount the new tire while the rim is still warm.
"Not all those who wander are lost"
Ben10 is offline   Reply With Quote
Old 01-16-2008, 01:02 AM   #15
hoyks
Tightass KLR rider
hoyks's Avatar
Oddometer: 812
I used an angle grinder to cut a section out of an aircraft tyre once. They have some really heavy duty wire rope around the bead.
It didn't take long at all ....
..before the smoke detectors went off and the fire service turned up.
Not my best idea .
hoyks screwed with this post 01-17-2008 at 03:36 AM
hoyks is offline   Reply With Quote
Times are GMT -7.   It's 09:17 PM.
