Old 01-15-2008, 11:26 AM   #1
cap'n Jack OP
YAAARRR... or something
cap'n Jack's Avatar
Oddometer: 166
Worried about lack of Cush Drive... any advice?
So, I'm heading up north for the weekend, Los angeles to San Luis Obispo. Not a long trip, most if it was supposed to be off-road but all the good routs out of Los Angeles are closed for the season. So I am forced to slab it all the way up to Soda Lake area. That and the direct route back will put a few hundred miles on my NON cush drive rear wheel...
I ride a 625 SXC. Am I asking for trouble or is this nothing to worry about?
thanks for the advice,
Cooper
Now Riding--
2006 Husqvarna TE 610
Gone but not forgotten--
2006 Husqvarna TE 510
2004 KTM 625 SXC
1977 CB750 F
2000 Ducati Monster 750
1965 cb77
Restoration Projects--
1967 cb160
"Go that way really fast... If something gets in your way, Turn. "
cap'n Jack is offline   Reply With Quote
Old 01-15-2008, 12:08 PM   #2
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,134
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
It'll be fine.
Old 01-15-2008, 12:20 PM   #3
cap'n Jack OP
cap'n Jack's Avatar
Oddometer: 166
Originally Posted by Yossarian_47
It'll be fine.
Thanks Yossarian, that's kinda what I thought...
However I think I'll get a second wheel with Cush sometime in the future just to lower the risk of blowing out my transmission.
coop
Now Riding--
2004 KTM 625 SXC
1977 CB750 F
1965 cb77
1967 cb160
Old 01-15-2008, 01:05 PM   #4
crazybrit
crazybrit's Avatar
Oddometer: 8,040
I have a cush rear and a regular on my SXC. If you're running knobbies I wouldn't worry about it. See the FleaMarket for a guy looking for a new rear for his SXC where he trashed the hub. It happens. Probably not in 300 miles even if you were running Saharas (or some non knobbie).
Also OC is the wrong forum for this, it should be posted in thumpers.
crazybrit is offline   Reply With Quote
Old 01-15-2008, 03:52 PM   #5
roc104
roc104's Avatar
Oddometer: 313
I dont remember seeing any transmission issues on an SXC due to a non cushioned hubs on the street...Actually, I dont remember hearing about any transmission issues period. But as Crazybrit said, i have seen a few cracked hubs.
That being said, I installed one on mine for piece of mind
roc104 is offline   Reply With Quote
Old 01-15-2008, 04:11 PM   #6
crazybrit
crazybrit's Avatar
Oddometer: 8,040
The tranny is already dampened. It's the hub thats the issue.
If you're doing a lot of street miles on dual-sport tires it's worth adding
as a hub failure at speed could be unpleasant.
Old 01-15-2008, 04:24 PM   #7
cap'n Jack OP
cap'n Jack's Avatar
Oddometer: 166
I got ya, so the knobbies help dampen the torque of the wheel, taking the pressure off of the hub. less knobbies more torque on the hub.
Glad to hear that the repair would be on the hub and not the transmission. This definitely gives me piece of mind.
thanks again,
Coop
Now Riding--
2004 KTM 625 SXC
1977 CB750 F
1965 cb77
1967 cb160
Old 01-15-2008, 05:13 PM   #8
Beemer Pat
Oddometer: 2,722
all things KTM ... www.ktmtalk.com
Beemer Pat is offline   Reply With Quote
Old 01-15-2008, 05:31 PM   #9
Ned1
Lend Me Yu Choppa
Ned1's Avatar
Oddometer: 477
+1 on cracked hubs and the odd broken spoke.
Ned1 is offline   Reply With Quote
Old 01-15-2008, 10:24 PM   #10
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,428
Different bike I know, but I have done thousands of kilometres on my XR600 on highway and I've subscribed to the theory that sacrificing knobbies is an effective, if crude, form of damping. Seems to have worked for me so far.....
GodSilla is offline   Reply With Quote
Old 01-15-2008, 10:41 PM   #11
team ftb
Befuddled Adventurer
Oddometer: 1,210
The cush drive helps absorb shock loads delivered to the hub through the tranny. Strong shock loads would be strongest during low speed, high traction throttle inputs. for example, tight canyon pavement corners and super motard tracks. Droning along the interstate and cruising on the pavement I believe will transmit minimal loads to your hub.
You should have no problems. Good luck.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 01-16-2008, 05:53 AM   #12
Noreaster
Fat and Cuddly again
Noreaster's Avatar
Oddometer: 1,240
You know, every one loves to pimp that site but I haven't found that there is a lot of information on there. (Admittedly I am a total NooB over there and might not have the place figured out yet). There are a LOT of words typed though. It is my opinion that of all the "other" sites out there you get a more mature and knowledgable demografic on ADVrider and along wiht that the best answers to you questions. YMMV.
" I hate to burst bubbles, but the Last Frontier is paved..." JRMosley
Noreaster is offline   Reply With Quote
Old 01-16-2008, 06:23 AM   #13
Hair
10 fingers 10 toes
Oddometer: 12,009
Be sure that you have the sprocket bolts torqued down. Use blue locktight to hold them in place. If there is any give in the bolts you will have a problem.
Why are we stopping?: Wayne Weber
Hair is offline   Reply With Quote
Old 01-16-2008, 06:26 AM   #14
Hair
10 fingers 10 toes
Oddometer: 12,009
Hi Pat, From the looks of things you will be test riding a berg before the summer is out. Saturday I'm headed over to Prescott to pick one up.
Wish me luck.
Old 01-16-2008, 07:22 AM   #15
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,648
i have broken hubs of rigid wheels riding on the street. for 300mils you'll probably be ok though. problem is if you crack it you wont know for some time... if it were my only bike i would do it. if i had the extra cash i would spring for a used cush wheel off fleabay.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Times are GMT -7.   It's 03:59 PM.
