Old 10-19-2011, 07:52 PM   #3841
Switchblade315
Switchblade315's Avatar
Oddometer: 5,635
sounds like you picked up some trash in the pilot jet. I'd start there. next new plug. um air filter......... and the small ports in the back of the carb.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is online now   Reply With Quote
Old 10-19-2011, 07:54 PM   #3842
bobbed06
Cavalera Conspirator
Oddometer: 1,236
I agree....
bobbed06 is offline   Reply With Quote
Old 10-19-2011, 08:15 PM   #3843
Trailryder42
Trailryder42's Avatar
Oddometer: 1,061
If you were running 162 jetting then that suggests(even tho you didn't say) that the bike has intake and exhaust mods.
You say you ride near the Texas coast so that means near sea level. Dropping from a 162 to a 155 is 3 sizes. 155 with intake and exhaust mods and running at sea level is too lean, plus the weather cooling off would make things even leaner. I would suggest going back up to a 158-160.
You didn't say what your pilot jet is. You know that if you change the pilot, the fuel screw has to be retuned.
Is your gas cap venting the tank properly? Next time it dies after a run, unscrew the gas cap and see if you get a rush of air.
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Trailryder42 is offline   Reply With Quote
Old 10-19-2011, 11:34 PM   #3844
IronSpadeCycles
Button Pusher
IronSpadeCycles's Avatar
Oddometer: 234
Pipe is stock but baffle removed, and running a Uni filter with (5) 1" holes drilled on the right side of the airbox along the top. My DS battery sits in the top hole where the snorkel was. I can't remember what pilot jet is in there but I think it is one step up from stock and I'm running an NGK Iridium plug that is one step cooler to help with the continuous high speed runs. The 155 is what I had and I knew it might be too lean but my Trailtech Vapor is actually reading a cooler cylinder head temp with the 155, which really doesn't make any sense. I figured it might be the pilot circuit or the carb is just clogged. I haven't cleaned the filter all year but I really have only been riding on road on dry days. She was due for a basic tune and oil/filter change anyway before the trip but I just got nervous when this all happened.
Thanks for the info, I'll let you all know how it turns out tomorrow.
Talk soon Travis
www.theroadmuchlesstraveled.com
____________________________________
I'm a collector of fine crap!
IronSpadeCycles is offline   Reply With Quote
Old 10-20-2011, 03:25 AM   #3845
dazkarieh
Oddometer: 13
Eek
Im having the same problem. Take the cluch and she goes off. Sometimes i rev the engine and same thing happens. Going to the mechaninc today. ill tell you some good news if i have them. good luck
dazkarieh is offline   Reply With Quote
Old 10-20-2011, 07:37 AM   #3846
Trailryder42
Oddometer: 1,061
What kind of exhaust do you have? Is it the stock muffler or is it an aftermarket can with a packing material? Sometimes a packing material gets blown and obstructs the exhaust. The bike will idle but any throttle at all will kill it.
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Old 10-20-2011, 09:54 AM   #3847
Wallrat
Wallrat's Avatar
Oddometer: 681
Talk soon Travis
Might want to pull your plug and check it too. If you were running rich enough to carbonize your license plate, I imagine that plug is probably a tad sooty.
Wallrat is offline   Reply With Quote
Old 10-20-2011, 09:58 AM   #3848
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
you mean like this?
DrLewall is offline   Reply With Quote
Old 10-20-2011, 10:40 AM   #3849
TooSlow4U
2 Wheel Wonder Rider
TooSlow4U's Avatar
Oddometer: 1,090
Headlight help?
Hello fellow XR4 owners... I'm needing some help and keep turning up at dead ends. I was out last weekend enjoying some gravel roads here in southern Indiana aboard my '98 XR4 and collected a stone off of someone's rear tire ahead of me and broke the glass outta my headlight. The D/S kit that the previous owner installed on this bike appears to be the Electrex USA Dakar D/S Kit. Trying to find any contact info from Electrex USA has turned up nothing. I'm pretty sure (due to having to do some wiring repair a few months ago) that this kit has been updated since this was installed. Does anyone here know where I might be able to be just the new headlight so that I can replace just that, without having to buy a whole new kit? Will the headlight bulb/casing from something else fit into this as a direct bolt in that you know of? Any help is much appreciated... Thanks
Here is a pic of what it looks like just to give you an idea....
TooSlow4U is offline   Reply With Quote
Old 10-20-2011, 10:59 AM   #3850
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,184
Thirded.
Originally Posted by DrLewall View Post
you mean like this?
Have you considered blending your premix a little thinner?
Luke is offline   Reply With Quote
Old 10-20-2011, 02:28 PM   #3851
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
Originally Posted by Luke View Post
Thirded.
not my pic..but one that was just right for here..
Old 10-20-2011, 04:10 PM   #3852
Trailryder42
Oddometer: 1,061
Originally Posted by TooSlow4U View Post
Will the headlight bulb/casing from something else fit into this as a direct bolt in that you know of?..
It depends on how the lens is mounted within the plastic shroud. A lot of lenses are made to fit a specific mounting/shroud. Take the old busted lens out and take a picture of the back side of the lens and how it mounts to the shroud.
Then people that aren't familiar with the Electrex unit will have a better idea what lenses might be an option as a drop in replacement or with slight modification, if you're wanting to keep the Electrex shroud.
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Old 10-20-2011, 04:16 PM   #3853
TooSlow4U
TooSlow4U's Avatar
Oddometer: 1,090
Okay, I'll take it apart tomorrow when I get to work and get a few pics of it. From the front, it looks very similar to the light used in the BajaDesigns assembly. I'll post up some pics of the backside of it though. Who knows, maybe it's a match and I may be able to call B/D and talk them into selling me just the bulb casing, if that's the case. Thanks for your help on this.
Old 10-20-2011, 05:08 PM   #3854
stinkyfj60
stinkyfj60's Avatar
Oddometer: 2
Originally Posted by diesel1959 View Post
I bought my '97 XR400R from a fellow inmate but wanted more extensive lighting equipment for my inteneded useage. He was mostly dirt and I'm much more skewed towards road use. I swapped over to Connie TKC80's and had a Baja Designs DS kit installed. All the signals and brake/tail are LED. The headlight is an H4 PIAA 80w/80w lamp. Also, I added a second mirror, as it only had one from the PO. Power is provided through a Ricky Stator dual output 100w/100w brand new stator. The headlight is fed through one of the stator outputs and is still on AC, while everything else (including a LOUD horn) is fed through the second stator output to a voltage regulated battery pack to supply DC power. I'm very pleased with the result and I like the switchgear provided by BD with the kit.
I started with this:
http://diesel1959.smugmug.com/galler...18088217_vFYCE
http://diesel1959.smugmug.com/galler...18089292_nCkd3
and now have this:
http://diesel1959.smugmug.com/galler...18083320_k2TYC
http://diesel1959.smugmug.com/galler...18080228_sQzQL
http://diesel1959.smugmug.com/galler...18074890_cjdsC
http://diesel1959.smugmug.com/galler...18082441_ndXDx
http://diesel1959.smugmug.com/galler...18076966_wNYMV
And now the XR lives with me in Washington state :)
stinkyfj60 is offline   Reply With Quote
Old 10-20-2011, 08:56 PM   #3855
Gladly
Gladly's Avatar
Oddometer: 157
If it is the same, the BD lens assembly is listed on their site:
https://www.bajadesigns.com/NET/P-60...ght+Lens%2c+Bd
you could get one of these while you're at it:
https://www.bajadesigns.com/NET/P-60...igns+Headlight
'03 XR400R
Gladly is offline   Reply With Quote
Times are GMT -7.   It's 02:36 PM.
