Old 05-17-2013, 07:19 AM   #5926
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,087
Ahhh... Good ole' Kreeping Kroil!
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 05-17-2013, 09:37 AM   #5927
XR4EVER
XR4EVER's Avatar
Oddometer: 1,087
I have nothing to add, I just wanted my 400th post to be here!!
I hate bear grass.
Old 05-17-2013, 09:42 AM   #5928
JimmieA
Oddometer: 1,238
I ordered the 16 tooth sprocket. I am in the process of finishing the electric start conversion. I have to finish wiring a 200 Watt stator into the harness and that is causing a little stress. I have to build a battery box as well as wire in a starter solenoid. Have a 5.8 gallon tank and a back rack at the border to pick up soon. Looking forward to getting the bike dirty!
JimmieA.
Atlantic Canada.
2008 Honda XL1000V Varadero
2004 Honda XR400R
JimmieA is online now   Reply With Quote
Old 05-17-2013, 10:53 AM   #5929
Ed@Ford
Oddometer: 1,584
Used a LOT if kroil...soaking my swing arm bolt for weeks...did nothing...heat...that was the magic solution...BUT the swing arm ended up cut to bits
Ed@Ford is offline   Reply With Quote
Old 05-17-2013, 01:35 PM   #5930
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,196
am busy with SLAP this week, but next week, I am going to do a write up on suspension Tune'n, with pix..on my 400 in particular...you'll hafta tune yours to you
DrLewall is offline   Reply With Quote
Old 05-17-2013, 02:16 PM   #5931
birds
birds's Avatar
Oddometer: 249
Can't wait!
birds is offline   Reply With Quote
Old 05-17-2013, 02:18 PM   #5932
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,450
Looking forward to it.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 05-17-2013, 05:55 PM   #5933
Ride38
Oddometer: 34
Ride38 is offline   Reply With Quote
Old 05-17-2013, 06:12 PM   #5934
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,196
I have nothing to add, I just wanted my 400R post to be here!!
fixt!
Old 05-17-2013, 06:56 PM   #5935
Stretch67
Stretch67's Avatar
Oddometer: 6,450
Zing!
IBA # 33113
Alaska
XR400 Index
Old 05-17-2013, 07:21 PM   #5936
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 899
Where do you plan on putting the battery box? I have a tool canister opposite of my exhaust under the subframe and I'm struggling to imagine anywhere else a decent battery would fit?
Clem Kevin is offline   Reply With Quote
Old 05-17-2013, 07:49 PM   #5937
Ride38
Oddometer: 34
Battery
I put the battery under left side cover after fabbing a bracket to the sub. I used to have one of the old "dual-tool" kits there but it had to go to make room. No regrets.
Ride38 screwed with this post 05-17-2013 at 07:56 PM
Old 05-17-2013, 08:43 PM   #5938
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,367
I found that a small lithium fits between the gas tank and frame.
n16ht5 is offline   Reply With Quote
Old 05-17-2013, 09:10 PM   #5939
Stretch67
Stretch67's Avatar
Oddometer: 6,450
Dude, seriously... the very last place I would put a Lithium battery is under a gasoline tank.
IBA # 33113
Alaska
XR400 Index
Old 05-18-2013, 01:14 AM   #5940
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 899
What is that reservoir for? Where would I find one?
Times are GMT -7.   It's 10:57 PM.
