Old 04-20-2008, 02:23 AM   #1
stevh0 OP
Super Retard.
stevh0's Avatar
Oddometer: 1,491
XR650 L vs R
Sure the XR650R is the king of baja and more often then not the R gets the decision above the L ,just becos of that.
The R certainly has more power in stock form and it also weighs alot less.
Engine wise they are very similar , with the R just having .2 over in stroke.
what would happen when you match the L's 8 odd compression to the 10 odd compression of the R?
Would this not be a bit more of a monster with a happy button?
stevh0 is offline   Reply With Quote
Old 04-20-2008, 04:26 AM   #2
husky123
Oddometer: 1,454
Huh?!
husky123 is offline   Reply With Quote
Old 04-20-2008, 04:40 AM   #3
stevh0 OP
Super Retard.
stevh0's Avatar
Oddometer: 1,491
XR650R bore and stroke - 100mm x 86.2 - C/r 10.0.1
XR650L bore and stroke - 100mm x 86 - C/r 8.3.1
Higher C/r = more power.
Make sense now?
Old 04-20-2008, 05:12 AM   #4
michaeln
Old And In The Way
michaeln's Avatar
Oddometer: 821
The two engines are totally different. The L motor is an 80s vintage air cooled 650 based on the XR600R with electric start added. The R is a much newer designed water cooled motor that is way more maintenance intensive and produces a LOT more power.
CAUTION: Objects in shorts are much larger than they appear!!
http://michaelnel.smugmug.com/
San Francisco, CA
michaeln is offline   Reply With Quote
Old 04-20-2008, 05:16 AM   #5
stevh0 OP
Super Retard.
stevh0's Avatar
Oddometer: 1,491
the question is ..
what if you upped the C/r of the L to the same as the R or even higher..
You could gain some valuable Hp there.
I can see why they kept it low, making it a stress free engine. But upping the C/r could be beneficial.
The R is by FAR more superior.
Old 04-20-2008, 05:23 AM   #6
michaeln
Old And In The Way
michaeln's Avatar
Oddometer: 821
Without some kinda oil cooler installed, the L wouldn't be able to stand the heat generated by the R's compression ratio.
San Francisco, CA
Old 04-20-2008, 05:29 AM   #7
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
the question is ..
My L' comp ratio is higher than the R's and I'm somewhere near 680cc. Yes the power went up BUT it is not nor will it ever be on par with a R. Two different animals.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Old 04-20-2008, 05:32 AM   #8
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Yes it can, and has for about 4000 miles now Even when loaded
Klaatu barada nikto
Old 04-20-2008, 05:46 AM   #9
husky123
Oddometer: 1,454
Make sense now?
Oh yeah. Perfect sense. Thanks for clearing that up.
Old 04-20-2008, 06:18 AM   #10
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,831
Gee, I guess you're probably right, the 28,000 miles my modded L has on it must be just a fluke?
I was torn between getting a new L and building it up vs a new Husky 610 and I tired of waiting on ktm's 690 adv.
Yesterday I got back on the xrl and gave my brother a turn on the Husky and stopped after a mile convinced the front tire was flat. It wasn't, just the extra 50lbs.
My 93 L isn't really worth much dollar wise but it would be hard to part with.
katbeanz is offline   Reply With Quote
Old 04-20-2008, 06:25 AM   #11
katbeanz
katbeanz's Avatar
Oddometer: 7,831
the question is ..
I think the L is low compression so they could meet emissions standards for a street legal dual sport. They are also jetted horribly lean and a CV carb to boot.
Old 04-20-2008, 07:03 AM   #12
roadholder
roadholder's Avatar
Oddometer: 2,529
I've had one of each over the years and the 650R is hardly more maintenance instensive. Water cooling adds a dimension of complexity over the old XR600, but hardly significant and with possible benefits for long term durability... and certainly performance!
Doug
2014 Yamaha FZ9
1973 Norton Commando & other old stuff
roadholder is offline   Reply With Quote
Old 04-20-2008, 07:11 AM   #13
djmase
something catchy.
djmase's Avatar
Oddometer: 286
I am very curious as to what exactly is 'more maintenance intensive" meaning? What is it about the R that makes it such hungry wrenching beast? Does someone have a break-down of the two schedules side by side?
Also, how does the R stack up maintenance-wise relative to say a ktm 640?
Cheers.
“You don't have a soul. You are a Soul. You have a body.” ~CSL
More musings @ http://davidjessemase.blogspot.com/ & http://twitter.com/djmase
djmase is offline   Reply With Quote
Old 04-20-2008, 09:27 AM   #14
husky123
Oddometer: 1,454
+1 on that.
Old 04-20-2008, 09:30 AM   #15
stevh0 OP
Super Retard.
stevh0's Avatar
Oddometer: 1,491
what is your 650R service interval like?
Times are GMT -7.   It's 03:43 AM.
