Old 09-08-2013, 01:25 PM   #6616
mark1150
mark1150's Avatar
Oddometer: 194
Originally Posted by jphphoto View Post
Woohooo!.
Looked at it yesterday and Lo and Behold! Loose Screw. probably could have fixed this on the trail if i had a screwdriver with me. doh! Guess the loose screw is between my shoulders sometimes.
Lock tight is prescribed! "Thankfully the fix is easy," . Not so much with the wrong part bike bandit sent me. Linkage kit for the wrong years. Let's see if they can fix it quickly. Maybe its partially pivot works' fault since they label the '96-'97 parts ambiguously. I needed the 2000. But I paid BB. Major discount when it was on sale. It'll give me more time to clean the bike and see what I can uncover while I wait.
Jason
Glad it worked out for you mate, as it's a proper PITA when it all goes Pete Tong.
mark1150 is offline   Reply With Quote
Old 09-08-2013, 01:27 PM   #6617
mark1150
mark1150's Avatar
Oddometer: 194
Originally Posted by DrLewall View Post
Here's a picture of me praying and giving thanks to the XR Gods fixt
I missed the edit when I first read it, bloody brilliant mate.
Thank you.
Old 09-08-2013, 02:56 PM   #6618
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,499
Thank you.
You are most Welcome!
DrLewall is offline   Reply With Quote
Old 09-09-2013, 05:22 AM   #6619
XR400R99
XR400R99's Avatar
Oddometer: 31
XR Transparent Tank Listed in the Swap Meet
Baja Designs Dual Sport LED Drop Down Tail Light and a 4 Gallon Gas Tank, transparent are listed in the Swap Meet Area. Thanks
Zed's Dead Baby /
XR440R Street Legal via Baja Designs Dual-Sport /
XR400R99 is offline   Reply With Quote
Old 09-09-2013, 09:44 AM   #6620
xr400r
xr400r's Avatar
Oddometer: 3,198
Originally Posted by XR4EVER View Post
On any internal engine parts, use Vaseline as a pre-lube. It is very oil-soluble, where grease is made to NOT wash away.
Thanks for the info! Anymore helpful advide on replace valve stem seals on the xr400?
xr400r is online now   Reply With Quote
Old 09-10-2013, 12:27 PM   #6621
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,094
Not from me. I'm mostly useless, with the occasional random burst of helpful info.
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 09-10-2013, 01:17 PM   #6622
XR4EVER
XR4EVER's Avatar
Oddometer: 1,094
Baja Designs DS kit brake light switch
Any of you with the Baja Designs DS kit on your bike ever run into this problem? I was out riding some nasty single track this past weekend when I realized I had no back brakes at the most inopportune time. I was pivot turning at a right-hand switchback on the edge of a cliff, tried hitting the back brake to keep from rolling backwards down off the edge, and....
We were riding through some thick brush earlier, so I just assumed I tore the rubber line when I looked down and saw fluid in the master cylinder area. I just now tore it apart and found the problem. The top of the banjo bolt blew out at the brake light switch. I have had this kit on since '02, and this is the first problem I've had with this. I no longer use it for road use, and the stock one is long gone, so I am just going to dig/drill out all of the switch components and weld the pig shut. If you have the same setup on yours, you may want to carry the stock banjo bolt with you in your tool bag or switch over to an external switch. I don't know if it was something that deteriorated with age, or if a foreign object got up in there and broke it.
And just for kicks, props to the XR for making trails like this look easy, even without brakes! It is hard to tell in the vid, but we gained 1300' elevation from the beginning to the end of the clip. One wrong move, and it is a loooong way down.
I hate bear grass.
Old 09-11-2013, 01:55 PM   #6623
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 515
so what are we using for extended fuel screw on the might xr4?. Aftermarket tank makes fiddling difficult. Also I have a stock white tank without hardware if anyone needs. Make offer by pm. Greater Cincy area.
Sent from my SPH-D700 using Tapatalk 2
tonusmaximus is offline   Reply With Quote
Old 09-11-2013, 02:19 PM   #6624
jphphoto
jphphoto
Oddometer: 35
Swingarm mount and bolt cleaning
Hi,
Not sure if this has been discussed, but thought I'd ask.
I'm doing maintenance on the swing arm and shock of my 2000 XR400
The axle came out with some hammering (20 minutes) and pre-emptive squirts of liquid wrench penetrant each time I was in the garage over a 1 1/2 month period.
Clearly it was in there pretty tight. Before putting it all back together I want to clean up the bolt as well as the mounting hole on the engine cases. Thinking a brass brush for the mount point. Have any of you had luck with this? What do you recommend for cleaning up the swing arm bolt and the mounting hole?
Thanks,
Jason
"Up-hils, along with downhills and level ground,
have always been my weakness. " Rick Seimans
jphphoto is offline   Reply With Quote
Old 09-11-2013, 02:25 PM   #6625
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,632
Hi,
Thanks,
Jason
I sanded the rust off my bolt and then polished it using a wire brush wheel in a bench grinder. A cheap shotgun bore brush (Wal-Mart item) and WD-40 can be used to clean out the hole in the engine cases. Lots of high-quality waterproof grease (Mystik or Bel-Ray) all over the bolt upon reassembly. Do this maintenance once a year.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is online now   Reply With Quote
Old 09-11-2013, 03:20 PM   #6626
jphphoto
jphphoto
Oddometer: 35
[QUOTE=XR4EVER;22298284]Any of you with the Baja Designs DS kit on your bike ever run into this problem?
does anyone make a mechanical switch we can use?
glad you were able to continue.
And just for kicks, props to the XR for making trails like this look easy, even without brakes! It is hard to tell in the vid, but we gained 1300' elevation from the beginning to the end of the clip. One wrong move, and it is a loooong way down.OTE]
that ridge looks fun. is the path as narrow as it looks in the video?
Cause those switchbacks sure look scary from the wide angle lens.
Jason
Old 09-11-2013, 03:50 PM   #6627
XR4EVER
XR4EVER's Avatar
Oddometer: 1,094
This one would probably work with some creative mounting, although Im not sure if it is a "pull to turn on" or "pull to turn off" switch:
https://www.denniskirk.com/210119.sk...FS_ZQgodyzUAQg
Jason
Yeah this one is pretty high on the pucker factor. I have been on ones that are a lot more dangerous, but the fact that this entire trail is a steep uphill climb, 8" wide, AND the trail itself has an off-camber, downhill pitch (and severely washed out in some spots); it is just relentless. It also doesn't help that you are blinded by tree branches every 10 feet. You learn really quickly not to look out at the scenery while moving -- your bike will follow where you look.
I hate bear grass.
Old 09-11-2013, 06:33 PM   #6628
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,499
^^THIS!!! I learned the hard way!
Old 09-11-2013, 07:16 PM   #6629
MCCOYBOY
Oddometer: 99
I'm part of the group now ;)
I have been riding around my Dual Sported xr600 for about a year now and finally came across it's younger brother the xr400. Guy had it for sale for $400! It's a 2000 model and is mostly stock besides the stator and baja designs kit. Needs some TLC but I've got that handled.
I'm looking to turn her into a stealthy Dual Sporter with very few after market goodies. I did open the air box and found a spotless K&N air filter. Problem is I ride in some nasty conditions so that's got to go. Anyone have a UNI filter and cage they would want to trade for the K&N?
Pictures coming soon!
MCCOYBOY is offline   Reply With Quote
Old 09-11-2013, 11:45 PM   #6630
KilLeR Kawasaki
Marky A
KilLeR Kawasaki's Avatar
Oddometer: 964
You stole that. Go out and do something nice for someone.
2008 Kawasaki KLR650
2001 Honda XR400R
2007 Suzuki Bandit 1250
Colorado Dual Sport Riders
KilLeR Kawasaki is offline   Reply With Quote
Times are GMT -7.   It's 03:28 AM.
