Old 05-12-2013, 05:15 PM   #5911
Wallrat
Wallrat's Avatar
Oddometer: 672
Originally Posted by FSRIDER View Post
I would say so. I thought it was free and clear when I put it together but at some point while riding it rubs. I learned the hard way, had to replace my first chain after a few hundred mikes with the 16T and case guard.
I ran 14/40 and 15/40 and managed to keep my aftermarket case saver in place without rubbing. Gear ratio is almost the same as 15/45 and 16/45.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is online now   Reply With Quote
Old 05-12-2013, 05:21 PM   #5912
FSRIDER
This guy rides a lot
FSRIDER's Avatar
Oddometer: 66
I'm rocking 16/38 on my street set up, and 14 /42 on my dirt wheels and tires. The 14/42 puts me back to the stock gear ratio and the 16/38 gets me 53 mpg on the freeway. Just takes about ten min to change wheels out and countershaft sprocket, but the chain fits both.
2003 XR400 LEGIT!
Link to my 2010 OBCDR RR http://advrider.com/forums/showthread.php?t=596782
FSRIDER is offline   Reply With Quote
Old 05-14-2013, 07:50 AM   #5913
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,090
A few pics from over the weekend
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 05-14-2013, 08:31 AM   #5914
FSRIDER
FSRIDER's Avatar
Oddometer: 66
Thumb
Looks like you guys had fun. I love Idaho
2003 XR400 LEGIT!
Old 05-15-2013, 04:03 AM   #5915
JimmieA
Oddometer: 1,253
Looking for wisdom from the members here. I have ordered a Acerbis 5.8 gallon tank and a Moose Racing back rack for the bike (2004 XR400). I plan to do a 1000 mile road/off road trip on the bike. Newfoundland's T'rail that is the old railroad bed. I want to be able to camp and carry the necessary gear on the bike.
I'm thinking I maybe better off with a more highway friendly rear sprocket. I won't be going freeway speeds but there will be hours of pavement involved on the trip. I also want advice on a set of soft panners for the bike. I have a street legal tail light and signals on the bike and the back rack is higher than normal to clear this.
JimmieA.
Atlantic Canada.
2008 Honda XL1000V Varadero
2004 Honda XR400R
JimmieA is offline   Reply With Quote
Old 05-15-2013, 08:00 AM   #5916
XR4EVER
XR4EVER's Avatar
Oddometer: 1,090
As far as the gearing goes, personally, I would find a comfortable rear sprocket for pavement riding (like a 43 rear) that keeps the stock 15t front sprocket, and carry a 13t to swap out if you find yourself in areas where that setup is just too high. They are cheap, it takes only a minute or two to swap out, and in my experience, a middle-ground compromise in gearing is always a disappointment in all terrain. One thing that plagues these bikes is a narrow gearbox; you can either have all low gears or all high gears. If Honda would have put a really tall "highway" 6th gear in the box, OMG would these be awesome bikes.
I hate bear grass.
Old 05-15-2013, 09:24 AM   #5917
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 260
What I've found to be a sweet spot on mine is a 40 rear with a 16 front for street, cruises very nice at 60mph and still has the ability for trail.
But, carry a 13 front and it will put you at a stock ratio for really playing off road.
Downside is you may have to remove a link from stock length chain.
Otherwise, its a fantastic setup IMHO.
Sent from my XT907 using Tapatalk 2
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 05-15-2013, 02:07 PM   #5918
FSRIDER
FSRIDER's Avatar
Oddometer: 66
It just depends on how fast you want to comfortably cruise at. Here are links to a couple websites I used to figure out what sprockets I went with:
http://www.gearingcommander.com/
http://srs6.com/gearratiochart.html
The second one is just a simple chart that I actually printed and stuck on my wall in the garage.
This can be as complicated as you want it to be, but based on what you want to do, I would just buy a 16T and stick it in your tool kit if you want a few less RPM's on the roads. Ive found the stock gearing to be pretty good all around set up, you can easily cruise at 50MPH without being too wound up.
2003 XR400 LEGIT!
Old 05-15-2013, 09:10 PM   #5919
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 316
Anyone have any feedback on conn rods for the XR4?
Yep, it's that time. I'm leaning to just going Wiseco, but if there's something better at a decent price.....
FYCYFF (Dakar 2011)
'98 XR400R, Rokon , '81 GL1100, '15 TW200
SDAR, CORVA
Go, Antonio, go!
Czechsix is offline   Reply With Quote
Old 05-15-2013, 09:50 PM   #5920
mookybird
Gramps
mookybird's Avatar
Oddometer: 213
I run 16x39 and carry a 13 for when I want it, the chain works fine without needing to add or remove links. It puts at 55 to 60 and 70 doesn't seem unreasonable. I run the mt43 on the back and the large diameter also helps a bit.
Ran this combo thru ten states last fall without any issues.
mookybird is offline   Reply With Quote
Old 05-15-2013, 10:54 PM   #5921
Ride38
Oddometer: 34
Gearing
Ya, I've run a few years now on 16/40.
With a light Dremmel to the case and a bit of feathering on steeper trails it actually seems to work ok. I'm mostly forestry trails though. -As everyone's stating, replacing to a 13 for full-on days is easy.
My only complaint is a peculiar speed wobble that occurs around 65mph, even with a fork brace & balanced tire. It almost seems more RPM based because it doesn't happen on higher revs at 70mph.
Then again, I really think Uncle Honda frowns that this bike's modded to 70mph but it sure is nice getting to the trails faster.
Ride38 is offline   Reply With Quote
Old 05-15-2013, 10:59 PM   #5922
FSRIDER
FSRIDER's Avatar
Oddometer: 66
I was actually impressed by how this bike handled on the freeway. Its just as stable as my DR650 was at high speeds. Maybe a little more vibratiin , but nothing I can't handle.
2003 XR400 LEGIT!
Old 05-16-2013, 02:42 PM   #5923
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 686
I don't get speed wabbles until I hit triple digits.... I was running 16\40 and topped out at 97ish with zero wobble. Now 16\38 I get speed wobble at top speed which I haven't rechecked since changing sprockets (no speedometer... Use phone GPS to see top speed) supermoto 17" wheels but 50/50 tires if it matters.
aaron2a is offline   Reply With Quote
Old 05-16-2013, 03:21 PM   #5924
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
I have mine geared for the trail..55 is tops for me!
DrLewall is offline   Reply With Quote
Old 05-16-2013, 08:32 PM   #5925
fuel-cycle
3 wheels or less 49CFR571
fuel-cycle's Avatar
Oddometer: 427
Originally Posted by DREAMADVENTURER View Post
Now i ll have to try and get the bolt out without damaging the rest of the swingarm because while trying to cut the endcups i did this
Before you cut ... try Kroil http://www.kanolabs.com/ it is amazing stuff for 'rusty parts' and it worked for me
Also this tread may be helpful on dealing swingarm bolt issues
http://www.advrider.com/forums/showthread.php?t=532835
Good luck!
fuel-cycle is offline   Reply With Quote
Times are GMT -7.   It's 11:16 AM.
