01-10-2008, 04:45 PM
#1 |
I know a shortcut!
Oddometer: 9,478
Scotts damper relocation on an LC4E?
Hey guys, I searched the thread index to death and still cannot determine if what I want to do is possible.
I currently have a Scotts damper on my 02 LC4E using the over bar mount and weld on tower. Is it possible to get or use an under bar mount that will utilize the current welded on tower? I need some bar risers bad but don't want to give up my damper, and I don't know anyone that can weld... Yes, I tried some taller bars (Pro Taper ATV highs) but it doesn't do very much. Any thoughts and opinions welcome. You can even call me names if you want to! Thanks! |
01-10-2008, 04:53 PM
#2 |
Just a dude....
Oddometer: 11,205
You need to measure some stuff up to see where you're at, and where you want to be.
You could cut down the tower, and use a shorter pin to do the underbar damper. The alternative is to get a longer pin, but that creates some other issues. Measure it up and see if underbar mounts are available for that Scotts. They are pretty easy to talk to on the phone, too.
gaspipe [the original] I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle. -- Winston Churchill |
01-10-2008, 07:27 PM
#3 |
Guest
Oddometer: n/a
dampner
I was on jeff emigs page the other day he may have what you need. Alot of cool stuff there.
01-10-2008, 07:44 PM
#4 |
I dont want a pickle
Oddometer: 619
Stenhouse
01-11-2008, 06:41 AM
#5 |
Oddometer: 645
I just got finish installing a Scott's under bar with a weld on tower on my 01 LC4-E last night. I had to cut the short weld-on tower down so much that I had to ream the pin hole deeper.
All of Scotts under bar mounts come with the clamp on tower. The clamp-on towers are much, much easer to install, plus they look nicer. |
01-11-2008, 06:45 AM
#6 | |
What would Scoobydo?
Oddometer: 1,668
01-11-2008, 07:09 AM
#7 | |
making chips
Oddometer: 26,648
to answer questions... yes it is possible to take your existing damper and mount it under bar with your existing tower. here's how my mount works... a picture is worth a thousand words. ![]() this bike had an above bar mount. i removed it. installed my mount. flipped the damper around. flipped the lever arm on damper 180 degrees. chopped 31.5mm off the existing tower (measure twice, cut once ;wink ) ... andeverything works out well. have done this for a couple dozen customers. the resulting rise in bar height is 31.5... and you dont blast yourself in the nuts with your damper if you make a boo boo. pop me a pm if you've got any questions. don't want to get this kicked into the vendor forum.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 *** Stenhouse Racing - Specializing in KTM Upgrades custom cnc service available to suit your specific needs. |
01-11-2008, 09:05 AM
#8 | |
what attitude problem???
Ditto, have a Emig under the bar mounted stabilizer on the 07 640A I am working on right now, it's a really nice set up. Would post a pic, but no smug mug. However it would be easy enough to alter the weld on mount you have now by shortening it, re-welding it and then all you would need is the under bar riser with incorporated stabilizer mount such as Emigs.
Just some dude on the internet,.. |
