Old 01-28-2009, 08:09 AM   #766
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Originally Posted by Hayduke
The guy emailed me back this morning.... someone MAY have beaten me to it!
LaOutbackTrail is offline   Reply With Quote
Old 01-28-2009, 11:42 AM   #767
dirty adventurer
dirty adventurer's Avatar
Oddometer: 253
My best XR400 pic
99 XR400, plated
dirty adventurer is offline   Reply With Quote
Old 01-28-2009, 12:26 PM   #768
screwit
One more time
screwit's Avatar
Oddometer: 852
Tank
Hey Dirty,
Which tank is that? I'm tank shopping right now.
screwit is offline   Reply With Quote
Old 01-28-2009, 12:56 PM   #769
dirty adventurer
Oddometer: 253
Originally Posted by pilotrider
Hey Dirty,
That's the 4-gallon IMS tank that I bought in 1999.
I have no complaints about it!
99 XR400, plated
Old 01-29-2009, 10:55 PM   #770
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Question Best Headlight---- I rarely use this line.
Hmmm Picking up an XR400...
Wanting to dualsport it soon. Trying to figure out which headlight (need high/low beam)
I just found the Trail Tech XR
The Baja Designs
And the UFO
I'm likely to get the dualsport kit through ProCycle.com and they sell the BD and UFO lights. Are either of these using H4 bulbs? I ask because I have an HID setup that I could use.
OR........ what is the best headlight?
Old 01-30-2009, 10:24 AM   #771
Brandon
Brandon's Avatar
Oddometer: 194
I believe the only one of the three that is DOT legal is the Baja Designs. You may not care about being DOT compliant but if you are gonna have to have an inspection to get a plate it may be wise to take the safe route.
I do like the UFO with the built in turn signals though.
Current Rides
2008 Suzuki V-Strom 650
2002 KLR - Not quite a stocker.
Brandon is offline   Reply With Quote
Old 01-30-2009, 10:26 AM   #772
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,033
You're going to need a high output stator, too if you really want those lights to work.
Congrats on the bike!
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 01-30-2009, 10:27 AM   #773
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
i'd go with the ufo because you get your front blinkers with the deal and the xr electrical output can't handle much more than a 55w bulb anyway.
i think it's an h4 and so your hid would help.
but ask here
http://www.thumpertalk.com/forum/forumdisplay.php?f=26
here's how i mounted my plate:
http://www.4strokesonly.com/LicensePlateHolder.html
you can get bolts that have led in them to light up the plate.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 01-30-2009 at 10:47 AM
Old 01-30-2009, 11:02 AM   #774
Brandon
Brandon's Avatar
Oddometer: 194
Here's a couple pics of my 01 in it's current configuration.
Current Rides
Old 01-30-2009, 08:32 PM   #775
procycle
procycle's Avatar
Oddometer: 2,407
Originally Posted by Brandon
I believe the only one of the three that is DOT legal is the Baja Designs. .
Both the Baja designs and UFO are DOT approved. Don't run the Trail Tech light on the street. It doesn't have the proper type of light pattern. You will dazzle oncoming traffic.
The Baja Designs headlight has an H4 bulb. There are lots of good reasons not to try to run one of those HID conversions.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-30-2009, 08:43 PM   #776
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Why not? And this XR400 should be racing the Baja 500 next year.
Old 01-31-2009, 07:01 AM   #777
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,033
I know Firstworks had an HID on his, and had to get rid of it- it was blinding other vehicles and pissing people off.
Old 01-31-2009, 07:27 PM   #778
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Well, the only time I ride at night, its because I have no other choice! And when I am usually in an area where I NEED all the light I can get.
I dont think I'd have a problem with the HID... but can someone answer me this? Does Baja Designs have an upgrade for DOT light to have the HID setup?
I got the XR today. Picked it up, trailered it up the road 20 miles from where i picked it up, and did like 30 miles of single track... But I need new grips. The grips on there TORE MY HANDS UP!!!!!!!!!!!
Buyer's remorse??????????
Nahhhhhhh
Old 01-31-2009, 09:45 PM   #779
procycle
procycle's Avatar
Oddometer: 2,407
Baja Designs has a HID version of their headlight but it is not DOT. The H4 BD light is DOT. One problem with converting H4 lights to HID is the light pattern. You can't fit the problems wit the pattern because the HID and H4 light sources are different shapes. Like Heyduke says you're likely to blind other drivers. If you are just using it off road it won't matter.
Old 02-01-2009, 04:36 AM   #780
wide
Oddometer: 391
Seat look beefed up, how is it I need more comfort when out on the road
wide is offline   Reply With Quote
Times are GMT -7.   It's 03:34 AM.
