Old 01-09-2008, 11:23 AM   #1
snoid OP
100% Okie
snoid's Avatar
Oddometer: 29,462
ural performance mods...
have you hole-sawed yer pipe?
punched holes in the airbox and rejetted?
was it worth it?
snoid is offline   Reply With Quote
Old 01-09-2008, 11:48 AM   #2
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Ural
Performance
Mods....
Rad is offline   Reply With Quote
Old 01-09-2008, 12:01 PM   #3
mac62
One more thin gypsy thief
mac62's Avatar
Oddometer: 4,771
I think they go like hell with a chainsaw motor mounted on them.
I keed, I keed. I'm actually thinking of treating myself to a nice side valve Chang when I get back stateside this summer...I think Briggs & Stratton have a performance kit for it.
"Oh yeah? Well how about I just kick your ass?"
-Mahatma Ghandi, 1946
mac62 is offline   Reply With Quote
Old 01-09-2008, 12:23 PM   #4
wyowillys46
Hau Ruck!
wyowillys46's Avatar
Oddometer: 2,105
Oxymoron
But seriously, even if you could just tack on another 20 hp, the transmission and final drive can't deal with it. They're already at their limits.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 01-09-2008, 01:10 PM   #5
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
was it worth it?
well that will make it louder...
not a smart mod, but a common one
You want to make a Ural faster on a budget, lose some weight and get rid of the windscreens.
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 01-09-2008, 01:17 PM   #6
Gummiente
Rebel Without A Clue
Gummiente's Avatar
Oddometer: 449
was it worth it?
Anything you can do to build on the measly stock 42hp is be a good thing and will make an appreciable difference in the low to mid-range, which is where the Ural is meant to run at.
Hole sawing the mufflers - not recommended, but it is a better idea than ramming a spike through them. You will realise more power gains by going to an aftermarket muffler, such as the Dunstall replicas, with the required re-jetting to the carbs.
Punch holes in the airbox - really not sure what you mean by that and I probably don't want to know. Anway, the Ural's airbox setup is a little unorthodox in that air is drawn from the scoop underneath (on '06 and later models, a hole on the top lid for '05 and earlier) through the inside of the filter to the outside. This means the maximum intake hole you can have is one that is slightly smaller than the ID of the air filter itself; if you punch holes all over the airbox body then you are bypassing the air filter. Not good. Enlarging the stock intake hole will have a tendancy to slow down the intake airspeed - which is good - but will also expose the air filter to more roadspray, rain, salt and slush - which is bad. The best thing you can do with the stock airbox is to invest in a high flow, oiled filter element like a K&N and rejet the carbs to suit.
There's really not much else that can be done to improve performance on these motors, save for porting the heads. Other than that, you need to consider things like reducing wind resistance by removing the billboard sized sidecar windshield, spare tire and carrier, lightening the ballast load in the trunk and going on a diet.
Really, the Ural isn't meant to be a performance machine in the first place. I's all about torque and as such is designed to be loaded up and flogged through the undergrowth, with an occasional side trip to chase a squirrel up a tree.
Mike
'07 HD Road Glide
'05 Ural Tourist
CURD Head Cheese
"Riding a motorcycle is like playing the blues, it takes a moment to learn and a lifetime to master"
Gummiente is offline   Reply With Quote
Old 01-09-2008, 02:35 PM   #7
snoid OP
100% Okie
snoid's Avatar
Oddometer: 29,462
hmmm...
so the filter on a gear up is just hanging out there?
looks like i might be doing mr. cob's snorkel mod,
me
p.s. how about a hayabusa motor? will it fit?
Old 01-09-2008, 02:41 PM   #8
McB
Joe 40 ouncer
McB's Avatar
Oddometer: 15,440
Maybe a Subaru.
McB is offline   Reply With Quote
Old 01-09-2008, 02:52 PM   #9
snoid OP
100% Okie
snoid's Avatar
Oddometer: 29,462
but i want to put a hayabusa motor in it...
and a 35" swamper bogger on the back....
me
Old 01-09-2008, 02:58 PM   #10
Gummiente
Gummiente's Avatar
Oddometer: 449
Technically, the inlet scoop being relocated to the bottom means the filter is hanging down there. Mr Cob's mod is a good solution and can be done at home if you're fairly handy with tools and a welder. I went in a different direction by designing, fabricating and relocating my own airbox. It uses an automotive air filter with nearly three times the surface area of the stock round unit.
Mike
'07 HD Road Glide
'05 Ural Tourist
CURD Head Cheese
Old 01-09-2008, 03:03 PM   #11
snoid OP
100% Okie
snoid's Avatar
Oddometer: 29,462
hmmm... thanks
i'll have to take a look at it.... i'll come up with something.
Old 01-09-2008, 04:16 PM   #12
princess jamaica
OLD DOG-NEW TRICKS
princess jamaica's Avatar
Oddometer: 2,263
Originally Posted by Rad
Ural
Performance
Mods....
THAT'S FUNNY
24 hours,maybe 60 good years,it's really not that long a stay.........jimmy b.
princess jamaica is offline   Reply With Quote
Old 01-11-2008, 10:10 AM   #13
JohnBG
Slow Moving Three Wheeler
JohnBG's Avatar
Oddometer: 259
was it worth it?
I re-jetted the carbs with some fatter jets, plopped in a K&N filter and replaved the exhausets with some more free-flowing pipes.
It helped a little, but far from what most might consider "performance modifications".
Perfomance Modifications? - Dood it's a Ural. It pretty much is what it is.
JohnBG
'98.5 Ural Tourist 650 - "Valentina" (the blonde)
'06 Ural Raven 750 2WD - "Vorona" (the brunette)
Soviet Steeds Motorcycle Collective Forums
An independent site for Ural/Dnepr Enthusiasts
Forums - http://www.sovietsteeds.com/forums
Photo Galleries - http://www.sovietsteeds.com/galleries
JohnBG is offline   Reply With Quote
Old 02-20-2010, 11:58 PM   #14
Threewheelbonnie
Oddometer: 974
Resurected
My Triumph electrical gremlins (now sorted see here https://sites.google.com/site/threew...10/the-repairs ) plus the Ural bashing thread got me thinking about Urals. Back in 2000 I had a 650 whose **** construction meant that in 2004-7 when I put the Triumph-Ural together I wouldn't touch anything Russian that couldn't be fixed/improved. Looking now there would only be two things holding me back, price (9000 in the UK for a basic 1 WD) and the cruising speed. I remembered this thread.
So (without any "shove it off a cliff" comments please, and no I don't get enough holiday to slow down to 55 and enjoy the ride), if I want that Holy Grail 75 mph Ural what would I need to do?
Bore out to 1000CC?
Fit a BMW or Subaru engine?
Will this destroy the gearbox (makes the whole thing pointless if you lose reverse)?
Are Ural making any noises along the lines of understanding parts of the market want motorway speeds?
If I drop the 75 mph ask, can I get 65 all day by head/carb mods?
As the Triumph is now once again fixed there is no rush for me to do any of this, but I'd still be interested to hear if it's possible or if I need to wait for the 2015 model.
Andy
Threewheelbonnie is offline   Reply With Quote
Old 02-21-2010, 01:07 AM   #15
SamM
Jeep Overlander
Oddometer: 1,471
Why does this seem to be the ongoing theme of the Hacks Section of AdvRider? The bike is not made for that! It doesn't need performance mods because, it's not a performance bike. I'm all for making it better though. It's made for utility. To do things that other bikes can't do. Get you where a normal motorcycle can't go or won't go and in weather that others will not go out in.
You guys crack me up!
SamM
SamM is offline   Reply With Quote
Times are GMT -7.   It's 06:31 AM.
