Old 04-27-2010, 09:31 AM   #181
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 17,944
I kinda like the look of dual ATE's, just want a more traditional look for the bodywork. A return to the '74 R90/6 I rode when I was 21.
Guess I am become one of those old guy nostalgic vintage farts.
Old 04-27-2010, 04:37 PM   #182
blaine.hale
blaine.hale's Avatar
Oddometer: 3,065
Originally Posted by crazydrummerdude
Well, if you want to ditch the fairing and dual disc setup..
Shoot, put me in line for that dual disk set up
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 04-27-2010, 04:40 PM   #183
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,593
One time, I saw one on ebay goin' for like $20. It ended at like 7pm that night. At about 7:05, I checked, and it sold... for $20.
crazydrummerdude is offline   Reply With Quote
Old 04-27-2010, 05:24 PM   #184
blaine.hale
Oddometer: 3,065
You should go ahead and shoot yourself in the foot for not watching that auction.
1974 BMW R90 /6
Old 04-27-2010, 05:58 PM   #185
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 781
Originally Posted by AntonLargiader
' sometimes the potentially deadly 10mm flywheel bolts (were never supposed to be used with 900cc but some got out),
So, what's the story on the "potentially deadly 10mm flywheel bolts"?
-Chobro
Chobro is offline   Reply With Quote
Old 04-27-2010, 06:43 PM   #186
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I call it the "chicken little" syndrome
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 04-27-2010, 07:48 PM   #187
Hawk Medicine
Coyote's Brother
Oddometer: 3,302
It's a simple story...
After the introduction of the R-90 and the 90S there were reports of the small 10mm flywheel bolts that had been carried over from the R45/50/60/75 models shearing and creating quite a mess.
The problem disappeared after the factory discontinued using the small bolts and went with larger fasteners. I've never owned an R90 with 10mm bolts and while I'd sure want to know if a prospective bike had em, they wouldn't be a total deal breaker. I'd just have to consider how I was going to use the bike.
Some folks say that there were only a handful of R-90s issued with the 10mm fasteners but if thats true, how come it appears as if there are so many of em around?
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 04-27-2010, 08:42 PM   #188
Lornce OP
Lost In Place
Lornce's Avatar
Oddometer: 17,944
Yeah, I ain't gonna worry too much about that one.
On another note... dropped in on a buddy this evening who has a 13mm perch mounted master cylinder and braided line on his '78 R100/7 (single ATE). Either his brake needed bleeding or I might be eating a little crow re. a 12mm M/C and twin ATE's.
Whatever it takes, baby. Whatever it takes.
Old 04-27-2010, 08:45 PM   #189
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
There were two versions of the 10mm bolts.
1970-1973 used short ones, 1974-late 1975 used a longer one.
In late 75 they changed the crank to 11mm bolts.
I've seen the 11mm bolts fail also.
If the 10s were so bad they would have had a lot more failures.
I believe the reason that BMW went to the 11mm bolts is not because of inherent failure of the 10s, but because they were getting ready to launch the new engine (1000cc) in 76 and redesigned a lot of things, some that were not necessary. (rubber diode mounts comes to mind)
They anticipated alot of things with the 1000 engine that were non issues.
(Smaller diameter alternator rotors because of crank flex also comes to mind)
the sky continues to fall.
small minds think alike.( it's easier)
www.wirewerkes.com
wirewrkr screwed with this post 04-28-2010 at 02:35 PM
Old 04-27-2010, 10:39 PM   #190
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 781
Thanks for the info, I'm just about ready to pull the flywheel on a 5/74(mfg. date) R90/6 to replace rear main, etc.
I'll let y'all know what I find...
-Chobro
Old 04-27-2010, 10:50 PM   #191
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 781
BTW, nice score!
Originally Posted by Lornce
-Chobro
Old 04-28-2010, 08:12 AM   #192
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,593
Both of my /6's are early ones. Neither has 10mm flywheel bolts.
Old 04-28-2010, 01:58 PM   #193
Max Headroom
lost in the '70s
Max Headroom's Avatar
Oddometer: 515
In late 75 they changed the crank to 12mm bolts.
I've seen the 12mm bolts fail also.
I believe the reason that BMW went to the 12mm bolts is not because of inherent failure of the 10s, but because they were getting ready to launch the new engine (1000cc) in 76 and redesigned a lot of things, some that were not necessary. (rubber diode mounts comes to mind)
Just a minor but important correction: the later bolts are 11mm, not 12mm . . .
'76 R90S silver smoke
'75 R90/6 hybrid
'Skills are learned, talent is ornate.' Billie
Max Headroom is offline   Reply With Quote
Old 04-28-2010, 02:33 PM   #194
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Thanks Max. I stand corrected. Don't know what I wuz thinkin.
But I still stand pat on the rest of the statement.
www.wirewerkes.com
Old 04-28-2010, 07:28 PM   #195
Rightshiftrick
Rightshiftrick's Avatar
Oddometer: 119
Nice, I need to get mine back to a proper Monza Blue. Will probably end up painting myself though, I've never been happy with other peoples work.
Had a chance to check out Dave Percival's collection up in Maine once. Talk about pre /7 BMW heaven!
1970 Norton Commando
1974 BMW R90/6
1980 Moto Guzzi v50
Rightshiftrick is offline   Reply With Quote
Times are GMT -7.   It's 03:34 AM.
