Old 01-21-2008, 04:14 PM   #61
JayBo1
JayBo1's Avatar
Oddometer: 2,805
East coast , Tasmania.
...and that's the main road into town!
JayBo on Safari/Dakar
#101 Dakar 2015, Kiwi Safari Team, Perth, WA
KTM 450 Rally ... Dakar ready
KTM 530 EXC-R
Cagiva 750 Elefant - Lucky Explorer '88
JayBo1 is offline   Reply With Quote
Old 01-21-2008, 04:29 PM   #62
scottmoto16
Scooter Adventurer
scottmoto16's Avatar
Oddometer: 2,076
NO LONGER ORANGE
scottmoto16 is offline   Reply With Quote
Old 02-07-2008, 06:14 AM   #63
Sand Junkie
08 Safari Here I come!
Oddometer: 14
Nice set up !
Hey jaybo1 what thickness ally is your cockpit bracket made out of ????
Looks about 3mm am I close??
I like the design !
I had that type of design in mind but just makes it easier to see one all set up !!
Cheers
Bish
Sand Junkie is offline   Reply With Quote
Old 03-30-2008, 10:27 PM   #64
Tappet
Feral
Tappet's Avatar
Oddometer: 1,451
Minimalist
Here's the dash on my new Adv, it's quite simple. The KTM/Touratech bar brace and the $15 handlebar mount from Garmin. It's actually a bicycle mount but with a little tube rubber wrapped around the mount it works fine soaking up the vibes and is as tight as you like.
Tappet is offline   Reply With Quote
Old 04-12-2008, 05:57 AM   #65
kelsow
kelsow's Avatar
Oddometer: 1,118
Thanks to Gybeman, here is what I ended up doing,
kelsow is offline   Reply With Quote
Old 04-14-2008, 07:38 AM   #66
gybeman
gybeman's Avatar
Oddometer: 632
Thanks Kelsow. I'd like to take the credit, but its clear that there are a few others with the same idea. Are you running that on bike power or gps battery? The proof if it works or not would be if it doesn't power itself off running on the internal battery.
I see you are a 'track up' guy. Arggg, the wife keeps flipping our gps's to that setting. North up rules !
gybeman is offline   Reply With Quote
Old 04-14-2008, 04:30 PM   #67
kelsow
kelsow's Avatar
Oddometer: 1,118
Yes, but you told me about this thread.
I have mine wired directly into the bike as this GPS doesn't have an internal battery.
North up confuses me.
Old 04-15-2008, 05:39 PM   #68
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 781
Thanks to this thread I finally got of my butt and made a roadbook holder that works with handguards. Full lock and GPS!
Did the factory roadbook holder work with the handguards of any year?
nfranco screwed with this post 01-28-2009 at 09:24 PM
nfranco is offline   Reply With Quote
Old 04-15-2008, 05:57 PM   #69
Para504
Spam, Spam, bacon & Spam!
Para504's Avatar
Oddometer: 558
Not a great shot, but you'll get the idea. The TT mount holds a 60Cx at an angle you can see while seated or standing.
Para504 screwed with this post 03-06-2009 at 05:27 PM
Para504 is offline   Reply With Quote
Old 04-19-2008, 10:18 AM   #70
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,634
Is that the KTM OEM Roadbook holder? Hows does that Emig setup work?
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is online now   Reply With Quote
Old 04-25-2008, 11:00 AM   #71
Para504
Para504's Avatar
Oddometer: 558
The bracket used was designed for the roadbook. I believe I got it from ktmhutt.com The only negative about it is it limits the steering lock when using barkbusters (depending on your setup).
As far as the Emig setup goes, I have nothing but good things to say about the product & company (small family business). I ended up getting the different offset & a "Rev 1" damper (no damping back to center).
Old 06-04-2008, 01:41 AM   #72
chevaliernoir
Le Chevalier Noir
chevaliernoir's Avatar
Oddometer: 101
here is mine.
I use a PDA for navigation because depending of the country and the maps available, I use Tomtom, IGo or OZI software.
The problem is that the PDA is not waterproof and has no 12V supply. So I put it in a RAMTECH box, and included a Bvat-> USB power supply home made.
The king size model of RAMTECH fits perfectly the windscreen of 640Adv!
I wanted first to use a RAMTECH system to hold it to the KTM support, but it was too heavy an too big, so I made my own support.
I come back from Mongolia, and everything has been fine (at least with the dashboard)
I use also the PDA and MP3 player (not while driving, but in the camp)
Le Chevalier Noir
One thing is sure : Nothing will happen as planned
chevaliernoir is offline   Reply With Quote
Old 06-22-2008, 01:33 PM   #73
earthmover
Opinionated, me?
earthmover's Avatar
Oddometer: 225
I think I've just about got the cockpit of my 640 how I want it now. A Scott steering damper, mated to a Stenhouse Racing mount, to keep the plot straight and add an extra 20mm raise to the bars. I got new throttle and decompressor cables 50mm longer from Venhill, they weren't absolutely necessary, but I was able to route them better than the standard ones. Cycra handguards, with the U-mountings to allow me to have the levers set lower, and provide much needed crash protection. A roadbook holder from Acerbis, fastened to a stainless steel bracket made by a local fabricator to avoid the bars hitting it, as the KTM part does. (He has kept the pattern, if anyone else wants one). ProGrip handgrips, as I can't get on with the foam ones it came with, far too fat for my liking. I tried various methods for positioning the GPS, but none of them worked particularly well. A Malcolm Smith bracket from the handlebar bolts was fine, until I compressed the forks and the brake hose tried to rip the aerial off. Mounting it under the roadbook obscures the clocks, unless I lift the roadbook up, which puts it too far above the fairing. Without completely rearranging the dash, I settled on the faithful Ram Mount, with a Touratech bracket, very soon to be powered from an extra socket on the dash.
Big thanks to Colin Stenhouse, off this site, for his assistance with getting the right parts.
Mark
earthmover is offline   Reply With Quote
Old 06-23-2008, 01:35 AM   #74
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,468
Originally Posted by earthmover
.... I got new throttle and decompressor cables 50mm longer from Venhill, they weren't absolutely necessary, but I was able to route them better than the standard.... Mark
mmmm! any chance of passing on the part numbers and the source... do they do esales?
I really need some extra rise to help my poor old back!... the only thing stopping me is I've run out of cable length with Colin's damper mount and riser kit....
would really appreciate the info - cheers
alfons
braaap! is offline   Reply With Quote
Old 06-23-2008, 05:45 AM   #75
JayBo1
JayBo1's Avatar
Oddometer: 2,805
Cables
alfons
I bought some Venhill cable kits to do my throttle cables. Bought from Ballards and you make them up to length to suit. It took a fair bit of messing around but I'm very happy with the end result.
The decompressor cable you want is KTM Part No. 58302094000. It's the decomp cable for a '93 LC4 and is longer than the cable from '03 to '07 640Adv's and goes well for length with the 25 or 30mm raised bars I have. I just fitted mine yesterday and it works a treat.
KTM 530 EXC-R
Times are GMT -7.   It's 07:58 AM.
