Old 05-06-2013, 10:33 AM   #5866
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 681
Anyone know where I can get an electric start kit or at least the crankshaft extension?
aaron2a is offline   Reply With Quote
Old 05-06-2013, 06:57 PM   #5867
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,301
Originally Posted by DrLewall View Post
Oh thanks alot for making me re-live that night mare!
Madness takes its toll... please have exact change.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is online now   Reply With Quote
Old 05-06-2013, 07:07 PM   #5868
hughrk
hughrk's Avatar
Oddometer: 68
Originally Posted by DREAMADVENTURER View Post
Well i was hoping that my first post here would be about showing you my new to me XR400 1996 model but luck was never on my side..............
anyway i bought it 1 month ago and my purpose was to bring back to mint condition (plus the fact that im a mechanical engineer but i always told people how to fix staff but never layed a hand and i thought it was time to change that)
Anyway while checking it i realised that the front and back suspension was sugged (forgive my english) so i decided to take the bike apart fix and grease everything and while i was at it, paint the frame etc
so the nightmare began, i couldn take off the swingarm pivot bolt, i read everything on the net, i saw images i didnt want to see ( I still see nightmares about cutting the swingarm) I tried every possible solution, i loosened the engine supports, i raised the bike, i took off the rear suspension, i used heat, i used locktight freeze, wd40, penetrating oil
i used raw force..................nothing
i decided to drill it hopping it would break free or get loose but..............NOTHING
what i managed to do is break the head of the bolt loose but i still cant get any drill bigger than 10mm inside (I think its a matter of tools to be honest)
anyway in a moment of brilliance i decided to use a hacksaw (im not sure if this is how its called) and cut the bolt right next to the frame.....you know...right next to the dust cups.....which i did
Now what? i dont want to cut the swingarm and i dont have a room to use a circular saw, i tried with a dremel but the bushing is very hard the room is very tight and nothing
so here is my big idea and i want your opinion guys on that
As i said the bolt is free from the frame at both sides, so provided that the rear wheel is off and i remove the carburator and all the electrics from the frame if i remove the engine will i free also the swinarm with it?
i mean there is a pivot, if i take the engine off the right side of the frame and tilt it on its side, i think that the swingarm will clear the frame and because there is a pivot point i will be able to get it free
after that i will take the engine and swingarm to a machine shop and hopefully the will manage to release the engine and swingarm
so what do you think?
will it work?
anybody else has done something similar?
any opinions, experiences or ideas on the subject are welcome
You are on the right track, drill out both ends of the bolt then take the engine and swing arm assy out of the frame.
Once on the ground you can put a socket under the pivot, block the swingarm and engine then swing a BIG hammer at that bolt, and I mean BIG.
You are aiming to move the bolt the width of a hacksaw blade, this will allow you to insert a hacksaw blade between the bush in the casing and the bearing bush. You will have to insert the blade then connect the tool frame at a 90 degree from normal angle. Turn over the assy and repeat, job almost done. Just the bit of bolt left in the casing which is easy, one of the bush's will probably come out with the bit of bolt, just split them in a vice.
If you get really, really stuck then cut up your swingarm but its probably not required.
Thats how this Mechanical Engineer did it
hughrk is offline   Reply With Quote
Old 05-06-2013, 07:12 PM   #5869
Stretch67
Stretch67's Avatar
Oddometer: 6,301
All this so Honda could save three cents worth of grease per bike.
IBA # 33113
Alaska
XR400 Index
Old 05-07-2013, 12:56 AM   #5870
FSRIDER
This guy rides a lot
FSRIDER's Avatar
Oddometer: 66
OK let's try these pictures again...
FSRIDER screwed with this post 05-07-2013 at 01:15 AM
FSRIDER is offline   Reply With Quote
Old 05-07-2013, 01:16 AM   #5871
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Old 05-07-2013, 01:18 AM   #5872
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Old 05-07-2013, 01:18 AM   #5873
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Old 05-07-2013, 01:27 AM   #5874
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Old 05-07-2013, 03:20 AM   #5875
TARider
Oddometer: 130
XR400 E-Start
I bought extension from Boechat. http://www.boechat.ch/fr/p4-4113.html
Almost everything else I bought used through ebay. Most of Honda atv 400ex parts work for conversion. Some machining needed to done on starter ring in order to fit appropiate bearings. I may have manual copy scanned somewhere. PM if you need it.
Save the drama for yo Momma
1990 Transalp
1985 XLV750R
2004 XR400R E-Start
TARider screwed with this post 05-07-2013 at 03:28 AM
TARider is offline   Reply With Quote
Old 05-07-2013, 03:43 AM   #5876
FSRIDER
FSRIDER's Avatar
Oddometer: 66
XR400 estart
How much does it cost to convert to estart?
Old 05-07-2013, 03:58 AM   #5877
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,898
last time I checked, was around $1400..I think that was for a kit that was available a few years ago..If I remember right that is
DrLewall is online now   Reply With Quote
Old 05-07-2013, 04:29 AM   #5878
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Eek
OUCH! I think I will just keep kicking mine over.
Old 05-07-2013, 06:01 AM   #5879
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,000
I'm just a lowly technician w/o the benefit from years of schooling but I'd press the bolt out using some heat and a hydraulic shop press. I like to avoid the BFH at all costs, it's never pretty.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-07-2013, 06:29 AM   #5880
hughrk
hughrk's Avatar
Oddometer: 68
So would I but if you dont have that sort of a workshop available to you then BFH it is.
Times are GMT -7.   It's 11:54 AM.
