Old 02-19-2010, 07:22 PM   #226
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,259
Originally Posted by NC Rick
Yea, me too. It snowed yet again last night, coated stuff with ice ontop of that. We have had about 24" since mid December.
I want to ride my bike!
Awesome job on the shock Rick. It handles the sand down here in Mexico just fine!
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 02-19-2010, 07:29 PM   #227
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
That white sand almost looks like snow... Is it just me?
Thanks Ron! I wish I were down there with you "Testing".
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 03-10-2010, 10:16 PM   #228
Exile
The Mundane and The Magic
Exile's Avatar
Oddometer: 222
Rick
I recently snagged a Ohlins shock for a '95 KTM 250SX off Ebay for cheap. Others have told me they were able to get this shock to bolt onto the DR650 with minimal effort. I have found otherwise. Sparing the details, the exhaust gets in the way of the reservoir. So I was thinking of taking the guts out of the Ohlins and putting it in the stock casing, basically what you are doing. Any thoughts on this? Any problems you foresee? Here are some images for your viewing pleasure.
06 Ducati 999 | 66 Ducati 250 | 03 Suzuki DR650 | 88 Honda NT650 Hawk
My Site
TAT 2010 | Rocky Mountain Loop 2014
DR650 Stator Rewire
Exile is offline   Reply With Quote
Old 03-10-2010, 10:49 PM   #229
Exile
Exile's Avatar
Oddometer: 222
Another picture to show my problem.
My Site
DR650 Stator Rewire
Old 03-11-2010, 06:13 AM   #230
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
So the reservoir is too long. Also looks like the shocks stroke is wrong. We could likely correct the stroke and shorten the reservoir to make that shock fit. I don't know about the spring rate or valving on that shock. KTNs have a linkless rear suspension that often use variable rate springs with position sensitive damping, that too can potentially modified.
I doubt the internals will fit into the DR shock. The DR uses a 40mm internal piston dia. Not sure what you have in the Ohlins but I suspect it is a 46mm body.
I would consider some type of trade for our shock internals for you to install for the KTM Ohlins.
Rick
motocd.com
Old 03-11-2010, 06:34 AM   #231
Exile
Exile's Avatar
Oddometer: 222
Well, in your opinion, would modifying the Ohlins make for a "beefier"/better shock compared to your rebuild of the stock shock? I am open for trades, perhaps with a little compensation from myself if needed. What did you have in mind?
Btw: How could you tell the stroke was off?
My Site
DR650 Stator Rewire
Exile screwed with this post 03-11-2010 at 06:40 AM
Old 03-11-2010, 06:43 AM   #232
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
The Ohlins shock would give you better compression damping control due to the superior compression adjuster design compares to the OEM shock. Our internals will likely give the better overall damping. If you were using the DR on motocross tracks, the 46mm Ohlins body would get rid of heat better. Let's talk off line about how to work this out for you.
Rick
motocd.com
Old 03-11-2010, 06:55 AM   #233
LukasM
Oddometer: 5,426
Hi Rick,
Before you go offline with this discussion - do you work on a lot of linkless/KTM suspension as well? I might have some custom work for you...
Cheers,
Lukas
Old 03-11-2010, 08:20 AM   #234
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
Lukas,
I can not profess to be an expert on the KTM stuff. I do work with a few local Hare Scrambles racers who ride KTMs and I service the WP stuff, more because few shops will. I am quite conversant with the KTM Dual Sport stuff and have worked on / revalved some cool 560 SM race bikes. Our shop and product range is petty much dedicated to Street, RoadRace and Dual sport bikes.
I would help where I can.
Rick
motocd.com
NC Rick screwed with this post 03-11-2010 at 08:30 AM
Old 03-11-2010, 05:55 PM   #235
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 871
Why waste the time with that Olins shock when Rick can set you up with the correct DR setup for under $500.00.
I have my doubts that a KTM olins shock will be better than a Cogent DR shock.
Plus you can just sell the olins for enough to fund the correct DR shock.
When it's all said and done, More will be said.
You dont have to wish me luck for me to know that I need it.
rallyhound is offline   Reply With Quote
Old 03-11-2010, 06:00 PM   #236
Exile
Exile's Avatar
Oddometer: 222
Well I don't have even close to $500 to spend on a new shock. Plus I got the Ohlins for free, which may fund a correct shock from Rick.
My Site
DR650 Stator Rewire
Old 03-11-2010, 06:10 PM   #237
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 871
I hear you about the money.
I guess my point was you could probably sell that Olins for enough to get the Cogent shock, which I think is a better solution.
Old 03-17-2010, 08:52 AM   #238
HiJincs
Dreamer
HiJincs's Avatar
Oddometer: 624
Woo Hoo
I got me some wrenchin' to do this weekend!
Rick performed his magic and added a 7.2 rear spring. I'm also replacing the stock fork springs with .45's and intiminators.
Thanks Rick & Joyce! Great talking to both of you.
HiJincs is offline   Reply With Quote
Old 03-18-2010, 06:47 AM   #239
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
Hi Guys,
an important note:
DO NOT use the suzuki manual torque specification to tighten the lower shock mounting bolt (on the shock clevis).
The prescribed torque will often rip the aluminum threads out of the clevice on the OEM or our shock.
There is an error in the manual.
We suggest 37 NM as the correct torque to tighten the M-10 fastener in the aluminum thread.
Rick
motocd.com
Old 03-18-2010, 08:17 AM   #240
71tr
Oddometer: 463
new group buy
Okay guys, its time to get your shocks into Rick for rebuild and group buy discount on the hard coating. Mine is going out this week and the only hold up is sufficient numbers to garner the discounted hard coating. Lets get off the wallets and get our bikes ready for spring riding....it hit 60F here in Chicago yesterday!
71tr is offline   Reply With Quote
Times are GMT -7.   It's 10:04 AM.
