Old 01-09-2008, 08:44 AM   #1
urchindog OP
Oddometer: 163
Cool2 KTM LC4 - Aux. Lights
Hello,
anybody out there mount and use the Piaa 55w aux. driving lights on their LC4 ? I'm interested if this will work with the charging / electical system without problems or if this is too much drain. I've got a old pair off a previous bike and wanted some real world opinions before I mount/ wire up.
tks, bryan
Thanks for the ideas and responces ... my application is for a
2004 KTM SMC 625 ..didn't know all those lc4's had different charging systems.
urchindog screwed with this post 01-09-2008 at 01:29 PM
urchindog is offline   Reply With Quote
Old 01-09-2008, 09:19 AM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
You only have 200W maximum to play with. Throwing 110W at two driving lights will get you close to battery drain. Why not look into HID?
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-09-2008, 09:29 AM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,254
That is good advice, and there are reasonably priced options too.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-09-2008, 11:32 AM   #4
loeky
Oddometer: 245
Would love some links or info. Haven't seen much specifically relating to the LC4 Non-Adventure...
Matt N.
loeky is offline   Reply With Quote
Old 01-09-2008, 12:07 PM   #5
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Try here: http://trailtech.net/single_lights.html
Chris
1943 BSA M20WD
Old 01-09-2008, 12:23 PM   #6
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,553
I've run one 55W aux light on mine with no problems. I made a bracket out of a bit of alu angle to attach it to the handguard mount.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 01-09-2008, 12:45 PM   #7
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Cheers
Clint
Yeabutt.... that only works in the Southern Hemisphere.
Chris
1943 BSA M20WD
Old 01-09-2008, 12:58 PM   #8
meat popsicle
Ignostic
Oddometer: 14,254
No this is a good point Chrissy-poo - differences between the E and ADV. I don't recall any statements on the E's charging output and standard load.
Thanks Clintnz! I've been watching the Lord of the Rings movies again (bedridden with the flu) and lusting over your countryside...
Come to look, the original poster didn't say which model LC4...
Old 01-09-2008, 01:20 PM   #9
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
It took some time and I now have it booked marked.
Yet this is the way I'm going with my Adventure....
http://www.advrider.com/forums/showthread.php?t=197163
alpiv is offline   Reply With Quote
Old 01-09-2008, 01:41 PM   #10
666
Agnostic and Orange
666's Avatar
Oddometer: 1,318
I installed only high beam HID. 89$. Works great. I had to change one fuse from 10 to 15.
Plenty of light
http://www.advrider.com/forums/showthread.php?t=285277
666 is offline   Reply With Quote
Old 01-09-2008, 02:37 PM   #11
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
E should be the same, save the minor difference in the headlamp... Herr Meatsheisse
Chris
1943 BSA M20WD
Old 01-09-2008, 03:03 PM   #12
meat popsicle
Ignostic
Oddometer: 14,254
The headlamps are the biggest piggy-poo(s) in the ADV system, so "minor" may not be an appropriate qualifier and clintnz is a very reliable source of poop.
That's not right either... how about Fleischkopf? Hey, wait a minute, some bugger's already got that handle. How about Herr Fleischstock?
Old 01-09-2008, 05:05 PM   #13
clintnz
clintnz's Avatar
Oddometer: 3,553
No this is a good point Chrissy-poo - differences between the E and ADV. I don't recall any statements on the E's charging output and standard load. ...
I doubt there are any differences. I know I've run 60W high beam + 55W aux light + 35W heated grips for long periods with no probs.
Good aye! I might have to watch them again soon too & get some inspiration for the next Sth Is trip. Get well soon
Cheers
Clint
Old 01-09-2008, 05:32 PM   #14
meat popsicle
Ignostic
Oddometer: 14,254
What is your headlight draw clint?
Cheers
Clint
Old 01-09-2008, 06:28 PM   #15
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
the lc4 e has the same charging output as all other "640" lc4 engines. chris is right... 110w is bordering on the edge.
you may be ok. you probably will not. if it's an adv bike you've aready got your 2 oem lamps, then you wan to double them with a couple hundred watts max?
hid is by far the best option. trailtech are nice as are many of the hid conversion kits available online (ebay has hundreds). i'd try an hid in the main lamp first, then add more if need be.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
