Old 01-14-2008, 06:21 PM   #1
Zerodog OP
Oddometer: 1,233
Ever wonder what is inside your 640 shock?
Now you know!! Here is the inside of my shock. I needed to put a new seal in and I decided to try out some different valve stacks. I have some ideas......they could be good.....or could totally suck and I will be doing this again shortly.
All of the washer looking things are the shims that control the oil flow. These items are arranged in the shock when it is revalved. The thing on the left with the holes is the piston body. The piston separates the compression side from the rebound side. It also controls oil flow to the shims.
The LC4 shock is totally different than the standard PDS style shock in any other KTM. The PDS shocks have 2 pistons a needle and about twice the amount of shims. I will have to post one of those next time I get one apart.
Zerodog is offline   Reply With Quote
Old 01-14-2008, 06:46 PM   #2
durtrider
adventure sow
durtrider's Avatar
Oddometer: 670
Yo Dawg! Your gonna get mine to tear apart into littlebitty pieces in about 3 or 4 days! Its boxed up and ready to ship mon-yawna.
durtrider is offline   Reply With Quote
Old 01-14-2008, 07:08 PM   #3
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 771
If you weren't so far away i would send my shock to you.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 01-14-2008, 08:28 PM   #4
Tuff Tunica
Moto-Skiveez creator
Tuff Tunica's Avatar
Oddometer: 675
Slc???
What the? An LC4 suspension expert right here in SLC? I live in Park City and have had the shock for my 625 SXC sitting at Palo Verde suspension since before X-mas. Still no word. Had I known I'd have brought it to you. Where are you located and I guess I should ask do you do this kind of thing for others? I'm guessing from post #2 that you do.
Tuff Tunica screwed with this post 01-14-2008 at 08:58 PM
Tuff Tunica is offline   Reply With Quote
Old 01-14-2008, 08:39 PM   #5
Zerodog OP
Oddometer: 1,233
Yes I work on shocks and forks. I specialize in Lc4s because I am one of the few tuners that ride one all the time. So I know what the bike does under the usual riding conditions. It sure as hell isn't MX or serious desert racing. Most guys want a focus on dirtroads and easy trails.
I do other suspension stuff for other KTMs too, with a focus on trail and desert riding.
Zerodog screwed with this post 01-14-2008 at 08:47 PM
Old 01-15-2008, 03:43 AM   #6
bmwktmbill
Traveler
Oddometer: 5,203
Z-dog,
Another KTM mystery unveiled.
Thanks,
b.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-15-2008, 05:34 AM   #7
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
Thumb
Hey, mine looks like that; only all together...
You can leave most of that stuff out, it only adds weight.
Which one is the spacer that is added to the Adventure shock to limit travel?
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 01-15-2008, 06:04 AM   #8
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 2,820
I could easily pull mine apart....getting it all back to together, however
Yooper_Bob is offline   Reply With Quote
Old 01-15-2008, 06:26 AM   #9
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,735
yabbut... can you get it all back inside the tube it cam out of?
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 01-15-2008, 06:39 AM   #10
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,217
Interesting. I'll have mine apart after my new spring arrives. So I was wondering why the rebound shims were so much smaller- guess the inner ports on the valve are the rebound and the big outer ones the compression.
Luke is offline   Reply With Quote
Old 01-15-2008, 09:11 AM   #11
Zerodog OP
Oddometer: 1,233
The spacer is the brown thing on the left under the piston. It is about .5" thick.
Old 01-15-2008, 09:48 AM   #12
Mtncrzr
Mtncrzr's Avatar
Oddometer: 1,213
Zerodog, thank you.
Are you going to put a bladder in the new shock or stay with the piston?
Old 01-15-2008, 10:08 AM   #13
Zerodog OP
Oddometer: 1,233
Zerodog, thank you.
No bladders, bladders are for pussies! I like the pistons. They last forever, work very well and I find they are easier to deal with. I have a vacuum bleed system for doing KTM shocks.
Old 01-15-2008, 11:50 AM   #14
Hipster
Hipster's Avatar
Oddometer: 1,811
Zerodog,
Is it pretty much trial and error with various shim stracks until the you hit upon the charactestics your looking for? When you have a shock/ fork revalved are they just altering (adding or subtracting) to the shim stack?
Hipster is offline   Reply With Quote
Old 01-15-2008, 01:31 PM   #15
Zerodog OP
Oddometer: 1,233
It is and isn't trial and error with the valve stacks. You know what the problems are you are trying to fix. So you address those areas with certain configurations of shims. Different arrangements give different effects. But getting just the right set up is trial and error part. That is why testing on the bike is the best.
Yes for the most part revalving is changing the valve stacks. Sometimes it can also involve changing the pistons too. But revalving is the general term.
Times are GMT -7.   It's 10:43 PM.
