Old 07-16-2013, 06:10 AM   #6301
marc11
Oddometer: 147
Originally Posted by krebsatm02 View Post
I could never get the temp ring over the spark plug and all the way down into the cylinder head. Trail tech said the xr400's are too deep and narrow and suggested putting it on a bolt on the cylinder head instead. This worked horribly on an air cooled engine as the temp would swing 100 degrees.
Ah thanks. You saved me from buying the temp ring. I have it all set up using a drz kit except for the temp. Wont bother now.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
2007 BMW R1200RT
2002 Honda XR400r
marc11 is offline   Reply With Quote
Old 07-16-2013, 09:29 AM   #6302
XR400R99
XR400R99's Avatar
Oddometer: 31
Shifting Woes
Hi Group,
I think I have a broken shift spindle spring. When downshifting, I have to lift the shift spindle up manually to continue downshifting, for each gear. Has anyone experienced this? Thanks in advance for your input.
XR400R99 is offline   Reply With Quote
Old 07-16-2013, 09:48 AM   #6303
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,122
Originally Posted by XR400R99 View Post
I think I have a broken shift spindle spring....
Thumper Talk has been fairly worthless lately, but the XR250/400 section has a select few contributors who are very knowledgable and eager to help with the inner workings of these bikes. They might even send you free parts to help you fix it like they did for me! Try posting over there if no one knows here: http://www.thumpertalk.com/forum/18-xr250400/
XR4EVER is offline   Reply With Quote
Old 07-16-2013, 04:38 PM   #6304
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,368
I think you guys are over thinking the oil temp..I mounted the sensor on the head/frame mount bolt..closer to the head...and then I took a meat thermometer and checked the temp. The head temp will be hotter than the oil temp and if you see here in the pix, there is abt a 40 deg difference..so what ever is read on the display, your oil is going to be abt 40 degs cooler..if it says 200, then figure your oil is at abt 160 etc
actual oil temp
DrLewall is online now   Reply With Quote
Old 07-16-2013, 04:42 PM   #6305
XR4EVER
XR4EVER's Avatar
Oddometer: 1,122
Originally Posted by DrLewall View Post
[/URL]
If there is a Mrs. Lewall, I hope she didn't see that pic!
Old 07-16-2013, 06:51 PM   #6306
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,474
+1, You've got to be pretty hard on the XR4 to toast the oil, harder than most of us are capable of riding it.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 07-16-2013, 07:53 PM   #6307
81eagle
Oddometer: 5
Originally Posted by MartiniUp View Post
Stock? That's no fun, get in there and screw something up!
No way!!!! I rode it from 5000ft to 9900ft today and it ran great the entire time. I aint touchin' nothin'!!!! Except maybe a 440 kit and a pumper carb.
81eagle is offline   Reply With Quote
Old 07-16-2013, 09:59 PM   #6308
KilLeR Kawasaki
Marky A
KilLeR Kawasaki's Avatar
Oddometer: 968
Please show a pic of where you have the sensor attached. It does not want to go around the spark plug and in that inaccessible chasm.
actual oil temp
2008 Kawasaki KLR650
2001 Honda XR400R
2007 Suzuki Bandit 1250
Colorado Dual Sport Riders
KilLeR Kawasaki is offline   Reply With Quote
Old 07-17-2013, 02:32 AM   #6309
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,368
I will get a pic later today for ya...and you are correct, it will NOT go down into that spark plug chasm...I just woller'd out the hole a little to fit over the engine mount bolt on the head and put it there. And since I did not have it mounted where the instructions suggested, I wanted a better idea of what my oil temp would be, thus the meat thermometer test...it's not perfect, but I at least have an idea of just abt what the oil temp is, and so far, I have yet to exceed 200 degs on "actual" oil temp..I've come close to it, but haven't gone over 200.
Old 07-17-2013, 06:32 AM   #6310
krebsatm02
Oddometer: 20
Honestly, I'm just a dork and like to know things. Turns out I over analyzed the situation. What looked to be a small tube is actually the rectangular box steel that is the actual structural frame. I welded up the small hole in that and then patched the larger hole I used for exploratory surgery.
krebsatm02 is offline   Reply With Quote
Old 07-17-2013, 10:06 AM   #6311
KilLeR Kawasaki
Marky A
Oddometer: 968
How do you feel about adding it to the banjo bolt on the oil cooler or the oil reservoir down tube?
2001 Honda XR400R
Old 07-17-2013, 11:32 AM   #6312
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,368
I suspect that would be fine, but in my book, right now my oil system is closed and not leaking and I know that if I open it up to insert a sensor, that SOB will leak or weep oil from now on..for me, I can live with the head bolt mount.
If you mount it up that way, take some pix and post up a report here for us all, pretty please?
tnx
Old 07-17-2013, 11:40 AM   #6313
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,368
Oil Temp Sensor, Trail Tec Display
As promised, here are some pix of how I mounted the sensor on the head.
This is for the Trail Tech Vapor
View of the motor's left side
Here you can see the sensor mounted to the engine mount bolt on the head
On the frame under the fuel tank is a cable clamp/support. Run the sensor wire thru it as shown
sorry for the fuzzy pic
Old 07-17-2013, 11:46 AM   #6314
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,368
had the camera so took a pic..saddle bags and all
Old 07-17-2013, 12:07 PM   #6315
krebsatm02
Oddometer: 20
Here's my fubar...
Original hole is on the bottom left on the cut of the hole saw.
Inspection hole...
Patched with temp sensor bung, don't mind where the welder decided to start sputtering. I'll fix it when I tear everything down this winter and powder coat the frame.
Times are GMT -7.   It's 04:05 AM.
