Old 05-15-2014, 02:16 AM   #346
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,716
Originally Posted by GezwindeSpoed View Post
Did you have enough room in your F2R? The roadbooks of the Libya Rally contained too much detail, needed to cut it in 3 pieces sometimes.
Hellas improved a lot compared to last year!
What is your range with subframe tank?
Scouting info on large scroll sizes. Do you have the approximate length of the Libya one? (or the number of pages that it had?)
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon screwed with this post 05-15-2014 at 02:39 AM
640 Armageddon is online now   Reply With Quote
Old 05-15-2014, 03:29 AM   #347
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 256
It was provide on roll . I will have a look on the lenght.
I found out that there is a new model F2R, I have the old version.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 05-15-2014, 04:29 AM   #348
RandyMartin
Oddometer: 9
Yes I agree with you Mr safari! Husaberg did not produce reliable rallye bikes. However, I have heard that since KTM has taken over Husaberg, the company has started producing better rallye bikes.
RandyMartin is offline   Reply With Quote
Old 05-16-2014, 11:25 AM   #349
Hagenblad
Hagenblad's Avatar
Oddometer: 87
Had enough room, but you have to take your time rolling it on. If you bend it too much it doesn't work. Cut it the longest day.
The range is about 200 km I guess. It takes forever to fill up, so I fille the front, then a PET-bottle, and tank again, rode to the start of the next special and topped up with teh bottle.
Follow the DaCarl blog @ facebook.com/raiddesigns
Hagenblad is offline   Reply With Quote
Old 05-19-2014, 12:37 AM   #350
zimi
Oddometer: 59
GezwindeSpoed, about the Fuel boiling, did you mount some heat protection under the tank?
Something like this:
http://www.ebay.ch/itm/CV4-Fuel-Kool...item418035455d
zimi is offline   Reply With Quote
Old 05-19-2014, 02:02 AM   #351
GezwindeSpoed
Oddometer: 256
Nope, maybe that would have helped. A friend of mine has a low swing exhaust, he still had this problem, so it looks like the heat is mainly from the engine.
Old 05-19-2014, 03:05 AM   #352
SafariBerg OP
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,046
In 4 years of racing the 70 degree bikes over about 155,000km all up in Australia, EU and Dakar we NEVER ever experienced a fuel boiling situation.
We also never used heat protection of the stock main tank that holds the fuel pump, which we always retained.
2013 Husaberg FE501
2014 Arctic Cat Wildcat Z1 1100T Rallye
SafariBerg screwed with this post 05-19-2014 at 03:13 AM
SafariBerg is offline   Reply With Quote
Old 05-19-2014, 04:22 AM   #353
GezwindeSpoed
Oddometer: 256
Maybe I am too slow in the dunes
Just before the dunes there was a refueling point. The truck was standing in the sun, so maybe the fuel was already pre-heated. I was not the only one having this problem, also some 500exc's and older carburated bike had issues as well. It was around 45C at the hottest moment of the day.
I did not loose any water during the rally, but I have a fan installed (which was only running in the dunes).
GezwindeSpoed screwed with this post 05-19-2014 at 11:16 PM
Old 05-19-2014, 06:08 AM   #354
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,550
I have only boiled the coolant on slow trail technical trail riding and idling...no fan kit.
Seth S
Seth S is offline   Reply With Quote
Times are GMT -7.   It's 03:00 AM.
