03-11-2013, 05:46 PM
#5641 |
Oddometer: 23,806
yes..pix please..I gotta see this!
03-12-2013, 09:43 AM
#5642 |
919 excuses to ride!
Oddometer: 408
The small piece was still in place with the bent pin attached when I stopped to fix it. I loosened the axle, removed the small piece and pinched the remaining section of the bracket in place just to ride back to the truck. Rocky Mountain ATV has that part on sale for $118. I guess I have no choice. I'm not paying $91 off ebay for a used one.
![]() I'm still confused how it exactly happened. I was pounding on the bike, but nothing unusual. The old XR was hanging with a AA Pro racer on a new-to-him '12 KTM EXC 500, leaving his friends on a KXF 450 and XCW 300 in the dust. I love this bike.
He is his own best friend and takes delight in privacy, whereas the man of no virtue or ability is his own worst enemy and is afraid of solitude. -Aristotle '01 Honda XR400, '04 Honda 919 |
03-12-2013, 11:15 AM
#5643 |
Oddometer: 23,806
![]() HDF did you do that? I aint never seen that before..will be keeping an eye out for mine tho..good luck! |
03-12-2013, 11:16 AM
#5644 |
Oddometer: 314
Weird. Was the rear axle nut tight?
03-12-2013, 11:50 AM
#5645 |
Oddometer: 408
It was plenty tight. I went down on that side a few times previous to that during failed hillclimb attempts
, but there are no marks on the caliper or guard like it took a hard hit. The only thing I can think is that there was a reason that all the pressure of the axle nut was being placed on the part that stayed in after it broke, leaving all the vibrations to put leverage that one spot. If the entire "U" had even and equal clamping force on it, it wouldn't have been able to come out, or break in the first place for that matter. Either there was a proud spot in the rear of the casting, my inner swing arm surfaces aren't parallel, or my chain tightening cams aren't accurate and my axle was cocked to the left.I am still trying to figure out how it got out after it broke. It would have had to slide forward rather than backward due to the remaining part of the "U", and how did that pin bend like that?!!! The bent pin makes me think it was a violent action rather than vibration.
03-12-2013, 02:53 PM
#5646 | |
Oddometer: 1,050
03-12-2013, 02:54 PM
#5647 | |
Oddometer: 408
![]() Thank you!
03-12-2013, 03:31 PM
#5648 |
Oddometer: 23,806
03-12-2013, 05:00 PM
#5649 | |
Marky A
Oddometer: 746
2008 Kawasaki KLR650 2006 Honda ST1300 2001 Honda XR400R Colorado Dual Sport Riders http://motodelmundo.blogspot.com/ |
03-12-2013, 05:14 PM
#5650 |
Oddometer: 408
From what I understand, these bikes were listed as having high tensile steel frames. Chromoly is high tensile steel, just a high-end grade alloy at the upper end of the "high tensile" grading system. I'm pretty sure they would have bragged about using chromoly rather than just HT steel. Having successfully welded parts of my frame without heat treating it (with no stress cracks over the years), I would vote against it being chromoly.
03-13-2013, 07:26 PM
#5651 |
Oddometer: 408
I just got an email from the pro-level rider I went out riding with on Saturday. I had to share part of his email here. Classic.
"Today I was heckling Chris (KX450 rider) about playing his crashes on the big screen at work. He said "Ryan gets around great on that XR400". He was probably thinking the same thing as I was when I first rode with someone on a XR400, thinking it will be a slow ride, then when they take off, OH CRAP, I hope I can keep up with that Dinosaur. Funny how no matter how much bling someone puts on their bike, it doesn't make you a better rider, just a rider with less money."
03-14-2013, 04:06 AM
#5652 | |
Oddometer: 2,424
Ride what you want to ride and have fun. I have three bikes one is a xr400. I like it and it is fun only thing i would change is better brakes and better suspension. Motor is fantastic for they type of riding i do. |
03-14-2013, 05:40 AM
#5653 | |
Oddometer: 23,806
I loves me little ole dinosaur! Edit: Signature material.."Funny how no matter how much bling someone puts on their bike, it doesn't make you a better rider, just a rider with less money." DrLewall screwed with this post 03-14-2013 at 03:55 PM |
03-14-2013, 11:08 AM
#5654 |
Mad Scientist
Oddometer: 3,164
Dang right. I've been riding trail bikes for over thirty years, but none of them were bigger than 250cc, and they were decades-old four-strokes at that. I had to learn better throttle control on the XR4. You'd better have the bike pointed in a safe direction, 'cause when you snap the throttle open, this puppy moves.
You've got a bike the size and weight of a 250, but with half-again more cc's. Kinda like a sleeper hotrod with a big-block.
03-14-2013, 03:11 PM
#5655 |
Oddometer: 1,020
Electric Start
I finally got the short crank extension piece from Switzerland ($400) and was a little surprised. I had to purchase 3 new bearings at $20 each to use the new part. Than I had to machine out the ring gear to fit the new bearings with a lathe. The instructions were basically nonsense. I decided to pay a professional to do the install to give me a little peace of mind. My mechanic started on my bike late today, I should know how it went tomorrow and I'll post here.
JimmieA. Atlantic Canada. 2008 Honda XL1000V Varadero 2004 Honda XR400R |
