Old 07-17-2013, 12:28 PM   #6316
KilLeR Kawasaki
Marky A
KilLeR Kawasaki's Avatar
Oddometer: 964
Thanks for posting. That does seem a little bit removed and not a terribly responsive site. Kreb's solution seems very invasive, but effective. I'm thinking I'll attach to an oil line banjo bolt on my next oil change (as the bike is self changing the oil very effectively, that may be this fall!).
Originally Posted by DrLewall View Post
As promised, here are some pix of how I mounted the sensor on the head.
This is for the Trail Tech Vapor
View of the motor's left side
Here you can see the sensor mounted to the engine mount bolt on the head
On the frame under the fuel tank is a cable clamp/support. Run the sensor wire thru it as shown
sorry for the fuzzy pic
2008 Kawasaki KLR650
2001 Honda XR400R
2007 Suzuki Bandit 1250
Colorado Dual Sport Riders
KilLeR Kawasaki is offline   Reply With Quote
Old 07-17-2013, 12:41 PM   #6317
krebsatm02
Oddometer: 20
If I would have been 3/4" over with my original 1/2" hole I wouldn't have done such an invasive job. Thankfully I work in a shop with machine tools, etc... If I wouldn't have been in such a rush I probably would have figured out I should have angled the bung towards the top and not the front so the lead would be more out of the way. I don't think it will be a problem the way it is though.
krebsatm02 is offline   Reply With Quote
Old 07-18-2013, 07:42 AM   #6318
jbakerinc
Oddometer: 13
Can anyone let me know the tubing diameter of the rear subframe where it peeks out underneath the number plate down to the driver footpegs. I want to try to fashion some rear pass. pegs and forgot to measure the diameter..
and a fresh pic!!
jbakerinc is offline   Reply With Quote
Old 07-18-2013, 07:52 AM   #6319
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,594
and a fresh pic!!
before you tackle passenger pegs, you best figger' out a way to beef up the subframe for a passenger..remember, the XR is a single rider dirt bike, not a two up cruiser.
DrLewall is online now   Reply With Quote
Old 07-18-2013, 08:07 AM   #6320
jbakerinc
Oddometer: 13
I realize this. I am resprung and have beefed with bracing. im well aware of the load rating and functional limitation of the stock xr400. I was just wondering if someone knew the diameter...
Old 07-18-2013, 08:23 AM   #6321
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 686
I've got a second rear subframe... I'm gonna add a 12 bar and "passenger pegs" but their gonna be for stunts not a passenger :)
aaron2a is offline   Reply With Quote
Old 07-18-2013, 08:29 AM   #6322
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,594
you should be gettin that part I sent ya soon, so be alert
Old 07-18-2013, 08:45 AM   #6323
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 686
I've been to the mail box more in the last couple day than I have all month :) I feel withdrawal symptoms setting in... I got my new tires on the rims all I need now it to put that part in add oil and ride. Btw
Do you have a kickstand? I'll buy it from you if you do...
Old 07-18-2013, 08:48 AM   #6324
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,594
sorry, aint got one..a spare would be nice to have tho..
Old 07-18-2013, 09:32 AM   #6325
MartiniUp
Oddometer: 1,928
Originally Posted by RideFreak View Post
+1, You've got to be pretty hard on the XR4 to toast the oil, harder than most of us are capable of riding it.
But you have to remember,,,,,,,,,stupidity abounds!
MartiniUp is offline   Reply With Quote
Old 07-18-2013, 10:31 AM   #6326
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 686
Back on the ground with fresh rubber!
Check out the kickstand
Old 07-18-2013, 10:45 AM   #6327
aaron2a
supermoto hooligan
aaron2a's Avatar
Oddometer: 686
It's here!! Time to install
Old 07-18-2013, 02:08 PM   #6328
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 930
I'm in the middle of installing the Acerbis 5.8 gal tank and it seems like the forks will wear through the tank, yet it fits perfectly otherwise. Does anybody have experience with this?
Clem Kevin is offline   Reply With Quote
Old 07-18-2013, 02:33 PM   #6329
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,095
Originally Posted by Clem Kevin View Post
5.8 gal tank
That is a big tank!
XR4EVER is offline   Reply With Quote
Old 07-18-2013, 02:34 PM   #6330
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 930
Originally Posted by XR4EVER View Post
That is a big tank!
Right? I'm doing TAT and there's a few 250 mile sections, rather than buying an extra storage tank and dealing with carrying it on the bike, I got the big tank.
Times are GMT -7.   It's 09:17 AM.
