Old 05-30-2012, 07:30 AM   #4591
Wallrat
Wallrat's Avatar
Oddometer: 298
Originally Posted by SpeedoJosh View Post
Is the edelbock carb interchangeable from the 250 to 400, or is that one of the parts that isn't able to just plug and play with either model?
I can't imagine it wouldn't need a jet change at the very least. Plus you're talking about different velocities/volume of air being drawn in. My guess is the 400 carb would make a 250 run like absolute crap down on the bottom due to the low volume of air being drawn across the venturi. Then again for all I know the 250 and 400 might use the same diameter carb throat.
07 450EXC
Wallrat is offline   Reply With Quote
Old 05-30-2012, 10:22 AM   #4592
GurgaonTrails
GurgaonTrails's Avatar
Oddometer: 94
Neutral
Finding neutral woes continue.
After the bike has warmed up, it's just a game of chance that I'll find neutral. So trail stops while waiting for others are really about holding the clutch in....cant be good. But yet, after the bike's cooled down, it snicks into neutral real easy.
Other than that all gears shift nice and easy while warm or running, and there's no trouble of any sorts.
What do I need to fix? Any ideas folks?
Could it be just as simple as a oil-change (due soon) or maybe I should put in a new clutch cable?
'04 Honda XR 400 | '08 Royal Enfield 500
Himalayan Ride Report 1997 | Ladakh again (2012)
GurgaonTrails is offline   Reply With Quote
Old 05-30-2012, 12:01 PM   #4593
bobbed06
Cavalera Conspirator
Oddometer: 956
A fresh clutch cable never hurts, then change the oil to Valvoline Racing 4t 10w 40 and if the problem still persists you need to check the clutch basket for notching. I doubt this is the case though and am fairly sure the problem will go away with the new clutch cable and oil change.
bobbed06 is offline   Reply With Quote
Old 05-30-2012, 08:24 PM   #4594
Wallrat
Wallrat's Avatar
Oddometer: 298
Is your clutch properly adjusted? I generally use the nickel trick. Should be able to just slide a nickel into the gap made between the lever/perch when you pull the clutch lever to remove slack. A hard to find neutral is almost always going to be the clutch not disengaging fully.
07 450EXC
Old 05-31-2012, 11:07 AM   #4595
birds
birds's Avatar
Oddometer: 125
Just had the same issue and it was the clutch cable starting to fray. Wish this discussion happened a week ago :
birds screwed with this post 05-31-2012 at 01:47 PM
birds is online now   Reply With Quote
Old 05-31-2012, 12:02 PM   #4596
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 495
Send a message via AIM to Clem Kevin Send a message via MSN to Clem Kevin Send a message via Skype™ to Clem Kevin
Go to a lighter oil weight, made a huge difference for me. I was using 15-40 and dropped down to 5-30 and I could find neutral a lot easier after that.
Clem Kevin is offline   Reply With Quote
Old 05-31-2012, 11:29 PM   #4597
GurgaonTrails
Oddometer: 94
Thanks guys. I'm going to try that nickel trick....wonder if it works with Indian currency :)
And yes, I was told my cable had just about started to fray.....so new one will go in this weekend. Along with a new perch....which was also showing age.
Adding in Motul 300v oil 10w40 (synthetic). That's just about the best available here.
Hope it sorts out....got a 3000km ride up in the Himalayas coming up. Taking photos without easy Neutrals will be a real bitch!
BTW - The XR will hit 18000 foot altitude, not sure if anyone's taken one that high up.
Old 05-31-2012, 11:56 PM   #4598
sectrew
sectrew's Avatar
Oddometer: 5
I have a full exhaust if anyone is looking. Fmf powerbomb header and a power core 4 muffler. it sits in my garage I don't own my xr anymore. It was on my bike for 200 road miles. Offers?
Sent from my PC36100 using Tapatalk 2
Rain in June
sectrew is offline   Reply With Quote
Old 06-01-2012, 12:28 AM   #4599
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 495
Where do you live? Is it a loud one?
Old 06-01-2012, 07:48 AM   #4600
Wallrat
Wallrat's Avatar
Oddometer: 298
You just want about 2mm of a gap between the lever and perch when you pull the slack out by putting some tension on the lever. A nickle is just easier to maneuver than a tape measure.
While you're getting one new clutch cable, might as well get 2. Zip tie the second cable to the one that's in use. That way if you ever have the cable snap while on a ride you can fix it in a minute or two.
07 450EXC
Old 06-01-2012, 10:05 AM   #4601
GurgaonTrails
Oddometer: 94
I love that second cable idea. In fact I read about it in a ride report just yesterday and planned on doing it. I'm glad you brought it up, because I had already forgotten .
I wish someone had experience with the double tubes in tire thing as well....would have loved to have that worked out before my trip....Tubliss wont reach me in time.
Old 06-01-2012, 01:22 PM   #4602
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,565
Double tubes won't work, to much heat build up and friction will shred an extra tube in a tire.
tbarstow is offline   Reply With Quote
Old 06-02-2012, 10:38 AM   #4603
GurgaonTrails
Oddometer: 94
Blinkers
I decided to put in turn signals (indicators/blinkers)
They do come ON, but dont blink....
Would anybody be able to offer suggestions?
Wanted to be sure they could work before drilling the mounting holes on the front light unit.
Oh also, would a 50watt bulb work for the headlight? Instead of the standard 30 or 35 watt it came with?
I have a Euro spec XR.....from what I've read on the thread they seem to have both AC and DC circuits....
And I have no real idea what I'm talking about when I say that......
Old 06-02-2012, 11:19 AM   #4604
Ed@Ford
Oddometer: 1,051
You really need to find a european XR service manual. The north american XR400 manual only covers our primitive AC electrical system. FYI, AC = alternating current...like what is in your house, but 12 volts...DC = direct current is like what comes out of a battery....otherwise the only thing i can say right now is that a turn signal flasher wants NOTHING to do with AC...so get on line, learn some electric basics and maybe find a cheap voltmeter....also, if you are going off into the Himilayas, I really doubt turn signals are worth the trouble. Make sure the clutch/transmission is 100% good instead.
Ed@Ford is offline   Reply With Quote
Old 06-02-2012, 12:47 PM   #4605
GurgaonTrails
Oddometer: 94
Hey thanks Ed. Well, actually I did kinda know what AC and DC was....I think I wanted to say the same thing as youd did.....what would blinkers not blinking have anything to do with AC or DC...
Bike's at a mechanic's, he's got the tools. Maybe he's not such an expert after all.
And yeah, clutch/transmission/tyres all good. One special addition for the commute up till there....putting in a horn!
Excited about taking a proper bike up there...been there three times on Enfields. That was nice, but this one should be nicer.
Times are GMT -7.   It's 04:03 AM.
