Old 03-14-2013, 09:46 PM   #5656
Fishnbait
Fishnbait's Avatar
Oddometer: 43
Bearings
I need to replace my steering stem bearings and probably some rear suspension bearings. Does anybody have a preference on brand? Like All Balls, Pivot Works or OEM.
Any input good or bad is appreciated.
08 Versys
08 KLX450
01 XR400
Fishnbait is offline   Reply With Quote
Old 03-14-2013, 11:56 PM   #5657
Clem Kevin
Nude With Boots
Oddometer: 980
I've been replacing most of my bearings and I chose to go OEM, I feel like its the safest choice, if that's any help to you.
Clem Kevin is offline   Reply With Quote
Old 03-15-2013, 01:11 AM   #5658
JimmieA
Oddometer: 1,276
Originally Posted by Ed@Ford View Post
holy crap...for that kinda $$ you coulda bought a whole newrebuilt 400 crank/rod assembly from wiseco and other suppliers....a few more $$ & you coulda got a stroker and made a 460 cc e-start XR!
My bike is basically brand new babied it's whole life. I didn't want to break the cases and change the crank so the crank extension. I have an EX400 crank here as well so that was an option. I'm concerned about this crank extension. The end of the crank is cone shaped with a key way. The new piece is not coned inside, it is straight so I'm worried about this a bit.
JimmieA.
Atlantic Canada.
2008 Honda XL1000V Varadero
2004 Honda XR400R
JimmieA is offline   Reply With Quote
Old 03-15-2013, 06:21 AM   #5659
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,953
Under no circumstances would I run the engine like that. If the part's not made right, it's not made right, regardless of its price or intent.
Since you already have the EX crank in hand, why not do it right the first time and have it installed?
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 03-15-2013, 06:25 AM   #5660
Ed@Ford
Oddometer: 1,681
OEM = Japanese parts
Others = chinese
I can say I've had no issues with chinese trailer wheel bearings....but their seals are junk
Ed@Ford is offline   Reply With Quote
Old 03-15-2013, 06:29 AM   #5661
Ed@Ford
Oddometer: 1,681
I've seen variations on the extension piece...all were conical shaped..this variant sounds like junk....making the double cone bit properly....high precision...very difficult to do... I think you've been had.
Old 03-15-2013, 07:07 AM   #5662
Rojobandito
Rojobandito's Avatar
Oddometer: 77
Valves
I have the head pulled off. I need someone to inspect it and maybe port and polish. I was wondering if any fellow xr owners have done a port and polish with a small overbore(maybe 416 or 426). Is the port and polish worth it? Can anybody recommend someone in the Portland, OR area to do this??
Rojobandito is offline   Reply With Quote
Old 03-15-2013, 07:16 AM   #5663
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,442
I'd send it off to XRs only, they do allot of 400s, it pays to go to someone with specific knowledge of a particular motor. The 426cc is a very reliable overbore that doesn't stress the bottom end too much, I think the 416 is a 4th overbore of the stock cyl, not much gain there.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-15-2013, 09:17 AM   #5664
JimmieA
Oddometer: 1,276
The cone bit is OK on the outside but not in the inside to match up with the XR400 cone. It is straight on the inside. I have a mechanic doing the work so I trust he will spot an issue if there is one. I just ordered a 200 watt stator so it will take a couple days for that to come in. Might as well put the right stator in while it is apart. Need the juice to charge the battery anyway.
JimmieA.
Atlantic Canada.
2004 Honda XR400R
Old 03-15-2013, 10:02 AM   #5665
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,241
Ron Black (RB Designs) did a really good job with mine. It was a slight overbore and valve cleanup. http://www.rb-designs.com He's in the West Hills. Email's the best way to get a hold of him.
Luke is offline   Reply With Quote
Old 03-15-2013, 02:49 PM   #5666
Danne
Oddometer: 1
Rear susp
First post.. Picked up my Xr400 about a month ago, turned out my father in law had one sitting in his garage.. Still about zero to 10 below here in sweden so riding is quite a challange. Put a new petcock and cleaned the carburettor so far and now its time to adjust the (rear) suspension.
The preload is at its lowest setting (standard spring) and i need to stiffen it. I'm about 100 kg with gear. Anybody got a clue where to start from?
Cheers
Daniel
Danne screwed with this post 03-15-2013 at 02:50 PM Reason: ..
Danne is offline   Reply With Quote
Old 03-15-2013, 05:26 PM   #5667
Stretch67
Stretch67's Avatar
Oddometer: 6,953
Here's a good overview...
http://www.4strokes.com/tech/racesag.asp
IBA # 33113
Alaska
XR400 Index
Old 03-16-2013, 04:27 PM   #5668
Stretch67
Stretch67's Avatar
Oddometer: 6,953
Man ALIVE, I love this bike!
IBA # 33113
Alaska
XR400 Index
Old 03-16-2013, 05:56 PM   #5669
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,334
uh...me too!
DrLewall is online now   Reply With Quote
Old 03-17-2013, 07:01 AM   #5670
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,121
Nice sig line, Dr. Lewall! I think I've seen that somewhere before!
I hate bear grass.
XR4EVER is offline   Reply With Quote
Times are GMT -7.   It's 03:34 PM.
