Old 10-29-2013, 06:04 AM   #6736
hadfield4wd
Oddometer: 138
Call it the CXR440R 100% street legal with clean title.
1999 Honda XR400R:
440big bore kit
12.5:1 Compression JE piston
+1mm Kibblewhite valves w/titanium springs and retainers
Head ported and polished
Stage 1 cam
White brothers pipe
Uni air filter
Forks rebuilt with racetech springs .48kg (stiffest they had, I am 185lbs)
Pro Taper Contour bars
Tusk hand guards
Bar risers
Baja Designs Headlight with Hi and Low beam switch
LED brake light
MX rear fender
SDG tall seat
EBC HD rotors front and rear with EBC red pads
Acerbis rotor guards
ASV levers
Clark 3.8 gallon tank (140 miles usually until reserve) 40+ mpg
Stainless steel braided line on the front
Trailtech Vapor
hadfield4wd is offline   Reply With Quote
Old 10-29-2013, 01:34 PM   #6737
G600
Oddometer: 461
Very nice.
Why do you want so heavy/stiff springs? Are the forks from a CRF?
G600 is offline   Reply With Quote
Old 10-29-2013, 06:20 PM   #6738
MartiniUp
Oddometer: 1,928
1999 Honda XR400R:
440big bore kit
Stage 1 cam
White brothers pipe
Uni air filter
Tusk hand guards
Bar risers
LED brake light
MX rear fender
SDG tall seat
ASV levers
Trailtech Vapor
Fix that fancy new brake line before you rip it off. Will take about three minutes. And I agree those, 48 springs are very stout for 185lbs unless you have very very soft valving.
MartiniUp screwed with this post 10-29-2013 at 06:33 PM
MartiniUp is offline   Reply With Quote
Old 10-30-2013, 03:10 PM   #6739
hadfield4wd
Oddometer: 138
Originally Posted by G600 View Post
Very nice.
Oops that was the fork springs from the old stock forks. Still lighter than what racetech recomends.
New forks are from a 1999 CR250
Brake line is done. It's not actually my bike it's my buddies. I do the engine work. And assist with all the other stuff. I've toyed with buying it myself as it's for sale.
Old 10-30-2013, 04:03 PM   #6740
MartiniUp
Oddometer: 1,928
If I was closer I would want to take a hard look at that bike, that has to be a very nice pkg. If priced right you can't go wrong. The XR4 will always be in demand.
Old 10-30-2013, 04:53 PM   #6741
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,593
Yes..this is true..I always DEMAND to ride mine! and I do!
DrLewall is offline   Reply With Quote
Old 10-31-2013, 11:53 AM   #6742
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 930
Question, are the sleeves pressed into our cylinders or are they a drop on deal? In the blowup, my piston expanded out the lower end of the sleeve and I'm wondering if it'll just be cheaper to find another cylinder and sleeve than to deal with this one. Just got a bottom end online for 425 with only 12 miles. Just gotta get new valves, do some headwork, and probably buy a new clutch pack
My Spotwalla Link
Clem Kevin is offline   Reply With Quote
Old 11-02-2013, 06:26 AM   #6743
xr400r
xr400r's Avatar
Oddometer: 3,203
I am in the process of reassembling my 400 motor. What is everyone's opinion/recommendation on oiling piston, rings, cylinder when reassembling?
a light coat of oil on the cylinder, rings and piston skirt sounds reasonable to me.
How about wrist pin? assembly lube?
thanks
xr400r is online now   Reply With Quote
Old 11-02-2013, 06:39 AM   #6744
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,593
assembly lube works, just as regular motor oil..and start from the bottom up..that means crank wrist pin up thru the jug, rings, guides, and anything that moves in there
Old 11-02-2013, 09:41 AM   #6745
G600
Oddometer: 461
thanks
I use engine oil on all moving parts when I reassemble my engines. Has worked for me so far.
Old 11-02-2013, 02:15 PM   #6746
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,393
I wrote up a dual sport guide for my XR400.
http://www.thumpertalk.com/topic/105...xr400-part-ii/
n16ht5 is offline   Reply With Quote
Old 11-02-2013, 04:47 PM   #6747
xr400r
xr400r's Avatar
Oddometer: 3,203
Well, kinda on the subject and thanks for the responses earlier.
I am planning on dual sporting my 400 and have a high output stator. What is the best head light option to take advantage of the upgraded stator? needing a high/low beam. I like the idea above just wondering what else is out there besides a ktm light....not that I am opposed to that.
Thanks,
Old 11-02-2013, 05:25 PM   #6748
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,393
http://www.cyclopsadventuresports.com/
if you want some really bright stuff, call that guy up.
Otherwise it is mostly DIY stuff. We just put dual 55W ebay HID into a trailtech X2 dual sport light that turned out well.
I have a ebay HID projector in my Husaberg that works really well, but I had to use a hole saw to my stock headlight
n16ht5 screwed with this post 11-02-2013 at 05:36 PM
Old 11-02-2013, 06:30 PM   #6749
creaky
creaky's Avatar
Oddometer: 186
thanks
I have for many years used regular engine oil for the piston/rings , never a problem. Best to use non detergent oil, allows the rings to seat quickly. Assembly lube for the piston pin.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
"Once you go over the hill, you start picking up speed!"
creaky is offline   Reply With Quote
Old 11-02-2013, 08:48 PM   #6750
xr400r
xr400r's Avatar
Oddometer: 3,203
How do you tell if it is a non detergent oil?
Times are GMT -7.   It's 05:09 AM.
