Old 01-16-2008, 10:40 AM   #46
rob1313 OP
Still learning
rob1313's Avatar
Oddometer: 4,378
Hey meat
Are we going to add this one to the index?
I love this site
"To live is the rarest thing in the world. Most people exist, that is all." - Oscar Wilde
rob1313 is online now   Reply With Quote
Old 01-16-2008, 11:23 AM   #47
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Originally Posted by rob1313
Hey meat
I love this site
Sure. Major reorganization of the index coming up, which may rely upon dumping many lesser threads into a separate repository to free up real estate in Posts 1 and 2.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-16-2008, 11:37 AM   #48
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
Originally Posted by chevaliernoir
Hello
What are all these switches below the clock?
Le Chevalier Noir
as you know ktm charging power is limited. i wanted to control all things individually so i didn't run the battery flat.
1) aux power relay (for vhf radio and other comms)
2) gps power (charge it up, run it dead, charge it up, run it dead)
3) roadbook power (it has lights that are annoying at night when no map installed or not required)
4) grip heaters
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 01-16-2008, 11:37 AM   #49
Loadedagain
making chips
Oddometer: 26,732
Originally Posted by meat popsicle
I think the two on the left are for the Gatling gun, and the two on the right are for the RPGs.
can't tell them that. now we have to kill them all!
Old 01-16-2008, 11:58 AM   #50
boney
Ride > Post
boney's Avatar
Oddometer: 1,405
Originally Posted by braaap!
when it all goes wrong.... I need it all tucked up nice an' tight...
Mouting the GPS to the roadbook holder isn't as treacherous as you might think. Last year when I bit it in the desert the GPS mount roated back and down on the roadbook holder, which then took the brunt of the force and left the GPS with only minor cosmetic damage. I rotated it back up and it was good to go. The roadbook holder had to be removed and straightened later .
The plastic "fairing" on the 640A provides very little crash protection for the things behind it.
boney is offline   Reply With Quote
Old 01-16-2008, 12:22 PM   #51
meat popsicle
Ignostic
Oddometer: 14,224
Old 01-16-2008, 01:30 PM   #52
Sylvia
vir sapit qui pauca loqui
Sylvia's Avatar
Oddometer: 3,513
you southern boys are ruthless to one another!
Yes this is true meat; more importantly however we are also consistant
Slightly Orange
Sylvia
Sylvia is offline   Reply With Quote
Old 01-16-2008, 01:43 PM   #53
meat popsicle
Ignostic
Oddometer: 14,224
yeah, we yanks could learn a thing or two from ya. Like that minimalism y'all got for traveling - can we do without the kitchen sink? Come to think of it, walkabout never could be a national phenomenon here in the US, because we can't carry enough crap on our backs...
Old 01-18-2008, 04:04 PM   #54
searchin oz
Sand, Gimme more sand
searchin oz's Avatar
Oddometer: 1,169
Heres mine;
I purchased a KTM road book carrier but found I had to lose some of my steering in order to fit it so it went back and had this made.
6mm steel rod for the main frame with 1.2mm sheet stitched in between the bars to keep it rigid. There was to much flex with out the sheet. Drilled a heap of holes to reduce weight but kept the strength.
Finally folded up a GPS carrier out of some 2mm alloy welded to some 5mm alloy that bolts to the 1.2mm flat sheet.
Dont criticize someone till you have walked a mile in their shoes,
at least then if they get angry they will be a mile away - and barefoot.
searchin oz is offline   Reply With Quote
Old 01-21-2008, 03:35 AM   #55
scottmoto16
Scooter Adventurer
scottmoto16's Avatar
Oddometer: 2,076
Very , very simple.
KTM road book holder , Touratech GPS mount for Magellan Meridian.
NO LONGER ORANGE
scottmoto16 is offline   Reply With Quote
Old 01-21-2008, 03:54 AM   #56
scottmoto16
Scooter Adventurer
Oddometer: 2,076
Howdy Meat
Have got gear on the bike down to bugger all , about 6 kilos per pannier , and the same 6 kg for bag on rack , with a couple of kg's in tankbag.
Thats for a multi-day trip.
Overnighters are just the panniers , no tankbag or bag on the rack (just a thermarest on the rack).
Whoops , sorry , thread jack......................
NO LONGER ORANGE
Old 01-21-2008, 09:57 AM   #57
gybeman
gybeman's Avatar
Oddometer: 628
and another simple one....
276 with Gilsson remote antenna.
I see a couple other genius's onboard have discovered the supplied Garmin mount for the 276 fits lovely on the dash. If you have a remote antenna it can be be placed further back and more out of the way and shaded from the sun. Infact, I also have a Tourtech iso mount (not the real jiggly one, the one thats cheaper and has smaller iso mounts) and it vibrates like a s.o.b. mounted off the handlebar mounts. Touch the bar mount and there are very little vibes. Touch the gps and you can get a hand massage. Its enough to make the gps power off when running on the internal battery.
The stock plastic one mounted on a rubber gasket (sliced off a piece of old hand grip) is smooth enough to run on batteries and it also locks in place, without key though. Oddly enough when I mounted the Tourtech on my 300 2T, the bar mounts vibe a bit, but very little vibes get to the gps. I run it on the battery no probs on that bike.
If you are not going to do any desert racing, or need the big route sheet holder and all the tubing that comes with it, you can use the power feed for the route sheet holder for a switched powersupply to hardwire the gps and any other accessories to. There is a spare 2 wire square plug in the connections under the dash. I don't like the idea of a lighter plug sticking out, or popping out in bumpy conditions.
gybeman is offline   Reply With Quote
Old 01-21-2008, 11:02 AM   #58
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,562
Very simple.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 01-21-2008, 11:26 AM   #59
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,595
Originally Posted by scottmoto16
Very , very simple.
That looks like a good trail to me.
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is offline   Reply With Quote
Old 01-21-2008, 03:36 PM   #60
scottmoto16
Scooter Adventurer
Oddometer: 2,076
East coast , Tasmania.
NO LONGER ORANGE
Times are GMT -7.   It's 06:17 AM.
