Old 02-19-2013, 05:01 AM   #5536
DrLewall
DrLewall's Avatar
Oddometer: 23,867
Originally Posted by cirell View Post
I know its already on here somewhere but can some one tell me if the stock stator will run a 55watt HID light? Or would I need to upgrade to a bigger stator.
it will..but remember, you're gettin close to the limit and if you have "other" items (brake lite, turn sigs, GPS, clock, Air conditioning, DVD player etc )that require some juice, you could be SOL..
DrLewall is offline   Reply With Quote
Old 02-19-2013, 07:21 AM   #5537
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 230
On the subject of draw, if all lights (turn sings, brake) were converted to LED and the say, BD headlight were still incandescent. Would the stock stator push a .68-1a or 10w LED supplemental headlight
Sent from my XT907 using Tapatalk 2
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 02-19-2013, 07:39 AM   #5538
DrLewall
DrLewall's Avatar
Oddometer: 23,867
I would think so...the stock stator would probably do okay, but with its limited output, you could be pushing its limits..as in anything in life, money, love, motorcycles in the garage etc, I have always tried to live by the rule that it is better to have enough than not enough...but a feller will do what he has to do and if you can get by with minimum, then give it a go, but also know that you assume the risks.
Old 02-19-2013, 08:07 AM   #5539
PCK_4xCustoms
lost
Oddometer: 230
ie. Toasting the stator.
Old 02-19-2013, 08:53 AM   #5540
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,565
It won't run a 55 or even a 35W HID, the stock stators output drops below the HIDs threshold wattage at idle, on a 35W HID the bulb will shut off at idle and try to restrike next time it's revved up, that eats into the HIDs lifespan pretty quickly. The 55W won't even strike as they have about a 70W initial surge requirment. I've attempted to run HID off one leg (100W) of a 200W stator and it had this problem even with the extra wattage. Problem is the stator's idle output, HIDs require a decent battery to suppliment the stator's output during that time.
Many people are fooled into thinking a 35W HID only uses 35W, that's pretty accurate for a good quality HID, many of the chinese systems use more than stated. The problem is they all have a large surge current when they first start up, around 15~20 amps higher than the 35 or 50W stated draw.
The stock system will run LED lights pretty well though with a DC conversion.
Chris
VIDEOS
RideFreak screwed with this post 02-19-2013 at 09:02 AM
RideFreak is offline   Reply With Quote
Old 02-19-2013, 12:52 PM   #5541
cirell
Oddometer: 60
Thanks Doc and Ride Freak for your replys, dont want to risk reliability but the head light is no good for night riding will look into 35 watt lights and Leds, My bike has a battery so may be ok
cirell is offline   Reply With Quote
Old 02-19-2013, 03:51 PM   #5542
blitchfield
blitchfield's Avatar
Oddometer: 130
Originally Posted by Luke View Post
First check to make sure there's some free play at the clutch lever..
I went to pull the clutch cover off and looky.. looky..
That's the clutch cable bent into the cylinder fin, cables kinked right there and I thought I just needed to lube the cable.
Even so I still pulled the cover and checked to see if the friction plates are within spec(looks good) so.. crossing my fingers that the cable is the issue
Thanks for the insight everyone
blitchfield is offline   Reply With Quote
Old 02-20-2013, 07:08 AM   #5543
Feelstranger
likely lurking
Feelstranger's Avatar
Oddometer: 21
Quick question - sorry to intrude!
Folks, sorry to interrupt your regular programing, but could one of you fine xr400 owners do me a favor?
I need the length of the forks from a 96-04 - axle center to top of tube. It would be greatly appreciated!
Nat
Feelstranger is offline   Reply With Quote
Old 02-20-2013, 08:06 AM   #5544
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,565
Nat
36" extended (no sag) center axle to top edge of the inner fork tube.
Chris
VIDEOS
Old 02-20-2013, 08:11 AM   #5545
Feelstranger
likely lurking
Oddometer: 21
Thank you much sir!
Old 02-20-2013, 09:27 AM   #5546
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,565
Thank you much sir!
That's +/- .25" I was pulling up on the bars and measuring while leaning over another mc, the 400 is buried at the moment
Chris
VIDEOS
Old 02-20-2013, 02:07 PM   #5547
Feelstranger
likely lurking
Oddometer: 21
No worries.
While I'm at it, could I get the measurement between the bolt holes on the caliper bracket mount of the forks?
Old 02-20-2013, 02:17 PM   #5548
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,173
No worries.
Since RideFeak's bike is buried, and mine's in the middle of the floor...
That's the bracket mounting tabs on the left-hand fork tube, not the caliper itself? That appears to be 103 mm, center-to-center.
Stretch67 is offline   Reply With Quote
Old 02-20-2013, 02:25 PM   #5549
Feelstranger
likely lurking
Oddometer: 21
Exactly.
Thanks again y'all
Old 02-20-2013, 03:47 PM   #5550
roadracer
roadracer's Avatar
Oddometer: 303
Does anyone know how fast the xr400 will cruise with stock gearing? I'm headed to mexico in two weeks and I'd like to run high way speeds.
Thanks to Scuderia West for their support in the 2013 Mexican 1000
roadracer is offline   Reply With Quote
Times are GMT -7.   It's 12:59 AM.
